Dealer quoted me a lift installed at $450, is that good or bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fxbrry, Dec 18, 2013.
  1. Dec 18, 2013 at 7:46 AM
    fxbrry
    fxbrry [OP] Well-Known Member
    Im new to Tacomas so bear with me. I want to lift my 2013 DC sport to allow for larger 33inch tires. The Toyota dealership where I bought the truck installs a spacer lift kit. The parts rep said its a 3 inch spacer up front and a 1 inch spacer in the rear and it will allow me to run 33's. He quoted $450 installed including a realignment. He said it was a TRD lift. I didnt know Toyota had a lift. I usually do this kind of stuff myself but I went to the dealership so that it doesnt void my warranty. How does this sound? Will I fit 33's?
  2. Dec 18, 2013 at 7:49 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Yea it will fit but you're still going to have to trim plastics and maybe cut the cab mount...
    Also remember spacer lifts = stiffer ride and if the lift is pushed hard can cause premature failure to the stock struts resulting in damages
    Why not get some Bilstein 5100s?
  3. Dec 18, 2013 at 7:58 AM
    18seeds
    18seeds Well-Known Member
    save up for a real lift. you will regret the spacers
  4. Dec 18, 2013 at 8:01 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Does the dealer warranty the work? If the shock fails because of the lift they installed, will they replace everything? If they do, I would say that's a pretty good bargain, the alignment alone will be close to 100 bucks.
  5. Dec 18, 2013 at 8:06 AM
    fxbrry
    He told me that it would not void the warranty and I don't do any hard core wheeling. I mostly want a more aggressive look. I would prefer new springs and shocks but I have a lifetime powertrain warranty with this dealership so I don't want do any mods this will void it. I'm coming from a Jeep so if the ride is a little rougher it will still be better than my lifted Jeep was.
  6. Dec 18, 2013 at 8:07 AM
    BamaToy1997
    Bill
    Navarre, FL
    I agree with Jerez. I suggest against spacer lifts as well. Never really a good idea. Too many people get them, then hate them later, or deal with damage to shocks. Now as for the cost, spacer lifts for the Tacoma can be bought all day long for about $150 depending on the brand (of course the dealer is not buying, or selling the lift itself at that price). Figure an alignment is what, $70? That is $220. Labor time would be in the neighborhood of 2 hours if you were meticulous.That is close to $200 at average dealership rates. So $450 installed is about a fair price if you DID decide to go that route.
  7. Dec 18, 2013 at 12:32 PM
    1strongone1
    1strongone1 Well-Known Member
    Jeff
    Iowa
    12 TRD Sport Supercharged
    Lifted, 33's, Supercharged, Volant Ram air CAI, Walbro fuel pump, 2.85 pulley, TRD exhaust, Bully Dog GT-T
    I had the front spacer lift installed from the dealership as well. When I put new tires on I decided to put some 5100's on like everyone on this site suggests, seeing as I would need an alignment anyhow. I put the 5100's on and the are a harsher ride than the spacers. Just my personal experience. If you don't do a bunch of off roading, the spacers are fine, with an AAL on the rear
  8. Dec 18, 2013 at 1:20 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    That is an excellent price, in fact that sounds too low if done right with including alignment. I have that lift on my truck done by the dealer. Most likely that is a Ready Lift http://www.readylift.com/products/to...t-69-5055.html . They priced the parts for that lift 299.00 for the parts plus labor. The TRD package also requires Sway Bar Relocation bracket.
    Also make sure they give you something in writing saying the lift will not void the warranty in any way. I had to press the dealer on that one. By the way I do not find that the spacer lift is a harsh ride. If this is mostly for looks, which is why I did mine as well as hoping it would be easier for this old man to get into the truck, and you are not going to be doing any hard wheeling, this lift will be fine and save you a lot of cash. I have been off road with mine on some very rocky trails and had no problems, but I did not rod the truck either. I took it to Colorado and did some trails. The one was over 7 miles long, rocks and boulders all the way and took me about 3 or 4 hours so complete.
    You asked about tire fit. This is what Ready Lift says about this lift;
    "Allows for up to a 33 x 11.5 tire on an 8" wide wheel with 5" backspacing with minor trimming of the inner fender liner. 32.5" tires on and OEM or 5" backspacing wheel should fit with no trimming required."
  9. Dec 18, 2013 at 1:55 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Really?
    I had spacers then went to 5100s and it was night and day :notsure: smooth as hell :cool:
    (Set at 2.5)
  10. Dec 18, 2013 at 1:59 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    My spacer lift rides close to stock as well but I'm going with the 5100s here pretty soon
