Dealer says lift kit he installed CANNOT BE UNDONE!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Oldbuzzard, May 14, 2019.
  1. May 14, 2019 at 12:42 PM
    Oldbuzzard
    Oldbuzzard [OP] New Member
    Oldbuzzard
    2019 Tacoma Ltd
    Brush guard, lift kit, exterior appearance accessories.
    Picked up brand new Tacoma Ltd last week. This was my first Toyota truck after driving Nissan trucks and SUVs for years. When picking out accessories the dealer said he could install a two inch or four inch lift kit. I went with the four inch. When I picked up the truck it sat too high so I said I wanted to change to the two inch kit. The Accessory Manager said he could not change the lift and it would forever have to be what it is. I can't believe that. I don't know where/who made the lift kit he used. Can anyone give me some advice?
  2. May 14, 2019 at 12:43 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Aloha, and welcome to TW! :wave:
    Pics of the lift components? I am guessing they are either full of shit, or did some sort of drop bracket fuckery.
    Biscuits, Kpatt9, TheGoat and 14 others like this.
  3. May 14, 2019 at 12:44 PM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    If it was a drop bracket lift that was installed then the frame is cut in order to accommodate for the steep cv angle (if 4x4). If this is what was installed, it might not be possible to undo...
  4. May 14, 2019 at 12:44 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Odds are for the 4 inch lift they had to cut out the old cross member up front and weld in a new one. So yes, it cannot be undone
    Fluffymonkey, mjp2, paleh0rse and 6 others like this.
  5. May 14, 2019 at 12:46 PM
    Anchovy
    TRD Ferguson
    Realistically it’s their fault for not telling you what had to be done and that once on, the 4 inch lift cannot be undone. Although the 2 inch lift would be easy to undo since it’s most likely just blocks
  6. May 14, 2019 at 12:49 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    You can undo any lift including DB. Have welder will travel. :)
    Biscuits, walterj, TRDBROPRO and 29 others like this.
  7. May 14, 2019 at 12:49 PM
    eon_blue
    Azusa, CA
    It can be undone but you'd have to get a new crossmember welded to the frame where the original was cut off...people have done it. But I can see why a dealer won't
  8. May 14, 2019 at 12:51 PM
    tAcomaPueblo
    tAcomaPueblo Well-Known Member
    Virginia Beach, VA
    2017 Tacoma TRD OffRoad 4x4 DCSB
    Steal a new tacoma and weld off all of the VIN plates from your old vehicle so its technically yours.. I think that works.
    HIYota, 06trdtaco and Arailt like this.
  9. May 14, 2019 at 12:53 PM
    Anchovy
    TRD Ferguson
    Have the dealer do it
    tAcomaPueblo[QUOTED] likes this.
  10. May 14, 2019 at 12:55 PM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    Obviously, without all the details, it's impossible to say for sure. But my guess would be that he's not saying what you want is not doable, he's saying that you said 4", they installed 4" and that they aren't reversing it on their own dime. Understandable if it was a drop bracket lift. However, the last thing I want to do is take a dealer's side, so I would say that you should have been shown examples of each lift before you had to decide.
    BSFord, rmorse, Chew and 3 others like this.
  11. May 14, 2019 at 12:55 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    This one is rough country, but all 4-6inch lifts are similar procedures.
    Take note of instruction #30, because you cut out and remove the factory lower control arm crossmember, you can’t revert unless you find a donor and weld factory member back in. 3inches is the highest you can go on a factory 4x4.
    https://s3.amazonaws.com/roughcountry/install/921748200.pdf
  12. May 14, 2019 at 12:57 PM
    eon_blue
    Azusa, CA
    I assume you got bigger tires put on with the lift, easiest way to lower the truck would be to get smaller tires
    TRDBROPRO, Toki, paleh0rse and 6 others like this.
  13. May 14, 2019 at 1:00 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Time for some big ass tires
    Chew likes this.
  14. May 14, 2019 at 1:01 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Neither of those dealer options are great. 4 inches seems too high, 2 inches would likely be blocks.
  15. May 14, 2019 at 1:01 PM
    Inferno!
    El Dorado Hills
    I would simply weld in the cut out portion, add gussets and be done with it.
  16. May 14, 2019 at 1:12 PM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    Chances are there are several things at play here: the most important being time and money. The dealer just spent 8-10 hours installing a 4” lift, which has real costs in parts and labor. Asking to undo it and installing a different lift involves many more hours and many more parts which someone has to pay for. If the lift was part of the deal, it becomes difficult to untangle.
    Per who is responsible: I’d say both the dealer and the buyer. Knowing what I know, I’d never get a lift higher than 2.5 or 3 inches. That’s plenty for what 99% of us want to do out there. Going higher than that starts compromising too many parts, and throwing ride and handling —as well as entry/exit— to shit. For its part, the dealer should have made absolutely certain that the buyer understood well what a 4” lift involved, and really wanted it.
    Where to go from here...? Depends at what stage the deal is. If all the papers are signed and the financing secured...OP, you better find a sturdy step stool...
  17. May 14, 2019 at 1:14 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Waiting to see it on 4 inch blocks lol
    TRDBROPRO, drewhaus, TheGoat and 10 others like this.
  18. May 14, 2019 at 1:15 PM
    eon_blue
    Azusa, CA
    Plus, drop bracket lifts don't really gain you any clearance since the front diff, axles etc remain in the stock location. You get body clearance and it looks way better than a 4" body lift would, but for offroading there's a reason drop bracket lifts aren't very popular
    This really comes down to why it's not a good idea to get accessories and lift kits sold/installed through the dealer. It's all about the money to them and they aren't going to try and educate you on what might be best for your needs, they just want you to agree to it and pay 3 times as much for it as you would elsewhere.
  19. May 14, 2019 at 1:16 PM
    FHC
    FHC Well-Known Member
    Drive it for a year, if you still don’t like it trade it in and get exactly what you want. Life goes on.
  20. May 14, 2019 at 1:17 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    That’s what one might do if they did it at home, assuming you saved it..
    But getting it done at the dealership, I would assume they scrapped it.
