Dealers who performed the Suspension TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hotdog, Mar 26, 2008.
  1. Apr 21, 2009 at 6:43 PM
    #501
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    OK so.....
    Northshore Toyota in Covington, LA sucks dead donkey dick!
    TOYOTA OF SLIDELL IN SLIDELL, LA IS AWESOME!
    I walked in with the TSB in hand, no questions asked, my parts were ordered within 10 min. Parts were in this mornin and went and waited today. Lovin it. They have done 3-4 of em.
  2. Apr 21, 2009 at 7:31 PM
    #502
    matt45648
    matt45648 Well-Known Member
    Glockners honda & toyota
    Portsmouth, OH
  3. Apr 22, 2009 at 12:24 AM
    #503
    Robocop
    Robocop Well-Known Member
    Alabama
    09 4x4 Access Cab Gray Manual
    Serra Toyota in Birmingham Al. completed the TSB on my 2009 Access cab without any problems at all. I also was told by Hoover Toyota that they would also approve the procedure however they were about 30 miles further away from my home.
  4. Apr 22, 2009 at 1:40 AM
    #504
    michael2468
    michael2468 Active Member
    North Adams, Ma
    2009 Tacoma SR5 Package
    Haddad Toyota, Pittsfield Ma. 2009 SR5 Xtra Cab
  5. Apr 22, 2009 at 2:51 PM
    #505
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    well its now sitting at BG (actually arlington toyota) for a couple hours so they can check it out. I have a decent amount of weight in the back with tools and stuff, maybe 200 lbs? Not enough to bottom out, but man it sways like crazy when on the highway.
    Of course the guy never heard of this problem or tsb before :rolleyes: I also told him about my radio acting all funky so we will see what happens. So far I am NOT impressed with toyota service with warranty work :mad:
  6. Apr 22, 2009 at 7:54 PM
    #506
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    I went in to try to get the rear spring hash ride TSB yesterday. Chuck Patterson Toyota fit me in at 10:30 in the morning which was fine since i had class at four. It took them two hours to do the "Check Up" and the service writer comes back and says "we've gotta talk about some things." I was confused by her tone, but she said that they can do the TSB but that it will void any other rear suspension warranty(wtf) after the work is finished. Then she told me that there were alot of parts to order so it will take a few days to get the parts in (I am hopefull that this means new shocks too). She said that if they do it, other problems might arise in how the truck handles and i was very suspicious. She alluded to the fact that they get paid for this which i replied that i knew already. I told her to order the parts and they will call me when i need to make an appointment. I'm just happy that i didn't get turned down because it seemed probable. BTW i have an 08 sport dblcab 4x4 12k miles.
  7. Apr 22, 2009 at 8:24 PM
    #507
    k2raus
    k2raus Member
    I don't think they replace the shocks if you have the bilstein shocks. But they shouldn't give you a hard time over the TSB - they get paid from Toyota to do the work. I have had four TSB issues totalling around $1,800 or more in work and there was never a question about it being fully covered. And I don't believe your warranty should be an issue after the work is done. I would inquire more fully on that, as it potentially voids 1/3 of your coverage on a major component.
  8. Apr 22, 2009 at 9:10 PM
    #508
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Thanks
  9. Apr 22, 2009 at 9:11 PM
    #509
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    my new shocks are on order :D
  10. Apr 23, 2009 at 3:15 AM
    #510
    TACOCRAZY
    TACOCRAZY Active Member
    Sarasota, Florida
    07 Prerunner SR5 double cab
    Custom made 15 degree offset t-handle billet aluminum shifter handle, more to come
    This will NOT void any other rear suspension warranty, where the hell did they come up with that??? I am a service writer and I have had this TSB done to my 07, your truck will still be in warranty. I don't see why any dealer would discourage this TSB, after all they get paid....:confused:
  11. Apr 23, 2009 at 4:25 AM
    #511
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    sounds like bs to me. I have my order list in front of me- shows spring assembly, u bolts, and the shock absorbers. I also have 11K on my '09. the ride seems to have really gone to shit lately. i cant wait to get this done. FWIW, I think I have the "revised" 3 leafs in there now. imo, they need 4 from the factory, or a different material spring.
