dealers injector cleaning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by s.e.charles, May 25, 2023.
  1. May 25, 2023 at 5:02 PM
    s.e.charles
    s.e.charles [OP] Well-Known Member
    what does this consist? and what's the fair cost?
    thanks
  2. May 25, 2023 at 6:16 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You don't need it. They are self cleaning. If it makes you feel better, run some Lucas injector cleaner in a tank once awhile. I run a bottle every few months in all my vehicles and equipment.
    Kev250R likes this.
  3. May 25, 2023 at 6:38 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Had mine done at 60t miles together with spark plug change and at fluid change . This is how it’s done . I’ll have them do it again at 120t miles
    https://youtu.be/suzFEuuMPXE
    HondaGM likes this.
  4. May 25, 2023 at 6:59 PM
    eurowner
    eurowner Duke Sky
    Scoty
    HondaGM likes this.
  5. May 25, 2023 at 7:01 PM
    Tacospike
    Two Trucks
    I do once a year, maybe less-ish. But I don’t rack up miles
  6. May 25, 2023 at 11:40 PM
    s.e.charles
    so 300$ @ 60k as preventive medicine?
    i use either shell or mobil top tier gas and drive about 8200 miles a year (four + years and 35,200 miles) 2019 4x4 AC
    i guess i don't know the difference between injection nozzles and induction system either!
    thanks for the video & inputs.
  7. May 26, 2023 at 12:09 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You don't need it if you use good fuel. Keep in mind whatever is pumped in comes out the tailpipe as smelly white smoke. Use too much (or too frequently) and you risk poisoning the catalytic converters.
    eurowner likes this.
  8. May 26, 2023 at 1:42 AM
    s.e.charles
    when i was a Saab-o-holic, i would use Howe's fuel conditioner every oil change (3k - dino- this was the '80s).
    the dealer cautioned using anything too frequently, citing deterioration of (rubber) seals.
    D.A.S. Taco likes this.
