Dealer Recommended Service Intervals
Discussion in '1st Gen. Tacomas (1995-2004)' started by SonnysTile, Dec 24, 2010.
  1. Dec 24, 2010 at 8:48 AM
    SonnysTile
    SonnysTile [OP] Well-Known Member
    Sonny
    Louisville KY
    '04 TRD Dbl Cab 4x4 Limited
    A shitty snugtop, step bars, wheels, and vent shades... For now.
    I did a quick check through my owners manual and didn't see this?
    Anyone know what and when Toyota recommends as far as services and at what mileage?
    Five years ago my last Tacoma had the starter fail right next to a dealership at about 100K so I had them perform the dealer service. I know I paid a lot, but 80,000 miles later I never had an issue.
    I just upgraded to an 04 that has 88K on the clock and was wondering what kind of preventative maintenance is suggested at this mileage.
    I notice a slight whine from the engine so I was thinking belts?
    Anyone know or have an opinion?
  2. Dec 24, 2010 at 2:03 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Just regular maintence...? Oil and oil filter every 3k (unless useing synthetic, like me) I dont like to go over 4,500-5k without changing, Top off all fluids, Check all belts and replace if their needed, Air filter, Fuel filter, Pcv valve, Flush radiator, Grease up all joints and drive shafts, Spark plugs, Clean throttle body, IAC (Idle Air Control Valve), Seafoam, Rear diff fluid (if 4WD front diff and t-case fluid), Flush transmission when its time to do so and replace what ever breaks and the truck should last forever! :D
  3. Dec 24, 2010 at 2:06 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Umm, what has been going on since 2004?
    My three Tacomas ('01, '05, 10) all had the same recommendations:
    oil change every 5,000, mid level service at 15,000 miles, and full blown service at 30,000 miles. The First Gen. timing belt needs to be changed at 90,000 miles, too.
  4. Dec 24, 2010 at 2:08 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Oh and good jop for useing your owners manual! :D Most people seem to forget its there!! lol. :tumbleweed::smack:
  5. Dec 24, 2010 at 2:11 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    I dont think he meant theres a difference with the 2004, I think he just didnt know what is suppose to be done in general.. Atleast thats what I thought? But OP look at the stickys and use the search function and most of the time you will find your answer! :thumbsup: And yes change the timming belt around 90k, some people just like to see how long they can go untill it breaks lol. Its a non-interference engine, so pistons wont hit valves, you will just be stranded untill you get a new belt.:D
  6. Dec 26, 2010 at 11:06 AM
    Nick_Taco
    Nick_Taco Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
    dont most people replace water pump and thermostat along with the belt at 90k?
  7. Dec 26, 2010 at 7:02 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Here's my mental checklist:
    Every 7.5k - Synthetic Oil Change
    Every 7.5k - Grease all zerks
    Every 7.5k - Rotate tires
    Every 20k - Fuel Filter and PCV valve
    Every 90k - Replace timing belts, radiator hoses, thermostat, water pump, acc. belts
    Every 100k - All gear lubes changed
    Every 100k - Spark plugs and wires
    Every 150k - New rear shoes
  8. Dec 26, 2010 at 7:03 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Yes.
    I get my parts from www.partznet.com (awesome pricing for Genuine Toyota parts).
    I also replace the upper and lower radiator hoses and all three accessory belts while I'm at it.
  9. Dec 27, 2010 at 7:09 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    http://smg.toyotapartsandservice.com/
    You can enter your year and model, and the mileage/time interval you are looking for.
    At my 90K, I did my timing belt, accessory belts, water pump, idler pulleys, plugs, all fluids, and I'm sure some more stuff too.
  10. Dec 27, 2010 at 8:32 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Besides the regular scheduled maintenance stuff, you might also want to get the truck on a lift you can inspect other critical component. Some things to watch out/check for on the Tacoma are:
    1. Frame Rust
    2. Leaking rear axle, oil pan, or Transmission seal
    3. CV/Ball Joints/Steering Rack assembly
  11. Dec 28, 2010 at 7:16 AM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Don't forget periodic re-torquing of your valve covers.
  12. Dec 28, 2010 at 7:28 AM
    SonnysTile
    Sonny
    Louisville KY
    Excellent information guys! Thanks.
    I do most general maintenance myself, but (horror stories aside) there is a peace of mind that comes with having the dealer perform some of the trickier tasks.
    I'm going to look into the belts, water pump, thermostat, differential oils, trans fluid and coolant, plus all filters.
    Any guesses as to what that would cost?
  13. Dec 28, 2010 at 7:36 AM
    asus611
    CA
    For my timing, air/oil filters, accessory, plugs, fluids, idlers (basically the "parts" I used for the 90K ) it was about $350-$400 I believe. I went all OEM Toyota though. I could have saved some money if I used an aftermarket idler, and aftermarket accessory belts. Also I used synthetic fluids all throughout.
  14. Dec 28, 2010 at 7:51 AM
    SonnysTile
    Sonny
    Louisville KY
    Thats not bad.
    I also meant to add plugs and wires.
    I see "TRD" air filters? Are these worth the premium dollars? Should I get a K&N or just an Autozone style filter and change regularly?
    I appreciate all the info!
  15. Dec 28, 2010 at 11:57 AM
    asus611
    CA
    I use OEM air filter.
    Also forgot, I replaced my upper/lower radiator hoses as well.
  16. Dec 28, 2010 at 2:25 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    +1. I did my timing belt job (replacing all of the other stuff along with it) and I think I paid around the same price.
  17. Dec 28, 2010 at 2:27 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    In the past, I've used K&N, Amsoil, Wix, etc, etc. I've ended up going back to a factory Toyota filter. Air filters, in my humble opinion, are a wad of fluff. I've also been very suspect of the "oil spray" filters and their safeness with MAF sensors.
  18. Dec 28, 2010 at 2:29 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    I want to note that I also change my air filter every 15k - 20k miles.
    Additionally, I want to ammend my "100k - All gear lubes changed" to actually about every 60k.
