Dealer says rear brakes need adjusting at 25,000
Discussion in 'Technical Chat' started by 10PreRunner, Dec 17, 2010.
  1. Dec 17, 2010 at 12:39 PM
    10PreRunner
    10PreRunner [OP] Well-Known Member
    Kevin
    Knoxville, Tennessee
    2013 SR5 4x4 Double Cab
    Just got back from the dealer to get my 25K mile service and the service guy told me that my rear drums need to be adjusted. I thought drum brakes were self adjusting. He also said that I wasn't using the rear brakes as much because they were out of adjustment. Isn't 60 to 70 percent of the braking done in the front? Please tell me your opnions and thoughts on my rear brakes and could they need to be fixed. Thanks for the help.
  2. Dec 17, 2010 at 12:43 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You have to manually adjust the rear brakes, and yes, it does make a difference.
    It takes a jack, a screwdriver, and 10 minutes to do. You don't even get dirty, so there's really no reason not to.
  3. Dec 17, 2010 at 12:44 PM
    10PreRunner
    Kevin
    So how do you do it and why are they Tacomas not self adjusting like alot of other brands? Most brands all you have to do it back up.
  4. Dec 17, 2010 at 12:52 PM
    mjp2
    NJ
  5. Dec 17, 2010 at 1:00 PM
    10PreRunner
    Kevin
    Thank you so much. I will go out to the garage and try to adjust them.
  6. Dec 17, 2010 at 1:31 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    That is something that is usually done at 15k intervals. It's called a Clean And Adjust rear brakes. And yes sadly our rear brakes are not self adjusting. Wise to have this done and its quite simple to perform. I had done mine recently and found some dirt and debris from the last time I went mudding. Couple of cans of brake clean and the proper tools and your done.:mudding:
  7. Dec 17, 2010 at 1:48 PM
    mjp2
    NJ
    By the way, you're going to be amazed at the improved braking when you're done. The rear brakes do a lot more than people give them credit for. :)
  8. Dec 17, 2010 at 2:39 PM
    10PreRunner
    Kevin
    Thanks to all the replys. I went out to the garage to see if I could do it but couldn't figure our what to do once I took the plug out. I'm gonna take it to a friends garage and put it on a lift so I can see it and get to it a little better. Thanks again.
  9. Dec 17, 2010 at 2:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When I adjust mine, I simply let it idle in Drive, and apply the park brake about 8 - 10 times. Then call it good.
  10. Dec 17, 2010 at 2:53 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You do this AFTER adjusting them, or you do this TO adjust them?
  11. Dec 17, 2010 at 2:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I do that to adjust them. It seem s to work, though what MJP suggests is the correct method.
  12. Jan 5, 2011 at 1:23 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    For what it's worth, my brake pedal was going down a lot more than it should when I applied the brakes, so I decided to bleed the brakes. No joy... I then read this post and decided to check my rear drum brakes by manually adjusting them. Ureka! The driver's side rear was not auto adjusting and I was able to tighten the sprocket by more than ten clicks. Problem solved and the brakes feel great. Thought I would share this with you all.
