dealer says no alignment necessary?
Discussion in 'Wheels & Tires' started by BuzzardsGottaEat, Feb 16, 2012.
  1. Feb 16, 2012 at 10:12 PM
    BuzzardsGottaEat
    BuzzardsGottaEat [OP] "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Part of the deal for trading up to my new tacoma was a set of wheels and tires. Since I know some of the guys pretty well I asked, since they're putting new wheels and tires on and the tires sensor anyways if they could save me some time and slap in my billys and I would pay labor for that only but not the new wheels/tires and alignment since they have to do that for free anyways. One guy there claims they don't do an alignment on tire/wheel swap so I should pay that too?
    Now is this guy legit or his he just claiming they don't usually do an alignment to get me to pay more?
    More info: They're putting in Mickey Thompson Classic Locks and Pro Comp xtreme all terrains in 265/75r16 (1in. up from stock) shouldn't they align this since its new size, BS, os, and everything or is it too small of a change and he's telling me the truth?
    Just wanna go in educated, thanks.
    P.s. I know dealership labor usually = rape, but what's a range for reasonable pricing to put in four 5100s and a 1.5" 3 leaf progressive AAL because I don't mind doing it myself, I just figured for convenience sake, if they have the tools and the truck jacked up with the wheels off already, why not. . .
    Thanks again guys
  2. Feb 16, 2012 at 10:13 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    He's saying they don't usually do an alignment after installing a lift (assuming you have 5100s set on something otehr than stock)?
    Wrong. Lift changes the geometry of the suspension, an alignment is recommended.
  3. Feb 16, 2012 at 10:16 PM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    It takes less than 20 minutes to align these trucks as long as camber/caster isin't out. No rear adjustment obviously. Just make them do it, tell them to quit being lazy. Not like it will hurt
    anything.
    Alignment isin't free I'm sure, either do it there or just go to Firestone and buy a lifetime alignment for like $149 (align it anytime you want)
    Edit: If the truck is being lifted at all with suspension components, then HELL YES, you need an alignment afterwards.
  4. Feb 16, 2012 at 10:18 PM
    jordando89
    jordando89 Well-Known Member
    jordan
    idaho
    2008 white double cab long bed sport 4x4
    3in lift painted sport wheels
    just got mine on and had to pay for $70 for alignment
  5. Feb 16, 2012 at 10:19 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    Correct, if all they are supposed to do is a wheel/tire swap, no alignment is needed.. So if you are asking them to do extra work (that you are paying labor for) which will require an alignment, then the shop should not have to pay for the alignment.
    Correct?
  6. Feb 16, 2012 at 10:23 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Swapping wheels/tires does not require alignment.
    Adding a lift does. But, if you're throwing 5100's on @ zero setting, none req'd.
    IMO, if you have the means to install it yourself, do it. Then spend the money for an alignment.
  7. Feb 16, 2012 at 10:49 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    This is pretty much all I wanted to clarify, thanks. I didn't wanna be a prick and tell them to give me something free when they shouldn't, but at the same time didn't want to get charged for something they agreed to do anyways. . . Now I know that paying for the alignment is my share. . .
    To clarify just in case some missed it or I want quite clear in the OP.
    Labor for putting in new tires/wheels was already negotiated as free, I was trying to take advantage of the fact that my truck is already jacked up and de-wheeled to get my suspension thrown in cheaper.
    I was supposed to drive away the day of purchase with the new tires/wheels but they made a mistake on tire size that didn't fit my new rims so I'm kind of capitalizing on the fact that it was their mistake that inconvenienced me (driving state to state)
  8. Feb 16, 2012 at 11:15 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    I'd do the same thing if she was in the shop already on a hoist! But as Zac808 said ... if new billies are set at zero, no allignment req'd. Personally ... I would just do it myself, that way the stealership can't charge you for extra shit they pull out of their magic hats,
    "Oh, well we had to replace your muffler, it had a unicorn in there, punching holes in it, and it was shitting in your filters... It'll cost you $99,000, but your truck is safe now"
    <I don't like my local stealership btw>
  9. Feb 17, 2012 at 5:44 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Your comment on not requiring an alignment if the 5100's are set at 0 depends on how they are installed. If they loosen any of the control arm bolts, then you should get it aligned afterwards.
    Otherwise, agreed, swapping wheels are tires on a truck that's already properly aligned would not require an alignment.
  10. Feb 17, 2012 at 5:47 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x2
  11. Feb 17, 2012 at 6:20 AM
    BuzzardsGottaEat
    Chaz
    South Dakota
    Thanks fellas
    My dealership isn't all that bad and we have some history but its nice to go in informed anyways
    Good old tacomaworld :)
