Dealer refused to disable sest belt beep
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stump jumper, Jun 21, 2014.
  1. Jun 21, 2014 at 9:01 PM
    stump jumper
    stump jumper [OP] Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    This was after service manager said he would. Not happy with them. I need to get a shock replaced under warranty and I am going to give them one more chance. I am going to point out the fact that the owner manual states that it is customizable.
  2. Jun 21, 2014 at 9:05 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats my one beef with toyota is the lack of consistency between dealers and your experience.
    Go to a different dealer in the area.
    I will be turning off the seatbelt beep soon on my own via my ELM327.
  3. Jun 21, 2014 at 9:05 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They don't have to, and they can be held liable if they do and the vehicle is involved in an accident. They occasionally do it as a favor to those that ask.
    But if the manager said that he would, then direct the servicing tech to the manager that said that he would.
    My manual does not say anything about it being customizable.. can you post a picture of the page?
  4. Jun 21, 2014 at 9:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Can Torque do that, or do you have to do it manually?
  5. Jun 21, 2014 at 9:12 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I don't see anything about it being customizable, and I thought it was against the law for them to do that??? Or, on the least, there are serious liabilities and ramifications if you crash and don't have your seatbelt on and it comes up that they disabled the chime.if that's the case, it's a little unrealistic to assume they don't care about your vehicle or satisfaction. I know when I was in service, we had customers asking us to turn off door chimes, seatbelt chimes, airbag lights, tpms lamps, etc... We could not do it. Period. And some people became obnoxious, nasty and disrespectful with us.
  6. Jun 21, 2014 at 9:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    A lot of TW members have had their dealers do it, so I can understand if someone has the impression that they are supposed to do it on request.... but dealer service runs the gamut from great to horrible.
    Like another thread where the dealer REFUSED to change the oil at 5000 miles on a '14.
  7. Jun 21, 2014 at 9:17 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Yup, i am thinking that it is against the law also. Since it has to do with safety, they might want to not mess with the system.
  8. Jun 21, 2014 at 9:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Just wear your seatbelt , problem solved
  9. Jun 21, 2014 at 9:20 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    You can turn it off yourself. There are instruction on turning the beep on/off on the forum here. Takes 15 seconds
  10. Jun 21, 2014 at 9:21 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    good lord
  11. Jun 21, 2014 at 9:23 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Quit whining and just do it yourself...
    Seatbelt chime disable
    -Turn ignition to "on"
    -cycle trip reset button until it reads "ODO" turn ignition off and wait a couple seconds
    -make sure seatbelt is not fastened
    -turn ignition back on, when dash lights up hold reset button for 12 seconds, fasten seat belt, ODO should show "b-on" press again to show "b-off"
    -turn ignition off and unfasten seatbelt
    Edit: nevermind-
  12. Jun 21, 2014 at 9:24 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    good gosh...turn it off
  13. Jun 21, 2014 at 9:24 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    my dealer did it without question. as you pointed out, it's mentioned in the owner's manual. because of this it is appropriate to believe it should be done without static. OP, sounds like your dealer is dishing out some bullshit. if you start a petition describing them as assholes i will gladly sign it. try another dealer i guess.
  14. Jun 21, 2014 at 9:25 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i don't think this works on 2012+ but i could be wrong.
  15. Jun 21, 2014 at 9:26 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I disabled mine on my '09, not so I couldn't wear my seat belt, but so my dog or backpack don't set off the alarm on the passenger side.
    I don't understand how it could be a liability on the dealer since they can't make you wear a seatbelt and chime eventually goes away. So the excuse is you need an alarm to remind you to wear a belt?
  16. Jun 21, 2014 at 9:29 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    You can't do it yourself on the newer models. But what is this about using the elm327?
  17. Jun 21, 2014 at 9:42 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It doesn't work on all models prior to 2012
    It doesn't work on any models after 2012
  18. Jun 21, 2014 at 9:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Doesn't work on 2012+
    Doesn't work on my '08 RC
  19. Jun 21, 2014 at 9:49 PM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    There is a missed step in that procedure, I think you do a 10 count in the middle and plug in belt. Worked fine on my 08 AC. I wear my seat belt religiously on road, but don't like the stupid chime for when I'm driving around at work or on my property
  20. Jun 21, 2014 at 9:53 PM
    JLink
    Josh
    Ocean, NJ
    [QUOTE="OldManTan";8818303]There is a missed step in that procedure, I think you do a 10 count in the middle and plug in belt. Worked fine on my 08 AC. I wear my seat belt religiously on road, but don't like the stupid chime for when I'm driving around at work or on my property[/QUOTE]
    Well that's how I've been doing it for 4 years.
