Dealer says I need to use a machine when doing brakes - otherwise there will be vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Jan 22, 2020.
  1. Jan 22, 2020 at 4:47 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    Brake job at the dealer is $350. I said I’d do it myself, then the salesman said they use a machine that prevents vibration of pads after installation. Has anyone had their brakes vibrate on them after install?
    wilcam47 likes this.
  2. Jan 22, 2020 at 4:49 PM
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    No. I've never had a set (on any vehicle) vibrate after putting new pads in. Just make sure your rotors are in good enough shape or else change those at the same time. Are they talking about resurfacing your rotors?
  3. Jan 22, 2020 at 4:49 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    how many miles on the rotors?
  4. Jan 22, 2020 at 4:49 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Hes refering to them using a lathe to resurface the rotors. New rotors does the same thing. Or if youre not having any vibes right now, you would most likely be fine to slap some new pads on with your old rotors.
    The vibration would be felt in the steering wheel while braking.
    I will admit, that is a good sales pitch that probably works on a ton of people.
  5. Jan 22, 2020 at 4:50 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If you’re installing new rotors and pads, just do a search for proper breakin procedures.
    There is no “machine” unless they’re talking about resurfacing older rotors.
    Dominic4Lo and wilcam47 like this.
  6. Jan 22, 2020 at 4:51 PM
    eon_blue
    Azusa, CA
    Just buy new rotors if you do it yourself, rotors are relatively cheap...no sense in resurfacing old ones
  7. Jan 22, 2020 at 4:52 PM
    BillsSR5
    bill
    2014 SR5
  8. Jan 22, 2020 at 4:52 PM
    Marek71
    Marek71 Well-Known Member
    2019 TRD Sport DCSB
    It sounds like they are talking about resurfacing the rotors, warped rotors would be what would cause a vibration in the brakes.
  9. Jan 22, 2020 at 4:54 PM
    Cutter_
    Thanks for everyone’s input. I have new Wagner pads from Pep Boys but I’m going back to get new rotors too
    cruiserguy and jbrandt like this.
  10. Jan 22, 2020 at 5:21 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i had to call the dealer service on something like that once
    told me my 3rd brake light was out and wanted 20-30 to replace the bulb, i have changed exterior bulbs before and could readily climb up there to fix it so i told them to show me.
    she walked me out and them hit the brakes and the 3rd light was working :facepalm:
    whatstcp[QUOTED] likes this.
  11. Jan 22, 2020 at 5:22 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    can you not just take the rotors in somewhere to get them resurfaced?
  12. Jan 22, 2020 at 5:23 PM
    eon_blue
    Azusa, CA
    Rotors are cheap...standard Wagner ones are like 40 or 50 bucks for a new pair and they just slide right on. Way easier to just put on new one's imo.
    cruiserguy and Seagull233 like this.
  13. Jan 22, 2020 at 5:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    oh ok, i thought they were as much as rear drums are, like a whole lot $150ish for retail non-wholesale
  14. Jan 22, 2020 at 5:26 PM
    eon_blue
    Azusa, CA
    You can buy really expensive ones...drilled, slotted, etc. For our trucks I don't think it's worth it, just a standard set and replace whenever it's time to do your brakes
    cruiserguy, gilligoon and wilcam47 like this.
  15. Jan 22, 2020 at 5:43 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Sometimes resurfacing the rotors is called "machining" the rotors. Also heard it called "turning" the rotors.
    Gunshot-6A, cruiserguy and wilcam47 like this.
  16. Jan 22, 2020 at 5:59 PM
    Cutter_
    Off topic, but when replacing plugs + wires, do I need to do the distributor cap/coil packs at the same time?
  17. Jan 23, 2020 at 6:43 AM
    omarq
    omarq Well-Known Member
    o
    1999 Tacoma Extracab
    17" wheel
    Dont machine unless there's a current vibration problem or you have grooves in your rotors. Make sure and bed the brakes after the brake job.
    Gunshot-6A likes this.
  18. Jan 23, 2020 at 6:45 AM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    I'm surprised no one has mentioned they were probably talking about machining the rotors.
    slander likes this.
  19. Jan 23, 2020 at 6:54 AM
    BillsSR5
    bill
    2014 SR5
    Cutter_[QUOTED][OP] likes this.
  20. Jan 23, 2020 at 6:57 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Dealers almost always lie about what you need, mark things up substantially and use their slime-ball sales tactics to pressure you into doing things. Brake jobs usually cost quite a bit anywhere. If you can do them yourself you can save a lot of coin.
    Gunshot-6A, wilcam47 and GQ7227 like this.
