Dealer said this screw was not pluggable - skeptical?
Discussion in 'Wheels & Tires' started by Scud, May 11, 2020.
  1. May 11, 2020 at 1:01 PM
    Scud
    Scud [OP] Well-Known Member
    Chicago
    2018 Cement DCSB TRD Sport 4x4
    Heard a ticking while driving with the window down, pulled over, and sure enough I had a screw in the rear driver's side tire. Stopped by the dealer and he said they couldn't plug it because it was too close to the sidewall.
    I'm a bit skeptical and the tire isn't leaking air so I'd told him I'd bring it back on my day off. What do you guys think based on the picture?
    https://imgur.com/a/x9foYUN
  2. May 11, 2020 at 1:03 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    easy fix. most tire places/dealers don't want to plug anything close to the sidewall
    whatstcp likes this.
  3. May 11, 2020 at 1:09 PM
    t0nyvalenzuela
    t0nyvalenzuela Well-Known Member
    2019 Tacoma TRD OR DCLB
    Puck level
    If you have a tire repair kit, use the strips and some glue and drive a bigger screw with a fat head. That’s what we do on job sites.
  4. May 11, 2020 at 1:11 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    If you have a local fire stone they'll do it for free.
    t0nyvalenzuela likes this.
  5. May 11, 2020 at 1:24 PM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Put soapy water on it before going to the trouble of taking it anywhere. If no leak, pull it out. Check with water again.
    That's patch-able and plug-able. Most places wont patch it because if the nail/screw is long enough, it could have rubbed/poked a hole somewhere inside on the sidewall. They just don't want to be responsible. But someone who knows how to patch can make that last as long as the tire.
    Dont keep driving on it. It might be just barely long enough to not puncture the inside layer of rubber. If you keep driving, it will work it deeper, then causing a leak. Looks like small machine screw. betting to short to go through.
  6. May 11, 2020 at 1:27 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Really?
    I had a tire with a similar nail placement as the OP, and Firestone would not patch it for liability reasons, and insisted on purchasing a new tire.
  7. May 11, 2020 at 1:36 PM
    BalutTaco
    I have not personally done it myself. But my buddy has.
  8. May 11, 2020 at 1:41 PM
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    Same with Discount Tire
  9. May 11, 2020 at 1:51 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    There is zero upside for them to repair your tire. Meanwhile there's about 120 reasons for you to patch it yourself. A 'nicer' tire repair kit at your local auto parts store is super cheap and it'll take a few minutes to repair.
  10. May 11, 2020 at 3:22 PM
    Scud
    Chicago
    Thanks for the replies, fellas. Stopped at a Firestone and he said it was right on the edge of it being too far to the outside of the tire for them to repair. It was too late in the day for them to try to work on it today so I'll deal with it when I'm off shift in a couple days. Not putting more than 5-10 miles on it before then. Might be a good time to upgrade to some KO2s
  11. May 11, 2020 at 3:30 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I just plugged one in the same spot on my RAM, didn’t want to bother with the tire shop so I plugged with the arb kit I keep in the recovery bag. Patches work well but a plug is fine.
    Shellshock likes this.
  12. May 11, 2020 at 3:32 PM
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    ColoradoTJ likes this.
  13. May 11, 2020 at 4:45 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    I have the similar Stop & Go 1075, which has successfully patched everything I've thrown at it.
    https://www.amazon.com/Stop-Go-1075-Standard-Plugger/dp/B0018EUDHW
    I like yours, because it has 2 plug sizes, and includes cement.
    ColoradoTJ and gabbo2112[QUOTED] like this.
  14. May 11, 2020 at 6:07 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Plug by itself doesn't seal the inner liner.
    Patch by itself doesn't fill the void.
    Firestone uses a patch-plug combo requiring <1" be ground off the tire for proper adhesion. Patch-plug should not be exposed to deflection forces.
  15. May 11, 2020 at 8:18 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I have plugged dozens of tires with just the goopy string and rubber cement plug kit and never had one fail.
  16. May 12, 2020 at 4:27 AM
    splitbolt
    NW Arkansas
    I don't know if that's directed toward me or not; but I'll take the opportunity to explain why I said, what I said.
    There are reasons 'they' won't patch near the sidewall, beyond liability or a new tire sale.
    Nothing I posted is factually incorrect, nor did I claim failure is imminent with a plug kit. I'm just trying to take the edge off of some of the skepticism.:)
  17. May 12, 2020 at 4:39 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If it was me, I would just plug it and be done
    Bagman likes this.
  18. May 12, 2020 at 4:45 AM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    I’ve also plugged many tires with success. If it were mine, I’d plug it and keep rolling. Tire shops don’t want to do it because they are worried about liability in the sue happy society we live in now.
    Bagman likes this.
  19. May 12, 2020 at 4:50 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That is borderline. A lot of independent tire stores would do it. A lot of bigger chains won't.
    I keep a set pf plugs, tools, and an air compressor in all of my vehicles and plug them myself. I've done many over the years. There have been several times when the tire couldn't be saved, but the plug held air long enough to get to a tire store and I let them do the dirty work.
    At that location I'd plug it myself and go with it.
    In&out likes this.
  20. May 12, 2020 at 4:51 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I once plugged a tire myself and then took it to a Mr Tire to do a proper job. They told me normally they won’t fix a tire if a customer has plugged it. I knew the guy though so he did me a favor. That repair job they did has held for well
    over a year, whereas the plug still let out a very small, slow leak.
