Dealer refused to check transmission fluid at 5k serivce
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mweidl, Jan 4, 2018.
  1. Jan 4, 2018 at 3:18 PM
    #41
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    so unless there is a visible leak, no need to check?
    If the customer has a complaint about the way the truck shifts, then he should advise the service dept, & they should check the shifting issue as a customer complaint.
    mikestaco17 likes this.
  2. Jan 4, 2018 at 3:26 PM
    #42
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Toyota's way of thinking Yes, reality, No.
  3. Jan 4, 2018 at 3:43 PM
    #43
    Clearwater Bill
    Billy
    Largo Florida
    You did. Right in the post you quoted.
    2nd gens don't either on the v6 models.
    Dip-stickless is a new 'feature' for the 2.7 in the 3rd gen lineup, as it was included in previous gens.
  4. Jan 4, 2018 at 3:45 PM
    #44
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    yeah from cold, which its not when you drove to the dealership. and if its low you have to fill it, which is a pain in the dick with out a pump or a lift. takes more that 30 minutes. no need to make it sound like its super easy. not impossible to do yourself, but its not beginner level simple.
  5. Jan 4, 2018 at 3:50 PM
    #45
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    it is beginner level simple. Ok my bad you need a pump to hand pump the fluid in. If you change your fluids you should already have that anyways.
    I was more saying it’s simple for the dealers to do
    Since the dealers stated you need to remove multiple bolts and stuff, which is a lie.
    EdgeCrusher[QUOTED] likes this.
  6. Jan 4, 2018 at 3:51 PM
    #46
    anthony250f
    Anthony
    San Diego, CA
    It could have been underfilled from the factory?
    Which is very common
  7. Jan 4, 2018 at 3:54 PM
    #47
    richiep
    Rich
    NY
    under filled equals, slippage?
  8. Jan 4, 2018 at 3:56 PM
    #48
    Clearwater Bill
    Billy
    Largo Florida
    One possibility. Or clunky shifting, either up or down.
  9. Jan 4, 2018 at 3:56 PM
    #49
    richiep
    Rich
    NY
    that sucks!
  10. Jan 4, 2018 at 4:10 PM
    #50
    natural_nativ
    natural_nativ Well-Known Member
    2024 TRD Sport MT
    What exactly is the purpose of this new "feature"? Is there any benefit to not having a dipstick? One less part to fail/leak from maybe? Because all I'm seeing are problems.
  11. Jan 4, 2018 at 4:19 PM
    #51
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I have absolutely nothing worthwhile to contribute to this conversation other than this: your Edward Abbey quote is excellent. I read his stuff growing up on various backpack trips in the 4 corners area as a kid. Desert Solitaire was and always will be one of my favorites.
  12. Jan 4, 2018 at 4:24 PM
    #52
    Clearwater Bill
    Billy
    Largo Florida
    IMHO it's a play to force consumers to dealers or service centers. But touted as maintenance free, lifetime fill.
    Can't imagine what it would be in 99.99% of cases. Could make up some wild possibilities I guess.
    I've been banging around vehicles for lot's 'o years, and many of them were automatics. From powerglides of the 50's to electro whizz bang stuff of today. I've never had a problem on a trans or trans axle dipstick.
    The problem isn't being stick-less at the moment. It's being under filled from the factory and making checking accurate fill levels more complicated.
  13. Jan 4, 2018 at 4:25 PM
    #53
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    I had a 2016 3rd Gen SR5 4X4 with the 2.7L 4 cylinder and had zero issues with the AT. I never had the fluid checked, but also never had a reason too. Sounds like definitely the AT fluid needs to be checked. BTW the ECU software has only been changed once on the 4 cylinder trucks and the last update was back in Sept of 2015. So not likely a software issue but a fluid issue.
  14. Jan 4, 2018 at 4:39 PM
    #54
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    OP, I would try again, but this time go in person and ask the front desk receptionist to speak with a dealership manager or even the owner. Make sure to detail your symptoms, explain what has happened so far without being nasty or accusatory. Tell them you request a master tech or other qualified person to ride with you to verify the symptoms. If they cannot reproduce any symptoms, they won’t want to manually check the fluid level because it is a pain to do right, and will want you to pay for it. Let them know that you are afraid it is low on fluid and may have damage going on. If they see you are calm, and reasonable to deal with, they will want to keep a customer. If they still won’t do it, then leave, do it yourself, and never return to that dealer.
  15. Jan 4, 2018 at 5:38 PM
    #55
    Reedld
    Reedld Well-Known Member
    Leon
    Painted Post NY
    2022 DCSB Tacoma Army Green TRD Sport
    My wife's venza has no dipstick, no issues 110k miles. All makes are going this route, nothing to do about it. I bought a Tacoma (long time V8 Chevy truck owner) solely on the build quality of my wife's venza and Tacoma's resell/build quality. My 2016 v6 limited was used but only 25k miles. After owning it a few weeks I noticed the hesitation from P to D and R to D. Years of working on cars (shadetree..not a pro) I thought "low tranny fluid". After finding this site, I read about the TSB. The TSB did solve my issue. The service writer at Toyota was not willing to manually check fluid level...said the computer said it was ok. I was upset but I let it go for now. I didn't bring paperwork proving I knew proper method of checking fluid. I am experiencing no other tranny issues like slipping, hard shifts etc. If I did after the TSB reflash, I'd be going to corporate too. Heck, even a private tranny shop for advice/service. Tranny fluid needs to be checked while its temp is "in range". Fluid level expands and contracts based on temp. My question, if those who found it a quart low, could it be temp related? Was it slightly too warm? It's tough to guage...again I am with 99% of the owners here. I want a dipstick!
    All I all, I really like my Tacoma. It's not as big and doesn't growl like my previous trucks.
    Really like this site, lots of great people with real life feedback and tips.
    Leon
  16. Jan 4, 2018 at 6:27 PM
    #56
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    Take it to another dealer and ask nicely.
