Dealer Throws Off Alignment While Making A Repair
Discussion in '3rd Gen. Tacomas (2016-2023)' started by itz so salty, Oct 16, 2021.
  1. Oct 16, 2021 at 8:37 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Thank you for clarification. I had a squeaky one a couple years back (passenger rear), loosened it up and hit with some lubricant. (Sounded like sheet metal pop). Since then no noises…BUT…winter is coming. :pout:
  2. Oct 16, 2021 at 9:21 PM
    itz so salty
    itz so salty [OP] Well-Known Member
    '21 DSCB OR 4X4
    Sorry, I didn’t think my aftermarket suspension mattered. I do have Bilstien 6112/5160 with SPC UCA’s. The dealer was obviously aware of this when they worked on my truck. There was discussion of whether the work would be covered because of the modification at first, but later given the green light because they are unrelated. Now, maybe the alignment isn’t covered under Toyota because of aftermarket components, but if they made adjustments to it, shouldn’t they still be responsible for giving it back to me how it was?
    Main point of concern is also what many have brought up. There is no reason my alignment should have been thrown off during this fix. I’ll see if they can explain to me exactly what they did and I’ll follow up here. I picked up my truck today and the tech was off, so couldn’t get an answer. Service advisor deferred to his tech, but did tell me the suspension was messed with.
    I had an alignment completed at my local off road shop after the suspension install and they did an absolute amazing job with it. My truck tracked better than stock. I have the alignment specs I can post if anyone is interested.
    There’s really nothing more to the story other than what I’ve posted. Dropped off truck that drove perfect, but made annoying squeaks. Dealer fixed squeaking, but my truck drives like shit. I called dealer and they told me I need an alignment after the fix (doesn’t make sense).
    If dealer makes changes to my aftermarket components, are they not responsible to put it back how they found it?
  3. Oct 16, 2021 at 9:37 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    With dealerships, you almost have to spell it out for them and get absolutely everything understood in writing.....BEFORE....they begin.
    Example:
    You go in for a leaky diff, which should still be covered under warranty.
    Would it be wrong thinking to have them put in writing that if they decide to fiddle with anything else on the truck, that they own getting it back to exactly where it was before they fiddled with it? Or at least call you first and let you know that they might need to fiddle with something unrelated to the prescribed work. At that point you can decide if you will authorize that particular procedure/work, and make it clear that whatever they fiddle with, gets put back to factory specs.
    itz so salty[OP] likes this.
  4. Oct 17, 2021 at 8:43 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Fuckers better fix it. Raise Hell Brother. Good luck :thumbsup:
  5. Oct 18, 2021 at 10:36 AM
    itz so salty
    '21 DSCB OR 4X4
    Well, this is embarrassing, but you all deserve an update. In my defense, I was steered in the wrong direction by none other than the Toyota service advisor.
    I took the truck into my alignment shop this morning and my numbers were unchanged. Immediately, the culprit became apparent and I was able to get it fixed. It was a tire balancing issue.
    Toyota techs didn’t touch my alignment as it was claimed by the service advisor. Maybe he was attempting to sell me an alignment and then further diagnosis to “fix” my issues that would be claimed due to non OE suspension. Or maybe the service advisors don’t really care and are just trying to close cases by throwing random things at them.
    Either way I feel dumb and I apologize to everyone for the unnecessary dramatic post. Happy to have my truck driving normally again.
    5nahalf likes this.
  6. Oct 18, 2021 at 10:38 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    We all make mistakes, thats why they put erasers on pencils.
    Glad you got it all sorted out!
    Aqualoon likes this.
