Dealer service drive in measures alignment as you drive in?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hobie17li, Feb 23, 2023.
  1. Feb 24, 2023 at 7:45 AM
    #41
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    That's what the dealer told me when my truck was under my first visit with toyotacare that it needed an alignment. They said it was very common in these tacomas that they were sent out with too much toe in for the passenger front wheel. I never was charged anything for it being in what they called the first 10k mile, or 1 year grace period of toyotacare.
    SH10151 likes this.
  2. Feb 24, 2023 at 7:57 AM
    #42
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I gotta admit, that’s pretty slick. The tread measuring and the body damage cameras are great ideas too.
    I’m not sold on it though, I’d wanna see the pre-adjustment specs from a proper alignment machine after that Quick Check machine makes the call on my “out-of-spec alignment”......
  3. Feb 24, 2023 at 11:49 AM
    #43
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Yeah...I'm skeptical too.
    It could only do toe and camber anyway.
    Static alignment is also different than dynamic alignment. How much...depends.
    Big tall dave[QUOTED] likes this.
  4. Feb 24, 2023 at 12:03 PM
    #44
    hobie17li
    hobie17li [OP] Active Member
    DHA
    16 TRD Sport MT quicksand ordered
    It was Riverhead Toyota on Long Island, NY. I am taking my tacoma in for service on
    Monday, but will probably decline alignment if offered
  5. Feb 25, 2023 at 3:37 AM
    #45
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    comes from the bigger ego I believe, even the hoes charge more than they should, "bitch you ain't THAT good!"
    XD
  6. Feb 25, 2023 at 3:43 AM
    #46
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    923C791D-C21D-4DE5-A6E3-6152DF06600F.jpgHave them rotate the air in the tires and don’t forget the spare
  7. Feb 25, 2023 at 7:03 AM
    #47
    Exfordman
    Exfordman Well-Known Member
    Norman
    2021 Tacoma TRD OR 4X4 LB White
    None
    It's all part of Dealers trying to make as much money as possible. We Dealership Techs (Ford) had to do Multi Point Inspections on every car we worked on. The fancy handheld battery tester would fail many batteries. I took it into the parts department and it failed many of the new batteries . I bet these alignment checking machines are similar with very tight parameters.
  8. Feb 25, 2023 at 7:06 AM
    #48
    Bishop84
    Bishop84 Well-Known Member
    We had it, it actually is pretty accurate. The problem is people don't trust it, and would rather have the tech recommend it.
    It cant detect caster or steering wheel position. I usually sell alignments off steering wheel angles and/or tire wear.
    Big tall dave likes this.
  9. Feb 25, 2023 at 7:11 AM
    #49
    Tac2021
    Tac2021 Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Same up here in NH. At the 10k tech said I needed an alignment. It’s a quick $99.99 hit. I declined. My tires looked fine.
