Dealer says I need to use a machine when doing brakes - otherwise there will be vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Jan 22, 2020.
  1. Jan 23, 2020 at 7:01 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  2. Jan 23, 2020 at 7:13 AM
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    When I was a little guy, my parents used to get their Chevy Caprice serviced at the dealer. Every year or two they would say your "idler arm" needs to be replaced for $150 or so... so they did it. When I got to HS age I wondered what an idler arm was... it was literally a small metal arm that served as a pivot arm for your steering... no torque on it, it doesn't really wear out at least not at 1 year intervals...
    Some of the BS just makes me :facepalm:
    cruiserguy, Kpatt9 and wilcam47 like this.
  3. Jan 23, 2020 at 8:16 AM
    Indy
    Indy Master of all I survey.
    As long as the rotor is in spec and not distorted to start with, they done need machined. A little sand paper work and youre good. By the time they do need machined, just buy a new set. They're only slightly more expensive than machine work.
  4. Jan 23, 2020 at 8:57 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Did you not see the 6 or 7 posts before yours that talked about machining the rotors?
    Starting with literally post #2...
  5. Jan 23, 2020 at 9:05 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Some people just dont know any better...
    GQ7227 likes this.
  6. Jan 23, 2020 at 9:06 AM
    wilcam47
    Will
    Bourbon state
    this...i tried it once on a honda i had. Vibe came back really quick. Replaced rotors and didnt have ay issues
    cruiserguy likes this.
  7. Jan 23, 2020 at 9:11 AM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    Yep, I saw it, but I guess the other 5 or 6 didn't. I was just being a shit head.
  8. Jan 23, 2020 at 9:14 AM
    jbrandt
    Justin
    So was I...
    :anonymous:
    :D
  9. Jan 23, 2020 at 12:38 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I really can`t fault service writers for pushing what they are told to sell.
    I don`t know anyone that even still cuts rotors just replace .
    wilcam47 likes this.
  10. Jan 23, 2020 at 1:06 PM
    jbrandt
    Justin
    When mechanics don't even want to press out some control arm bushings, and instead sell the customer a whole new set of control arms, I'm not surprised they don't cut rotors.
    I'm sure they still have the equipment, but they'd have to dust it off and get one of the "old timers" to run it for them.
    At a certain point, they're parts replacers, not technicians.
    Gunshot-6A and wilcam47 like this.
  11. Jan 23, 2020 at 1:09 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    You can get a rotor and pad kit from rock auto for $150. Did Centric rotors and pads @100k opted for the corrosion coated rotors that wont rust.
    The dealer wants to resurface to rotors for you. Then install pads. IMO I'd just replace both an call it a day.
  12. Jan 24, 2020 at 9:23 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I had mechanic telling me that the that throttle body needs to be cleaned because the butterfly valve is sticky. I asked him to walk me to the car and show me. At first he did not want, but I told him just show me and I'll pay whatever he will ask for the job. To his embarrassment he could not find the throttle body because it was a diesel engine. I called his bullshit, and he felt miserably. Some mechanics are just assholes.
  13. Jan 24, 2020 at 9:25 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Lawfarin and CS_AR like this.
  14. Jan 24, 2020 at 9:27 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    That's awesome. You should have asked him to change the spark plugs while he was in there. :cookiemonster:
  15. Jan 24, 2020 at 9:57 AM
    #35
    RysiuM
    Rysiu
    That's dangerous. He might charge me for glow plugs instead. Plug is a plug, right?
  16. Jan 24, 2020 at 10:47 AM
    #36
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    HahahahahahhahahahahhaHhHAhahah:rofl: you, my good man, just became my hero!:cool: seriously, good for you. Hope these assholes without a moral backbone(ex.: it's my job to lie to customer to sell them stuff they don't need.... Then get a job where you don't have to be dishonest every day you work, could you imagine how that kills your true self esteem or self worth, saddest part is they don't realize how much that affects your mind and perspective) learn their lesson
  17. Jan 24, 2020 at 10:55 AM
    #37
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    They may have some kind of runout machine they have either bought or made. Basically, just checking for warping. It's done at the plant on the new hub assemblies using a laser, but old timers used to use a setup like this:
    dial indicator on a flexible arm or some type of mount.
    https://www.brakebleeder.com/how-to-measure-rotor-runout/
    wilcam47 and cruiserguy like this.
  18. Jan 24, 2020 at 11:13 AM
    #38
    RysiuM
    Rysiu
    This is even better. Because it was my son's car (you all know what I think about diesel) I did turn on my cell phone camera and got the whole conversation (including walking to the car and "inspecting") on the video. Unfortunately it is all in Polish, so no value here ;). He still tried to safe his face buy saying "Sorry, this particular car does not have it, but most od diesel cars have throttle body" looking at the engine with disbelief (see picture below). For privacy I pixelated his face. Poor, stupid dude.
    wilcam47 and cruiserguy[QUOTED] like this.
  19. Jan 24, 2020 at 11:16 AM
    #39
    cruiserguy
    Elijah
    SEKS
    :rofl::rofl::rofl:
    Scammers beware! We're turning the tables on ya! :cool:
  20. Jan 24, 2020 at 11:23 AM
    #40
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    They did mean resurfacing the rotor.
    They actually have a special lathe which can machine the rotor while it is still on the car.
    This actually saves alot of labor on some cars like the LX470 and the vehicles with solid axles etc.. where it takes more time to remove the rotor.
    On the tacoma, the rotor pretty much falls off after you remove the wheel (or give it a good tap with a mallet if rusty etc..)..
    The rear is only harder cause of the parking brake, but still pretty easy overall especially if you are servicing the parking brake.
    On those other cars, you have to remove several bolts, the axle nut, and then it comes off with the bearings and has to be regreased and reinstalled etc...
    So it is pretty common for them to turn them when its in for a brake job, cause these cars are so heavy if it did't warp on the first set of pads, they will warp on the second set of pads at some point.
    On our cars its easy enough to just replace the rotors, so I would just get aftermarket rotors and ask them to install those.
    Then you have fresh rotors and it won't be as expensive. or just roll on your current ones till they start to have issues.
    lots of options!!
    pic of the on wheel lathe for an 80 series
    https://forum.ih8mud.com/threads/on-car-brake-rotor-resurfacing.122154/
