Dealership disarmed Pre-Collision System due modified grill/Pro grill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoGlenn81, Oct 30, 2020.
  1. Nov 1, 2020 at 8:10 AM
    #101
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    OK, I have said this like 5 times in this thread.
    TOYOTA IS NOT TURNING THESE OFF RANDOMLY. IF YOU GO IN FOR THE SENSOR RECALL, THEY WILL GIVE YOU A FORM THAT YOU SIGN TO TURN IT OFF, IF YOU DONT SIGN IT THEY DONT DO THE RECALL. IF YOU HAVE HAD THE RECALL DONE, THEY WONT GO BACK AND TURN IT OFF WHEN YOU GO IN FOR ANYTHING ELSE.
    You go in for a oil change... they dont care
    You go in for a fuel pump recall... they dont care
    You go in for the tss recall.. they do care
    BSFord and Pablo8 like this.
  2. Nov 1, 2020 at 8:13 AM
    #102
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I think Toyota wasn’t out of their minds when they put the radar sensor in the grille. If you are not affected by having modified your vehicle, the placement makes perfect sense and it hides well behind the garnish. The 2016 and 2017 models have the bracket, but no sensor, so that was clearly their intention all along.
    The thing they didn’t anticipate is all the grille-swapping that goes on, specifically with 3G Tacomas. Let’s face it, grille-swapping is a 3G thing. There are a few other vehicles where people may do this, and the odd 2G Taco and 4Runner, but I don’t think anyone could have imagined how grille-swapping, en masse, would become a “normal” thing to do with 3G Tacos.
    Lifting, on the other hand, they should have anticipated, which I believe they did. That’s why the unit has some ability to be recalibrated.
    batacoma[QUOTED] likes this.
  3. Nov 1, 2020 at 8:19 AM
    #103
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
    OK BRO.
    I realize how things are supposed to work. My concern is when people operate outside of established procedure (like making sure the form is signed before something is done). That is not exactly an unheard of condition. I have had dealerships do things I didn't ask for. If you haven't, that's great.
  4. Nov 1, 2020 at 8:22 AM
    #104
    5nahalf
    Erik
    Minnesota
    But toyota isnt turning these things off unless you go into the dealer to get the tss recall done... thats just not happening, and if you think it is happening, then you need to change your tinfoil hat because its not working.
    If they turn it off without getting the form signed, then its not legally binding and they need to turn it back on. If you signed the form, then its on you.
    Boghog1 likes this.
  5. Nov 1, 2020 at 8:31 AM
    #105
    Landpirate
    North Texas
    I have not made one single statement that I think Toyota is blanket bricking the TSS. My statement was to prevent (hopefully) the possibility. That's it. So thank you for your advise regarding tinfoil hats, but it's really not needed.
    Totally understand that without consent its not binding, and I am quite familiar with informed consent requirements. However, that doesn't mean that (again due to human error) it cannot happen. People make mistakes, people go outside of procedure, people violate policy. It happens. Sometimes by mistake. Putting a note on the truck to not brick the TSS sensor was an idea for hopefully minimizing the possibility that it could happen.
    For the record, I agree that you should read what you're signing. If the OP signed consent, then that's on him.
    5nahalf[QUOTED] likes this.
  6. Nov 1, 2020 at 8:39 AM
    #106
    5nahalf
    Erik
    Minnesota
    I apologise for the tinfoil comment, wasn't needed.
    But yes dealers will do things without consent, but in this case they need signed consent.
    Landpirate[QUOTED] likes this.
  7. Nov 1, 2020 at 8:43 AM
    #107
    Landpirate
    North Texas
    Totally understood, no problem; I think we're actually pretty closely in agreement. And as a general rule, I rely on the dealership following procedure.
    I go to a dealership that's on the other side of DFW from me. Like 2 counties away. I go there because the dealerships between where I live and where I got my truck are known for shenanigans.
  8. Nov 1, 2020 at 9:01 AM
    #108
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    This is reason 485 why not to take your vehicle to the dealership for anything other than a recall and even then I question it. My truck shakes in fear whenever I mention the stealership.
  9. Nov 1, 2020 at 11:19 AM
    #109
    TacoGlenn81
    TacoGlenn81 [OP] Well-Known Member
    Only problem is I didn’t go in for a recall. I went in for Toyota care service. They then said I have afew recalls and I need to sign some waivers before they do it. So just read the waivers carefully or don’t sign them. I wasn’t told directly about what exactly they were going to do as well as I declined the TSS recall the previous visit but they didn’t have me sign anything so it appears the recall rolled over to this visit because I thought the recall was for something else. I unfortunately just put my trust in the service guy and didn’t read the waiver fully. Had he mentioned anything about disabling the PCS system I would have declined. Lesson learned. Just read everything you sign... I’m going to ask to see my waivers when I go in next time to see if it said anything about disabling it permanently
    BSFord likes this.
  10. Nov 1, 2020 at 11:22 AM
    #110
    5nahalf
    Erik
    Minnesota
    Yeah, those are just add on things.
    The point I am making is that if you go in for a oil change and you have a pro grill, they are not going to turn off the system. If you go in for a oil change and they say you have recalls and want to add them on then they can turn it off since its required for the recall.
    Bottom line is know what your getting when you sign up for it.
  11. Nov 1, 2020 at 11:51 AM
    #111
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    At least they're not taking your aftermarket Pro grille due to some sort of copyright infringement. Wouldn't that be something "we took your replica grill along with the TSS due to safety and faux grille". There would be a lot of tacos missing teeth...
  12. Nov 1, 2020 at 12:30 PM
    #112
    Timetraveler66
    Timetraveler66 Well-Known Member
    Laugh, Toyota was taking and disposing of front mats that were not factory during the 2nd gen gas pedal fiasco. I know 2 people that lost their Husky mats. And got a hacksawed gas pedal.
  13. Nov 1, 2020 at 12:33 PM
    #113
    5nahalf
    Erik
    Minnesota
    I got a sawed up pedal for my rav4... they dont even try to make it look nice, they just chop the corners off all janky.
    Pablo8 and Smacky2020 like this.
  14. Nov 1, 2020 at 12:38 PM
    #114
    Smacky2020
    Bristol, VA
    "What do you want me to do lady, chop it off?" Sounds like the original 'cab chop'.
    Pablo8 likes this.
  15. Nov 1, 2020 at 12:45 PM
    #115
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I have a 2nd gen but I'm pretty sure they chopped it since it was a lease before I purchased the truck after it was turned in. Never had a floor mat when I got it so IDK unless someone knows the original pedal size
  16. Nov 1, 2020 at 4:03 PM
    #116
    ortho
    ortho Well-Known Member
    In any of this, does it matter if the grill is a Toyota part? Like an older Trd OR with a 2020 grill, grill off another model, or a genuine Pro grill?
    I have a 19 with a 20 grill.
  17. Nov 1, 2020 at 4:06 PM
    #117
    TacoGlenn81
    Basically if it’s not the factory grill it came with it’s considered modified.
  18. Nov 1, 2020 at 4:06 PM
    #118
    5nahalf
    Erik
    Minnesota
    Do you have a open recall for the front sensor? If you dont have a open recall for the front sensor then this doesnt apply to you.
  19. Nov 1, 2020 at 4:09 PM
    #119
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Well if you go in for the recall - you could have the original grill and have a 4" lift and you sign the papers.....toast.
  20. Nov 1, 2020 at 4:11 PM
    #120
    ortho
    I just looked it up, and I do not other than the fuel pump so no concerns for me. Carry on.
    Pablo8 and 5nahalf[QUOTED] like this.
