Dealers who performed the Suspension TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hotdog, Mar 26, 2008.
  1. Jan 4, 2011 at 1:02 PM
    #1001
    RobbKruger
    RobbKruger Wasting away in the frozen North
    Robb
    Twin Cities, Minnesota
    09 Tacoma DC TRD Sport Speedway Blue
    Access Bed cover, Access tailgate gasket, OEM Roof Rack, Garmin 780 12V bed outlet mod 120V in the console mod "Don't steal my tailgate" mod Yakima Lowrider rack mounted to OEM rack with Thule Cascade XT carrier Avid Arctic bar SOON TO COME - OME 885 lift kit
    Burnsville Toyota, Burnsville, Minnesota
    No issues at all on 2009 DC Sport. Showed the guy the buffed off areas on the frame where the bump stops had touched. Had the parts there and finished the install that same week.
  2. Jan 7, 2011 at 2:01 PM
    #1002
    Jnip
    Jnip Member
    Justun
    Richmond, Tx
    Fort Bend Toyota did mine yesterday. Had it inspected the day before so the turn around was very quick. Dropped it off @ 0730 picked it up about 1300.
    2010 DC 4x4 TRD OR
  3. Jan 12, 2011 at 10:47 PM
    #1003
    gordynor
    gordynor Well-Known Member
    Daniel
    San Diego
    2011 MGM Double Cab 4x4 TRD Off Road
    Steering intermediate shaft TSB, Rear leaf TSB, Bilstien 5100 F&R, Viair 400 mounted under the hood, rear diff breather, re-routed crossmember exhaust, fixed GPS mount, in-dash CB radio, double din HU, trimmed mud flaps, etc...
    Toyota Escondido (SoCal) did the rear leaf TSB and the steering intermediate shaft TSB on mine this week. I pick it up tomorrow - stoked! They wanted to inspect it first and I had to test drive it with the tech to point out the loose steering on gravel, but they're doing it.
    I'm pretty impressed with them so far. They also went all out to find & fix a really annoying squeak around the windshield. They were going to pull and reseal the windshield but ended up finding that the squeak was fom a bad weld in the frame around the window. Dude, they ripped apart and welded my truck to fix it! Awesome!!
    2011 DC 4x4 TRD/OR MGM
  4. Jan 15, 2011 at 1:20 PM
    #1004
    Vrbas
    Vrbas Well-Known Member
    2013 4x4 DCSB 6speed
    I'm in a 2011 Access Cab 4cyl, should this concern me? I haven't heard anything about this.
  5. Jan 18, 2011 at 11:29 AM
    #1005
    donovan6241
    donovan6241 Well-Known Member
    Donovan
    San Diego
    2017 TRD Sport Double Cab Long Bed
    bob baker toyota in san diego did mine. if u have any problems, talk to brad. he is the service manager.
  6. Jan 28, 2011 at 8:36 PM
    #1006
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    Longo Toyota, El Monte, CA. I said it sagged under load. Had to leave it with them so that they can verify problem. They called me to pick up my truck and said they ordered parts. A few days later, parts were in. Took it in at 9:00 am Tuesday & it was done by 4:00 pm. Finally got it done! :yay::taco: Ride is not harsh at all, hardly noticeable. Back end sits about an inch higher. Maybe it'll settle some.
  7. Jan 28, 2011 at 8:52 PM
    #1007
    Rufus
    SoCal
    If you have 3-pack rear leaf springs, your truck will sag & bottom-out under load. Bump stops will hit the frame. I would advise anyone to have it done. What good is a truck if you can't carry or haul a load or tow a trailer safely? The TSB is for a sturdier 4-pack rear leaf springs & alignment, maybe new shocks as well for non-TRD models. I think they look for bump marks from the bump stops on the frame. I'm surprised they're still using 3-pack leaf springs on 2011's. Good luck.
  8. Jan 29, 2011 at 12:28 AM
    #1008
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    Coggin Toyota in Jacksonville Fl. is replacing them with no problem. I said I didn't like the way the rear end felt bouncy while pulling the boat. The service writer said he has done several already. My appointment is this Thursday.
  9. Jan 29, 2011 at 1:37 AM
    #1009
    kauaibuilt
    kauaibuilt U no kea but AINOFEA!
    LA/SGV
    2011 DCSB
    Check out my sig...
    Chula Vista Toyota - no questions asked but the service dood reminded me at least 10x's that "it's gonna ride harsh! Are you sure you want this done?"
  10. Jan 29, 2011 at 3:56 AM
    #1010
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    I just don't know?? I just don't trust any mechanic touching my truck, he might screw it up, strip out some bolts and next thing the rear axle might fall out...
    everytime I take any of my past trucks in for either state inspection or tires the lug nuts are either over-tightened, or loose, on my older 4x4 with manual hubs the mechanic screwed up the hub, smashed it with a hammer out of round that I couldn't lock my hubs.
