Dealer problems on taco recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slimsean, Jan 5, 2017.
  1. Jan 5, 2017 at 5:54 PM
    slimsean
    slimsean [OP] New Member
    sean
    ny
    05 sr5 with lift
    lift kit and wheels
    Hi everyone, got my recall taken care off after a long wait. Lots of problems along the way though.
    Dealer hit my hood and when they tried to give it back they told me they never noticed and they would fix it. Ok, no problem I said. When I stood back the truck was sitting lower in the rear. So I looked and sure enough they never put the lift kit back in. They told me they look into it.
    Anyhow they fixed my hood but told me the Tacoma never had a lift kit in the rear. Showed them photos on my phone in their shop and that done the trick. Anyhow, got the car back and on the way home for the (fourth time) CEL comes on. Put it through my scanner and called Toyota. The codes were (p043e p043f p2401 p2402) all relating to evap system. Toyota told me to bring the car back. 3 days later they told me it needs a charcoal canister. They want $971.00 for it. Also back at the beginning of my problems they called and said they wanted $$350.00 for nuts and bolts for a RECALL.
    Has anyone had these problems with dealers on this recall and any ideas on what I should do.
  2. Jan 5, 2017 at 6:23 PM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    Lawyer Up !
  3. Jan 6, 2017 at 5:40 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Likely not an option unless the OP lives in a very Plaintiff favorable state like CA. Even then still probably not an option.
    I would ask to speak to the manager obviously and go as high up the chain as possible. See if they can't get you a solution.
    I'm assuming you are talking about a frame replacement here. If it were me I'd just get it to the point where I could sell it or the dealer would give me cash value.
    A frame replacement is a big deal, its bound to cause multiple issues. This is why I'm shocked many people go for the replace and keep the truck. It would scare me off. But thats just me.
    Put up a fight OP. Dont let them off the hook.
    Did you buy the truck with them?
    Rambo54[QUOTED] likes this.
  4. Jan 6, 2017 at 5:46 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    How can they charge you anything for them do the recall work, no matter what state your in. Contact Yota Corp, and then reach out to a lawyer (friend) and get some thing in writing on lawyer letterhead and send to dealership and corp. If that doesn't work, time to see the judge. NO WAY would I pay a dime for them to do any recall work, NONE!
    Rambo54 likes this.
  5. Jan 6, 2017 at 5:57 AM
    ColoradoTom
    ColoradoTom Team Velveeta™
    Colorado
    2014 Tacoma 4x4 Access Cab
    This.
    When I got my Tacoma in '14 the AC almost immediately became ineffective. Just stopped blowing much colder the the ambient temp. The dealership dragged some feet and cost me quite a bit of time. AC wasn't fixed the first time.
    I got in touch with Toyota America and things happened fast. You see, the dealerships need to be pretty much perfect. If corporate hears a story like this phone calls get made. Asses get chewed. I almost felt bad for my dealership (almost).
    Make a call. They answer their phones.
    PackCon likes this.
  6. Jan 6, 2017 at 6:20 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you mean frame recall ?
    they are only responsible for putting toyota parts back on
    if you came in with a lift, for a frame recall, you are obligated to remove
    all aftermarket crap and put it back to stock, then take it in
    but they should have told you before touching your truck. it's now their problem but it is complicated by your aftermarket parts
    all recalls have exacting steps and procedures and pay rate from toyota,
    a dealer is not obligated to dick with any extra crap...only factory crap
    TRDSport10, Jimmyh and PackCon like this.
  7. Jan 6, 2017 at 7:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What he said!
    Rambo54 likes this.
  8. Jan 7, 2017 at 3:39 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    If you have a lift you have to either have them put it back to stock or pay to have the lift put in. Toyota only pays for the stock stuff after that you have to pay. I work at a dealer so I know
  9. Jan 7, 2017 at 6:17 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    This. Had a similar situation but with the headlight melting issue. Dealer tried to make it out as if I did it by using the wrong bulbs. Pulled the bulbs to prove they were the original bulbs, called Toyota of America on the spot and shit rolled down hill for tha dealer within a matter of an hour.
    Don't let that dealer nickel and dime you on a recall as big as the frame replacement and above all, make sure they did the replacement correctly. Have a tech and the service manager comb over the truck for you and have them explain line by line On the repair paper work what all was required to do the frame replacement.
    asuchemist likes this.
  10. Jan 7, 2017 at 10:36 AM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    I had my frame done with no problems or extra charges. My truck was lifted when it when in and still lifted when I got it back. The only trouble they found was the 1/4" spacer on the drivers side for the taco lean. They called me and I explained it to them and they put it back where it came from.
    They also did the whole job in 2 days!
    Rambo54 likes this.