  12. Apr 23, 2009 at 5:57 AM
    #512
    Austin Taco
    Austin Taco Well-Known Member
    Pflugerville, TX
    08, TRD Sport, double cab, long bed
    Excuse my ignorance...
    What is the TSB for?
    I have an 08 TRD sport. Should I take mine in?
  13. Apr 23, 2009 at 3:11 PM
    #513
    TACOCRAZY
    Sarasota, Florida
    This TSB is for a "harsh ride when loaded"
    Basically the springs aren't strong enough to hold the weight the truck is rated for. If you use your truck as a truck, I would DEFINETLY recommend getting the new four leaf pack installed. You would not get new shocks or an alignment since you have a TRD, but the ride is like night and day. It has a stiffer ride, and it handles 10 times better. To get this done, the dealer will need to see that you rubber stops on the rear axle have been touching the frame, you should see a clean spot where they have been touching. Load it with at least 400 lbs, drive it over some bumps to insure you have these clean spots, and go into the dealer and tell them magic words....
    "my truck rides rough when loaded"
    Any decent dealer won't give you any hassles at all. I have performed this TSB on several of my customer's trucks as well as my own. BTW I have not heard of a "revised three leaf pack"...I'm not saying they don't exist but I'm pretty confident they don't:D
  14. Apr 23, 2009 at 3:37 PM
    #514
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '19 SSM Limited, '09 DCSB MGM OR
    I didn't go in with anything in the truck. Just told them it road rough when I had weight on it. I didn't get shocks (TRD), but, they did do a alignment on mine.
  15. Apr 23, 2009 at 4:00 PM
    #515
    IndigoBlue2006
    IndigoBlue2006 Member
    Spokane, Washington
    2006 Access Cab 4WD
    K&N Drop In Air Filter, Rear Spring TSB, All Weather Mats, Hood Protector
    Downtown Toyota in Spokane, WA. May Ward was the Service Rep. Very satisfied with work and service.
  16. Apr 26, 2009 at 6:46 AM
    #516
    jrw1965
    jrw1965 Well-Known Member
    Southern Maryland
    '08 dbl cab long bed 4 x 4
    Front tint, Stainless steel nerf bars, Leer tonneau, Rear spring TSB, Michelin LTX A/T2 265 70 16, Pioneer AVIC X910 so far
    Toyota of Waldorf (Maryland)
    It took some complaining, and you could tell they didnt want to do it. I got it done Friday. They did it right the first time. and it drives great. I'll post some pics later.
  17. Apr 26, 2009 at 9:25 AM
    #517
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    if they get paid to do it, why are these dealers being such pricks about it?
  18. Apr 26, 2009 at 9:54 AM
    #518
    bbarian333
    bbarian333 Well-Known Member
    SoCal
    06, Accesss Cab, TRD Sport
    TRD exh, K&N drop in,TRD seat cvrs,tsb springs
    John Elways Crown Toyota in Ontario California did mine . I just told them it bottomed out with approx 500lbs. They checked it out,ordered my parts , did the work yesterday.
    I went though a major hassle at Moss Brothers Toyota in Moreno Valley Ca.I'll never go to Moss Brothers again ,even though its closer to me.
  19. Apr 26, 2009 at 1:34 PM
    #519
    ShtrMcGavin
    ShtrMcGavin Well-Known Member
    Bryan
    Tempe, AZ
    Silver 05 DBL Cab LB 4x4
    3" Lift, spidertrax 1.25" spacers all around
    I tried a quick search without any luck but I was wondering if any of you know if an 05 dbl cab 4x4 that im the third owner of with 61k on it would qualify?
  20. Apr 26, 2009 at 1:45 PM
    #520
    bbarian333
    SoCal
    the warranty states 36,000 or three years. Its also on the TSB.
