Dealer won’t fix Wireless Charger. Options?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DD619, Jan 23, 2023.
  1. Jan 24, 2023 at 10:00 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    It is a known issue among TacomaWorld users. I doubt it is much of a concern for Toyota. There has been no Recalls on it...
    https://www.cars.com/research/toyota-tacoma-2017/recalls/
    (Didn't know what year OP has, so I did my own)
    If there was a recall, then there would be an improved part in subsequent model years, there isn't. Also, unless these catch a number of trucks on fire ( re: Canadian Engine Block Heater Recall ) then they will leave it as it is.
    In the meantime, Toyota hopes you enjoy you Qi charger, it was outsource from the rejects of Amazon and Walmart. High quality.
    I used mine once on a trip to Portland, I was bluetoothing music, and the thing kept beeping. It kept cycling from charge, to off and back to charge because the phone battery was full. I shut it off and haven't used it since, that was over 4 years ago. Today, I plan on using the circuit for upgrades, permanently disabling it.
  2. Jan 24, 2023 at 10:05 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
  3. Jan 24, 2023 at 1:36 PM
    DD619
    DD619 [OP] Active Member
    Don
    San Diego, CA
    2020 White TRD OR
    Thanks for all the responses. From what I gathered here I’m taking it out completely and throwing a storage cubby. Anyone have the part # for the oem one?
  4. Jan 24, 2023 at 1:44 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
  5. Jan 24, 2023 at 1:55 PM
    DD619
    Don
    San Diego, CA
    2020 White TRD OR
    I meant I’m not going to replace the wireless charging feature at all. Is there a different part for a storage cubby without the Qi charger?
    RushT[QUOTED] likes this.
  6. Jan 24, 2023 at 2:02 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Mine works through an Otterbox, but it doesn't charge very fast and gets hot. I usually just use a cable, which charges much faster anyway.
    DD619[OP] likes this.
  7. Jan 24, 2023 at 2:05 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    The Qi charger in the Tacoma has got to be one of the biggest technology fails Toyota has put into production. Never worked for me. Cooked the phone.
    DD619[OP] and oconnor like this.
  8. Jan 24, 2023 at 2:17 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Yup! @Buck Henry
    That's Buck Henry alright! LOLOLOLOL
    I've used mine...sparingly, for charging...but not for more than 30 minutes at a time.
    The darn phone gets very HOT!
    I don't put anything but receipts or my reading glasses in there...and God forbid any water gets in there!
    Since I bought my toggle thingy for Bluetooth connectivity for AppleCarPlay, I can place it on the platform and charge it while using GoogleMaps.
  9. Jan 24, 2023 at 2:28 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    It's not a recall, it's a TSB. Those generally only apply if you're under warranty.
    Mines been deformed since I picked the truck up off the trailer with 4 miles on it, but been too lazy to get it replaced. I'd rather just have a pocket there instead.
    cryptolime[QUOTED] and DD619[OP] like this.
  10. Jan 24, 2023 at 5:00 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I believe you need to buy the entire part of the center console that holds the charger to get the non-trd pocket. It’s like $135.
    DD619[QUOTED][OP] and HisDad like this.
  11. Jan 24, 2023 at 5:09 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    This is correct. The cubby is a part of the front center console and not a available seperately. Used consoles show up on Ebay from time to time, but I've never seen one with the cubby or QI charger.
    DD619[OP] and rtzx9r[QUOTED] like this.
  12. Jan 24, 2023 at 6:55 PM
    virginiajim
    virginiajim Well-Known Member
    2016 TRD Sport Automatic
    I use mine and it works ok but I take the phone off of it when the battery is fully charged assuming it doesn't overheat while doing so. I put down two popsicle sticks as an air buffer to get some air circulation under the phone. That seems to help the overheating a bit. One would have thought that they would have some 'cooling' system to work with it. My other QI chargers at home have fans.
  13. Jan 24, 2023 at 7:46 PM
    Slurmin Furrmen
    Slurmin Furrmen Welder / Fabricator
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    They deform from the heat produced by literally anything.
    Using the charger makes them deform faster, but I never used mine (otterbox case on my phone) and it deformed in 18 months / 30k miles just from the natural heat of the vehicle being parked in the sun in Colorado.
  14. Jan 24, 2023 at 7:49 PM
    Concrete_taco
    Concrete_taco Well-Known Member
    CA
    2020 TRD Off Road
    I've used mine probably twice since the truck was new, have never left the power on for it and it's still blown up like a balloon. All I want is a flat space to store whatever...
  15. Jan 24, 2023 at 9:05 PM
    #35
    DD619
    Don
    San Diego, CA
    2020 White TRD OR
    Me too
