Dealer says I need to replace both catalytic converters.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dkelley, Nov 11, 2017.
  1. Nov 11, 2017 at 7:38 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    3 points of emphasis..
    Misfires ruin catalytic converters. That is why the cel flashes when you have a misfire it is trying to get your attention.
    Some codes are vague, P0420s are not vague. That is the last code the manufacturer wants to see pop up because if it's under 8/80 they have to warranty the cat. The PCM is going to exhaust every last possible test of the coolant temp, the oxygen sensors, etc before it finally sets the code. If it had an oxygen sensor issue it would have oxygen sensor codes. If it had a coolant temp or thermostat issue it would have a P0 128 thermostat regulating temp code. The only thing to really check is any air leaks getting into the exhaust
    Lastly, this should absolutely be covered under warranty 100%. I would get a 2nd opinion from an independent shop or /and a 3rd opinion from another dealer and then demand that the dealer cover this.
  2. Nov 11, 2017 at 7:41 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    That a dealer would even recommend that this be a "customer pay" item without extensive proof as to why it's not covered under the 8/80 says a lot about the dealers staff and integrity over all.
    burlyb and Muddinfun like this.
  3. Nov 11, 2017 at 7:52 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Why is he asking the question if he is under warranty? Why would dealer quote him if under warranty?
  4. Nov 11, 2017 at 7:53 AM
    Pigpen
    Dan
    Northwest Montana
    Do you have a short daily commute? Not fully heating up the engine and cats on a regular basis will clog and kill your cats. Make sure to go for a half an hour drive a couple times a week.
  5. Nov 11, 2017 at 8:32 AM
    Taco'09
    Taco'09 Well-Known Member
    ^^^ X10
    OP, if you have bad cats and warranty refuses to replace them do this:
    1. Determine why they are bad, ie. missing, bad gas, etc. mentoned above and fix problem.
    2. Don't let the stealership touch your truck, especially to the tune of $2300.
    Do it yourself for pennies by rejuvinating them:
  6. Nov 11, 2017 at 8:40 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I can’t think of a reason why the warranty would be refused.
    It’s federally mandated, unlike the rest of the warranties.
    inwood customs likes this.
  7. Nov 11, 2017 at 8:53 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    if the dealer says they are bad have them replaced under warranty then even if they weren't bad you got a brand new set for nothing out of your pocket.
    Muddinfun likes this.
  8. Nov 11, 2017 at 11:55 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Check your gas cap,too make sure its on tight,and is in good shape,my trac light came on also,and it was a bad fuel cap.Read your codes yourself,I would not trust Toyota.
  9. Nov 11, 2017 at 12:15 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Is it possible the stealership thinks U R a idiot and would like to give them $2300 ? Just tell them to replace for free under warranty and watch their story change or if U did something stupid and ruined them then get them 4 free anyway.
  10. Nov 11, 2017 at 1:33 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Because the dealer would rather have the customer pay rather than Toyota, it pays more. The cats are covered under the 8/80,000 mile emissions warranty.
    JayRolla[QUOTED] likes this.
  11. Nov 11, 2017 at 1:43 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    from what i understand, as long as you can justify WHY, Toyota Warranty pays the dealer pretty well, How the dealer pays the tech for a warranty claim is another deal (in the GM world, techs get SCREWED HARD on warranty repairs). Thing is Toyota warranty will recall the parts and if the repair isn't justified, they will deny the claim. THAT is what makes this a jenky deal in this case. They wanna replace, but aren't confident enough to claim warranty ? "Eh, Maybe the customer will swallow and we'll be golden."
    Maybe they should do some real diagnostic work (its hard, and time consuming, easier to try and hump the customer)
    balljoint likes this.
  12. Nov 11, 2017 at 1:54 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    not at all
    they can last 200,000 miles or more
    the sensors (o2) that can throw a code usually last 120,000-140,000 miles or so
    sum ting wrong here,
    koditten likes this.
  13. Nov 11, 2017 at 2:05 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Your check engine light would have to be lit for months, even years to cause the cats to fail. Operating with a CEL present means your truck has been running in open loop since the light came on. 1 day is not going to fail the cats.
    "Open loop" is similar to operating with the choke on. Excess fuel is making its way to the cats and over loading them. 1 day won't hurt anything.
    You need to find another dealer.
    Lucifer1 likes this.
  14. Nov 11, 2017 at 3:34 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    It's always easier to get more money out of the customer. When the customer pays the dealership has the money the day the vehicle leaves. There are no warranty claims to submit, no parts have to be sent back, no discrepancy on the work and you can always get more from the customer. There are some recall claims that are done that pay absolutely nothing close to what it takes in the real world. It's always better to get the customer to pay if your a dishonest dealership.
  15. Nov 11, 2017 at 5:15 PM
    #35
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Cats do go bad eventually. If they are saying they need replacing and its covered by warranty, let them replace them and start your clock over. At least you'll know you arent paying out of your pocket for many more years to come.
  16. Nov 11, 2017 at 5:20 PM
    #36
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    If the dealer says you need cats then have them put in under warranty and when they say they are bad tell them that it is under the 80k warranty and force them to do it for free
  17. Nov 11, 2017 at 6:07 PM
    #37
    koditten
    Kirk
    Central Michigan
    Make sure you tell them you keep the old ones. The tweakers get huge money for old cats, you might as well get something out of the deal.
    Seriously, get another estimate. There is no way the cats are bad.
    I generally defend dealerships, but when shit like this happens, I get irritated.
  18. Nov 13, 2017 at 4:49 AM
    #38
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That is an awesome solution!
  19. Nov 13, 2017 at 6:45 PM
    #39
    Jlarso01
    Jlarso01 Well-Known Member
    Jim
    Clearwater, Florida
    2015 Tacoma double cab 5' bed
    None yet
    I would wager the dealer would change his tune when you told him they were covered under the warranty and you wanted them replaced under the warranty. Sounds like they are trying to make a little extra money to me.
