Dealer says the solution to my stuttering at low rpm accel is a new tranny... Really? Need guidance
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gtg, Jan 29, 2023.
  1. Jan 29, 2023 at 9:55 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Add Torque Converter locking status to you monitor, you'll be able to correlate its status to the vibration
    More like TC related issue. On stock 2016 ECU,TC locks in 3rd and 4th at low speeds
    Rusty66, RyanDCLB and gtg[QUOTED][OP] like this.
  2. Jan 29, 2023 at 9:56 AM
    gtg
    gtg [OP] Active Member
    2017 Dark Grey Tacoma TRD Offroad
    Dealer said the level was good. No flush, good advice jives with what the dealer said. Conditioner, I will try. Thanks!
  3. Jan 29, 2023 at 9:57 AM
    gtg
    Dealer said TC checked out ok. Likely hard to thoroughly check from outside, would be my guess.
  4. Jan 29, 2023 at 10:00 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    I’d go easiest to hardest.
    1. Try higher octane or different top tier brand fuel
    2. Maybe reset the battery so that ECU relearns
    3. Drain and refill fluid
    All of the above is $100 all in… if it doesn’t help it’ll be a $xxxx repair more likely
    before any sort of additives or voodoo magic tricks
    DougNuts and na8rboy like this.
  5. Jan 29, 2023 at 10:01 AM
    gtg
    Can a private person send to an auction? I found out that Toyota started sending vehicle history to CarFax in ~2020. Thus, the line in my dealer paperwork from my last visit on this issue was "internal transmission failure between 3rd and 4th gear". I think this forces me to get the truck fixed or take a huge hit (likely bigger than a new tranny) on value.
  6. Jan 29, 2023 at 10:04 AM
    gtg
    These transmissions are supposed to be life lubricated. Thus, no ATF changes like my other cars. The truck was maintained at the dealer until 75k. I had a local shop do the spark plugs at 79k, the only service I've had to do to this point besides oil.
  7. Jan 29, 2023 at 10:10 AM
    Vlady
    Issy, WA
    It is debatable.. Change the fluid.
  8. Jan 29, 2023 at 10:32 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Here's a video:
    McHale likes this.
  9. Jan 29, 2023 at 10:51 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    The dealer might be trying to shove a bunch of shit down your throat, I'd get that second opinion from a reputable transmission shop and go from there (if one exists)
    Process of elimination.
    HisDad, kahanabob and Chew like this.
  10. Jan 29, 2023 at 10:51 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Huh, tank replacement too?
  11. Jan 29, 2023 at 10:56 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’d flush the tranny with the Amsoil flush, drain, and refill. What would the reason be to not try this as a last resort before replacement?
    kahanabob likes this.
  12. Jan 29, 2023 at 10:59 AM
    Vlady
    Issy, WA
    Low pressure pump recall. I got a year a so ago. Have not done it.
    What about the tank replacement??
  13. Jan 29, 2023 at 11:02 AM
    OnHartung'sRoad
    Did they replace the tank or just the fuel pump? Some had to pull the entire assembly to do it.
  14. Jan 29, 2023 at 11:05 AM
    OnHartung'sRoad
    gtg[OP] likes this.
  15. Jan 29, 2023 at 11:12 AM
    #35
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Go to another city and another dealership or a good transmission place. Worth another opinion.
    gtg[OP] likes this.
  16. Jan 29, 2023 at 11:32 AM
    #36
    mckgyver
    mckgyver Active Member
    2020 TRD OR silver
    My 2020 TRDOR with 33k miles does this and so does my dads 2020 SR5 with 11k miles. Premium gas seems to help. Ive already checked the fluid level and added a bottle of Lubegard with no effect. It only does it at low rpm, around 1100 to 1500 in higher gears. Could it be tuned to not run at that low of rpm KDMAX guys?
  17. Jan 29, 2023 at 11:35 AM
    #37
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Mine was.
  18. Jan 29, 2023 at 11:38 AM
    #38
    gtg
    Thought about your suggestion already. Came to the conclusion that dealer techs ae experts in possible diagnosis and likely fixes that are lowest risk to the dealer. They are not experts in any specific sub-system. Thus, going to an A/T specialist is in order. However, I started a search for one in the SF Bay Area (South Bay), and no shop stuck out as an "expert". A lot of these places say they are transmission, but they really only do replacements, not deep diagnosis. And, good luck finding a rebuild place... although not likely the best choice for a complicated modern transmission like this.
    REQUEST: If anyone has a suggested shop or shops for me check out in the SF Bay Area, it would be greatly appreciated.
    The other thing that got me thinking... Argh, too much thinking about this. These guys in AZ would be a good choice if they weren't 15 hours away, but these guys suggest not saying anything to mislead a mechanic. https://tricitytransmission.com/abo...y-toyota-tacoma-a750-transmission-service-fix
    Phlogiston likes this.
  19. Jan 29, 2023 at 11:42 AM
    #39
    gtg
    Yes, 1200-1800, low acceleration, exactly the same. It seems based on other posts, this is more common in 2019+. Running higher octane has me still thinking it's a mixture issue. Why? My truck does NOT stutter when the engine is cold. It only starts once the temp gauge gets to the first line. Anyone have thoughts on the cold vs. warm engine behavior?
  20. Jan 29, 2023 at 11:44 AM
    #40
    mckgyver
    2020 TRD OR silver
    It could be part of the tuning. The torque converter may not be in lock up until the temp gets to the normal range. This is done to aid in faster trans and engine warm up times
