Dealer put in wrong plugs !!! WTF
Discussion in 'Performance and Tuning' started by Razorecko, Jun 2, 2014.
  1. Aug 8, 2014 at 6:05 AM
    #41
    Razorecko
    Razorecko [OP] Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    They did put on trd supercharger software, the stuff the other dealer showed me was newer supercharger software. The newer supercharger software makes the truck run not as LEAN !! and make considerably less power. From what I heard it neuters the truck so there is no point in even supercharger anything from toyota as the tune will castrate it because they can't get their sh*t togethor.
  2. Aug 8, 2014 at 6:37 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not the option that you want to hear, but an aftermarket ECU will take care of that. ;)
  3. Aug 8, 2014 at 10:36 AM
    #43
    nine3
    nine3 Well-Known Member
    Seattle, WA
    14 DCSB TRD OR Supercharged MT
    This is also why I'll be installing a wideband O2 sensor.