    I would love to have that done since I do have the tow package and planning on some heavy towing this summer, but,,, I just don't trust them
  11. Jan 31, 2011 at 6:37 AM
    #1011
    pudgie10
    pudgie10 Well-Known Member
    Moline, Il
    2011 TlX Pro
    rear TSB
    Had the TSB done last week at Hyland Toyota Moline, IL. It took 3 phone calls talking with the service department, with me expressing concern about harsh ride when towing a trailor. They mention more than once that the ride would be stiffer when not loaded. I told them that was fine. They order the parts and a week later installed the new 4 leaf. I could tell right away that the rear was higher and yes it rides rougher but not to the point its offensive. IMHO.
  12. Feb 3, 2011 at 11:19 AM
    #1012
    canyonchaser
    canyonchaser Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    Mark Miller just did mine last week - they showed me the new TSB, with a new number, that includes the 2010's.
    Greg Ostler was my rep.
    dp
  13. Feb 3, 2011 at 12:12 PM
    #1013
    skaterportland
    skaterportland Active Member
    Portland, OR
    2011 TRD OffRoad DC
    Spraypainted
    Gladstone Toyota in Oregon doing it right now. Tech said he had his done on his Tacoma...
  14. Feb 3, 2011 at 12:20 PM
    #1014
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    Arlington Toyota in Palatine. I gota 2010 TRD Sport. Under my Platinum coverage I got a free rental as well. I brought it in cause i was getting some really bad vibes/shaking/bouncing. Erik Rudd looked up any known issues and recalls and found the TSB (which i already knew about) and set it up. Go see Erik, he fought with the people who manage the extended coverage to get me my free rental. Dropped it off about noon today and should be ready in the AM tomorrow
  15. Feb 3, 2011 at 12:41 PM
    #1015
    chiefridr
    chiefridr I don't want a large farva!
    Carrollton, TX
    16 DCTRDOR
    Had mine done at my stealership a few months back. They pushed a little at first, but when I brought in the TSB that I printed off here and gave it to them, they relented and did it for me with no problem. They said I was the only Taco owner that they'd done it for.
    Hoselton Toyota
    50 Marsh Road
    Rochester, NY 14445
    Svc. Dept. 1-(888) 704-8341
  16. Feb 9, 2011 at 11:22 PM
    #1016
    808StateTacoma
    808StateTacoma SEARCH button is my BEST FRIEND
    Honolulu, Hawaii
    Magnetic Grey 2010 TRD Sport Access Cab
    Weathertech Floor Mats Wet Okole Seat Covers Ultragauge Flowmaster Original 40 Series Rear Suspension TSB SlimbCubby 4300K HID Hi/Lo
    Honolulu, HI - Kaimuki Toyota
    Will be getting it done first week of March. Went in for my free oil change given from the recall and told them that i was bottoming out with a few hundred pounds in the back. I told them that it was only a few times and that i had already checked the bumpstops for any signs and didn't see much. They said they needed to verify before doing it. When i came back to pick it up - they told me they couldn't "verify" it....BUT... if i wanted it done, then they would have to order the parts. Basically it wasn't a problem at all getting them to do it...
    Parts are available. They just don't have an opening until 1st week of March. Looking forward...
  17. Feb 11, 2011 at 10:22 PM
    #1017
    dan0688
    dan0688 Active Member
    06 sr5 6spd
    I work there.... Iv done lots of them.... maybe you talked to one of our newer guys...
  18. Mar 3, 2011 at 4:30 PM
    #1018
    accesscab
    accesscab Well-Known Member
    Cumberland Toyota. Cookeville, TN. with no problems at all. took in the TSB, made appointment, got it done. simple
  19. Mar 3, 2011 at 4:33 PM
    #1019
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Johnstons Toyota in New Hampton, NY. Great job the first time. Great service dept and techs
  20. Mar 3, 2011 at 5:26 PM
    #1020
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    Dan Cava toyota in Fairmont WV did a good job on mine.
    I had the bouncy ride with a significant load. I always went super slow over the tracks to prevent actual bottoming out, and they didn't question me or make me reproduce it.
    One thing to advise, I brought the tsb with me. The employee I spoke with said he was taking my bilsteins out and replacing them with an inferior product, along with the leaf springs. I showed the tsb and he had them mixed up.
    Also, they warned of a rough ride after, but there is no difference before or after (TRD SPORT MODEL). I inspected the job and gained 1 inch of lift of the rear, hopefully to be reduced over time.
