Dealer oil change went bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomawv, Apr 20, 2013.
  1. Apr 20, 2013 at 10:00 AM
    tacomawv
    tacomawv [OP] tacomawv
    Richard
    WV
    sr5
    Wade sure-fit mats, afe dry filter
    Went to have my 5000 mile oil change today. Looked under the truck at my filter and it was covered in mud. The tech said that he changed it. I made him look and he said that he may have forgot to change it. Then he told me that my truck does not need to have service til 10000. I told him that the 2.7 is at 5000. He did not believe me til I showed him the book that came with my truck. Then he said that he will change the filter. I told him that I want it all done again and I need to be under the truck to watch. After about 10 min. he said ok I could watch. At the end I got the change with a new filter, oil and washer for the plug. This is the first and last time I will not do my own oil change. They were suppose to replace my mirrors because they were scratched when I got the truck. They told me that they could not find my mirrors. Also I did not get my tires rotated but I would rather do it myself. If you use toyota care check your stuff before you leave.
  2. Apr 20, 2013 at 10:10 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Crap like this always makes me paranoid when bringing a vehicle to a dealer. Luckily the Toyota dealer near me is squared-away.
  3. Apr 20, 2013 at 10:21 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yeah, well it's shit but seems like this always happens. Flat rate doesn't help IMO.
  4. Apr 20, 2013 at 10:26 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Maybe they use pre-mudded oil filters.
  5. Apr 20, 2013 at 2:58 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's a Toyota off road filter. Usually they are special order.
  6. Apr 20, 2013 at 3:05 PM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Last time I went to dealer for oil change, I ended up leaving with Only 3 lug nuts on my wheels. That's completely unaccecptable.
    I should add that this was in Toyota of Riverside. Terrible place
  7. Apr 20, 2013 at 3:07 PM
    custom90gt
    custom90gt Well-Known Member
    Colorado
    05 SWB TRD Off Road
    What are you talking about. Everyone knows you only need 2 lug nuts and the rest are just for looks.
    At least the op didn't have too bad of an experience, I've seen dealerships forget to put oil back in. Guess how well that turns out...
  8. Apr 20, 2013 at 3:11 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
  9. Apr 20, 2013 at 3:18 PM
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    Never had a problem with the oil change I always mark my filter and torque stripe the drain plug. But for my 5K & 10K the tires were never rotated. I would mark one and check it after the service. NOPE! Try again guys.... Bunch of lazy pieces of shit. I got tired of having to send it back, so on the 15K I reminded them ahead of time. The first time I took it in, they asked me if like a wash... Why bother? It came wet with soap still on it... I'm not picky, and I don't expect a full detail but COME ON at least pretend like you give a shit..
  10. Apr 20, 2013 at 3:18 PM
    Trd2013taco
    Trd2013taco Member
    NC
    trd off road
    Took my 08 fj tt to the dealership to have my tires balance because of steeeing shake.. I took delivery of it without cking since it was in a hurry.. once I got home noticed a deep scratch circle that basically went ariund the the lugs all 3rims had indentations and one lug stud was broken!.. only good thing was steering shake was gone.. called dealership talked to one of the service manager and they replaced all 3rims and installed new lug at no cost.. been going to them ever since..
    Had a few oil changes with some minor incidents but they were quick to take care of it .. I guess it all depends on which dealership you go too.. some actually care about customer service
  11. Apr 20, 2013 at 3:34 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    The local dealer here was pretty good until recently. My last few experiences were not promising.
    Simple warranty work, replace the rear door window weatherstrips under warranty, wrong parts ordered. After days of waiting, they were changed and the interior trim clips were not secure with the trim panels falling off.
    Same work order, replace the two rubber molding strips on the roof on account of the TSB. Strips were not pushed in and seated, would have been lost during the first high speed highway run.
    Same work order, replace the headlight on account of them having small cracks in the clear lens, this one was dangerous. The light were aimed for light 50 feet max in front of you. Nothing beyond that lit up.
    Adjusted the lights myself. When it went back for the rear window moldings I asked about checking the light alignment. I was told they previously had the special alignment tool I read about in the service manual, but they did not have it any longer. I was told the guy did his best just aiming them on a wall. Yes this is in the manual also, but tells you how to do it properly.
    Lastly, went in to buy a TRD Corrolla filter for the wife's car. It has already had one installed before. The parts guy sort of argued they don't make one. Called the next day to one of the few remaining good guys, looked it right up and had it by 10 am.
    From what I can tell, this dealership has fired or had most of their quality leave.
    Sad to see it, but welcome to the almighty dollar, lazy workers, and poor management.
    Best part about the warranty work was the phone call I received about my experience. I asked the girl you are joking, right. Told her what happened and was informed there would be a follow up call with her boss...guess what? no call.
    Other stuff from other dealers...tire shop put the lift almost through the wifes old Civic floorboards. Then when questioned and told they had initiated the reports to cover the damage and come back tomorrow to show the manager, guess what...magically the car never had been in there for tire work.
    Daughters car, at the time a new Eclipse, went in for warranty brake work. Told her they were installing new parts, nope they were recut rotors, but better still they forgot to tighten both front wheels. She drove 175 on the highway back to school, said it still had a little vibration from the brakes. I explained, to take it to the dealer in Orlando. She made an appointment, but days before the appointment called in tears afraid to drive the car. I told her to pull into safe parking lot, and check the wheel nuts. She set the phone beside her as she went to check them. My angel daughter (not) could be heard in the background with some foul but appropriate words. all were loose but many turns. And to think, even after her going back to that dealer they would do nothing, then they called many times wanting us to buy a new car.
    Enough before I get really worked up and tell you about low quality aircraft repairs from BS artists and scoundrel shops. If you know an airline mechanic, ask them where they send the airliners for heavy maintenance work. Not many places in the US anymore. PK
  12. Apr 20, 2013 at 3:45 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    GUY ON A BUFFALO, lol
    OP that sucks! I always have a rough day when I have to take mine in for the interval oil changes... The "kids" at the dealer here seem to treat my truck well. I tell them not to complimentary wash it cuz they have to drive it down the street to do it... first time they did wash it I caught the dude enjoying a "spirited" drive back to the lot. All i ask is that you respect my shit, seriously...
  13. Apr 20, 2013 at 3:52 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    If you want something done right..............
  14. Apr 20, 2013 at 6:00 PM
    jrogers329
    jrogers329 Well-Known Member
    Huntsville, AL
    2011 Prerunner TRD DCLB-TRADED!
    ^^ This x1000! I do all my own stuff that I can.
  15. Apr 20, 2013 at 6:04 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Dealers= rip off
  16. Apr 20, 2013 at 6:38 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    You couldn't pay me to have someone else wash my truck. They are ruining your paint with the brushes they use to clean it. You might as well wash it with sandpaper IMHO.
  17. Apr 21, 2013 at 7:47 AM
    Del Scorcho
    Eagle, ID
    No brushes... They just have a pressure washer cart with a soap gun and a deionizer for the rinse water.
