Dealer rip off?
Discussion in 'Technical Chat' started by YoTaco18, Apr 5, 2014.
  1. Apr 5, 2014 at 12:35 PM
    YoTaco18
    YoTaco18 [OP] YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    17" steelies, 33" Mickey Thompson ATZ, Custom made Grill insert with matched paint, 3" Front, Add-a-leaf Rear Dipped Badges, Running Boards, Pioneer Head Unit, Custom 12" sub enclosure
    So I have my 06 taco at the dealer right now. I was hearing chirping/squeaking noise while accelerating on gas from under truck. Did some research and guess it could be u joints or carrier bearings.
    Just got off phone with mechanic at dealership and he said its not the u-joints or the carrier bearing but the drive shaft itself.
    He said there is a shaft within the shaft making the noise and wants $1025 to replace it!!!!
    Any thoughts
  2. Apr 5, 2014 at 12:37 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    So, how much is just the driveshaft?
  3. Apr 5, 2014 at 12:38 PM
    YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    think he said around $800 something
  4. Apr 5, 2014 at 12:41 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Personally, if the truck runs ok I'd get it the fuck out of there and get a second opinion from another driveline shop before doing anything. Don't quote me on it but I think if you remove the four rear u-joint bolts you can drop the shaft down then separate the front and rear pieces and lube the shit out of the splines and put it back together with new joints and center bearing for maybe $300 in parts. That's without labor.
  5. Apr 5, 2014 at 12:43 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Shaft inside the driveshaft? Sounds like a slip yoke that needs grease?
  6. Apr 5, 2014 at 12:44 PM
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
  7. Apr 5, 2014 at 12:46 PM
    YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    yea thats kinda what i was figuring. From reading stuff on here I kinda felt like he was trying to rip me off. I'm going to try to grease the u-joints first to see if that helps.
  8. Apr 5, 2014 at 12:47 PM
    YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    i have an 06 with 69,000 miles
  9. Apr 5, 2014 at 12:49 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Grease is the word, is the word, is the word, is the word. ;)
    I'd try that before applying Vaseline to your balloon knot for the dealer.... just sayin'.
  10. Apr 5, 2014 at 12:54 PM
    hitmans.army
    Myrtle Creek, OR
    Grab the shaft near the u-joints and push/pull up/down/side to side/forward and back. Check to see if there is noticeable movement or clunking. Do the same at the carrier bearing and see if there is any separation of the rubber. Does your driveshaft have greasable u-joints? If so, do this BEFORE putting grease in as the grease may make it hard to tell. If it is just chirping, I doubt you will notice much movement, but its good to check.
    If you don't want to do that, atleast get a second opinion from another shop.
  11. Apr 5, 2014 at 1:01 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Sounds like another dealer that doesn't want to change out joints to me. Unless the slip yoke is so shot the shaft is wobbling, or a weld/tube/yoke is cracked, you shouldn't have to buy another one.
    Looks like there's quite a few driveline shops that carry Spicer parts around Tampa, I'd call around, might be one kind enough to help with diagnostics
    http://www2.dana.com/expert/wc.dll?hvtss~spicerparts~locatea_ld
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/323396-rebuilt-driveshaft-doesnt-need.html
  12. Apr 5, 2014 at 1:02 PM
    YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    thanks guys I'm definitely not having them do it. To top it off I just called them and told him I wasn't going to do the work and he said they are closed for the day so now I have no truck tonight!
    I'll try everyone's suggestions first.
    Beyond Pissed.....
  13. Apr 5, 2014 at 1:08 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Don't be pissed. You've got 1k. Order in dinner tonight.
  14. Apr 5, 2014 at 1:11 PM
    YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    haha true
  15. Apr 5, 2014 at 1:14 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    prerunners dont have greasable u joints,unless you already changed them out for greasable ones...
    also just to change out all the ujoints out here in cali at this drive line shop its like between $150-200 parts/labor
    so yea youre getting fucked
    also, the only "slip yoke" prerunners have is the one that slides inside the rear of the transmission shaft.
  16. Apr 5, 2014 at 1:45 PM
    YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    well I wont be greasing them then haha. Ill just get another look at a different shop. Thanks
  17. Apr 5, 2014 at 1:52 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    yea man, search the web for places with good reviews. i did and found one like 5-6 miles away. great shop!
  18. Apr 5, 2014 at 2:00 PM
    File IFR
    Central MA
    Don't say that too loudly, BamaToy will flip out and go off on you. :D
  19. Apr 5, 2014 at 3:12 PM
    iroh
    michigander
    tonneau
    Still way better than the dealer! They'll want over $200 just for the joints, not including labor.
    Either things are way cheaper here or I just lucked out and found a great shop. Labor for all three joints, install center bearing, grease slip yoke, rebalance, and paint.... less than $60
    Forgot the prerunners had the solid shaft... yeah there should be no reason for it to need changing unless it went rock bouncing.
  20. Apr 6, 2014 at 11:26 AM
    YoTaco18
    Jon
    Tampa Florida
    06 SR5 PreRunner
    Got my truck back havent taken it to another dealer yet cause its sunday but i did get under the truck and grabbed both sides of the driveshaft around the carrier bearing and can move the drive shaft up and down an sideways within the carrier bearing. The rubber isnt falling apart. The is no movement at the ujoints.
