Dealership disarmed Pre-Collision System due modified grill/Pro grill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoGlenn81, Oct 30, 2020.
  1. Oct 30, 2020 at 3:47 PM
    TacoGlenn81
    TacoGlenn81 [OP] Well-Known Member
    So I had an appointment for maintenance at my Toyota dealership for my 2018 TRD off road tacoma. As I was getting serviced they wanted to let me know there was some recalls on my vehicle but I had to sign a waver since one of them involved a sensor upgrade for my PCS and I had modified my front grill / upgrade to Pro grill. As I am driving home I noticed that my Pre Collision light is bright orange and says "OFF". Turns out the dealership just straight up disarmed my PCS. Most annoying part is im stuck with the OFF light on my dash. I had tested the PCS after I installed my grill and seemed to work fine. I assume they disabled it since they don't want to be responsible if it works incorrectly due to the Pro grill upgrade.
    I just wanted to know if anyone knows how to rearm the PCS because the off on option isnt working anymore. My guess is they used some type of computer to disarm it completely. Is it possible to rearm it myself? and if not can I get rid of the annoying light?
    thanks
  2. Oct 30, 2020 at 3:52 PM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Are you talking about the TSS sensor? Did they just unplug it and forget to plug it back in?
    suaveflooder and t0nyvalenzuela like this.
  3. Oct 30, 2020 at 3:55 PM
    TacoGlenn81
    looks like its plugged in. I think they just disarmed it since I have a upgraded grill. Its considered a modification.
  4. Oct 30, 2020 at 4:01 PM
    SunRunner
    SunRunner Rub some dirt on it!
    Scott
    PA
    2019 Off Road Looooooooong Bed
    This has been posted about in the past. You’re not the only one this has happened to. I assume you are correct in your belief that it’s about liability issues.
    I can understand your frustration and would hate the off light as well. I have an after market grille but so far no issues with Toyota service.
  5. Oct 30, 2020 at 4:03 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Did you upgrade it tot he pro grill without the TSS? There should be one that includes it.
  6. Oct 30, 2020 at 4:04 PM
    81shark
    81shark Well-Known Member
    One of the many side effects of rocking a bro taco
    VeeSix, Taco 422, Chadr7858 and 4 others like this.
  7. Oct 30, 2020 at 4:06 PM
    TacoGlenn81
    yes I upgraded my grill about 2 years ago and it has the TSS module. Like i said i tested it and seemed to work fine but Toyota considers it a modification and had went in a disarmed it so I am not able to Turn it back on within the settings
  8. Oct 30, 2020 at 4:08 PM
    nudavinci64
    Robert
    lame.. have them "install" the grill again then turn it back on. I assume OEM grill or was it a copy?
    I am sure you could find another dealer to turn it back on. Play dumb, this came on, can you guys fix it...
    DAS Taco likes this.
  9. Oct 30, 2020 at 4:09 PM
    SunRunner
    Scott
    PA
    I upgraded to a pro style grille I got off eBay and bought the oem garnish from Toyota. My grille looks like the real deal though, even though it wasn’t advertised or priced as oem. Mine is molded as a single piece, including the letters. It’s a quality knock off.
  10. Oct 30, 2020 at 4:11 PM
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    I would have made a u-turn back to the dealer the second that light came on and wouldnt have left till they fixed it
  11. Oct 30, 2020 at 4:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Put the stock grill back, return and have them reset it.
    Put the pro back after you are home.
    Only return there for other warranty/recall work, which will be unlikely to include that again
    DAS Taco, Gearheadesw, BSFord and 4 others like this.
  12. Oct 30, 2020 at 4:13 PM
    TacoGlenn81
    yeah i got mine off CALI RAISED. Looks like the real deal. I guess its pretty obvious though when you bring in an off road truck with a pro grill
  13. Oct 30, 2020 at 4:14 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    They should turn it back on for you. They had absolutely no business turning it off! Plain and simple but did you sign a waiver. My local dealer called and scheduled an appointment for my fuel pump recall and wanted to do the tss. Simply put I said do not touch it, I refuse to let.them do it.
    71tattooguy likes this.
  14. Oct 30, 2020 at 4:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    You might be there a really long time!
    FLA_Hoosier likes this.
  15. Oct 30, 2020 at 4:15 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Search around, I vaguely recall that they flash and it permanently disables the sensor, e.g. bricks it. T-SB-0026-20 claims a new sensor is required.
    brandon78lusch and Tripod1404 like this.
  16. Oct 30, 2020 at 4:16 PM
    TacoGlenn81
    yeah I signed a waiver but they did not mention anything about upgrading the TSS sensor or disarming it. I was in a middle of a phone call when the guy brought me the waiver so i should had read it better but i know he didnt mention it directly.
  17. Oct 30, 2020 at 4:19 PM
    VaToy
    Parts Unknown
    Go back and demand it to be reversed.
  18. Oct 30, 2020 at 4:19 PM
    Tripod1404
    Tripod1404 Annihilator tripod
    Yeah I remember this. If they did this update, module is toast.
  19. Oct 30, 2020 at 4:22 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    T-SB-0026-20 attached. If that is what you signed off, module is supposedly dead and cannot just be turned on again.
  20. Oct 30, 2020 at 4:30 PM
    TacoGlenn81
    the visit before last they told me they couldnt do the recall on the sensor because of the pro grill and said if they did they would have to disable it so I declined. I am pretty sure the recall rolled over with the existing recalls they did today because the guy didnt fill out the paperwork or have me sign anything showing i declined it. The waiver did not look like that one i signed today though. So i can assume this is what they did to it since i am not able to turn it on within the dash
