Dealership f*cking up sound system!?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLOH, Oct 12, 2009.
  1. Oct 12, 2009 at 4:28 PM
    SLOH
    SLOH [OP] Well-Known Member
    Scott
    Los Angeles
    07 SR5, dc long bed speedway blue
    2.5 Icon c/o's and 3" AllPro rear suspension kit, 17" XD Series Addict w/ 285/70/R17 BFG KM2's, K&N 63 Series CAI, 13.5'' JL Sub (13TW5v2-2) and 500w Rockford Fosgate amp, limo tint all around, cat back banks exhaust with no muffler or tip, blue dash light mod, "taco" 3rd brake light mod, blue dome-light mod, cb radio and 4' firestik antenna, blacked out hoodscoop(thanks randy), Total Chaos UCA's
    i just got my car back from the dealership for its usual 5,000 mile check up at 43,000+ miles
    change oil, rotate tires, top off fluids, inspect chassis all that good stuff
    in this service i had my drums cleaned and re-aligned cause they had to be
    new battery installed since mine was almost completely dead (main reason i made the appt for today)
    new cabin and AC filter installed
    i get my car back and the first thing i notice, is an awkward thumping in back, like my bass is firing at volume 1 or 2 and its audible and you can feel it and it is even there during the normal song, but its on and off, sometimes it will do it, other times it wont, sometime fast, sometimes slow, the song has some affect on it but its kind of always there.
    oh and somehow my alignment is off now, i don't know if they fucked up rotating the tires and hit something, but at speeds up to 40+, my steering wheel oscillates back and fourth and it pulls left now WTF, i dont need this extra bullshit to deal with right now, especially since toyota is going to claim they didn't do shit to the sound system
    all i know, it was fine before they touched it...don't know what could have gone wrong??
    and yes i already contacted the dealership and told them both complaints and i'm bringing in my alignment spec sheet from when i had it done in sept.
  2. Oct 12, 2009 at 4:40 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    my buddy went to get his brand new GMC silverado aligned after upsizing to bigger tires and accidently hitting a curb a little quick. Befoer he sent it to the shop it had 8,000 miles on it, when he it back, it read 40,000. During the alignment the alignment guy must have messed with some sensor, or wire, and it can't get reset. The owner of the truck was pissed because the value of his truck dropped like crazy because the odometer was screwed with. The dealership said that the owner of the truck must have driven the truck 40,000 miles on his way home or something crazy like that. Dealerships generally have a way of screwing things up
  3. Oct 12, 2009 at 4:40 PM
    toast
    toast Well-Known Member
    thumping is likely coincidental, search for subwoofer wiring on here and you'll see the problems some have had
  4. Oct 12, 2009 at 4:41 PM
    SLOH
    Scott
    Los Angeles
    nice name btw and i have a feeling they are gonna get away with the sound system fucking up, i have no way of proving it wasn't fucked up before but i have proof with the alignment
  5. Oct 12, 2009 at 4:43 PM
    GAS
    GAS Well-Known Member
    Greg
    beautiful washington state
    I have an 09' with the jbl system and also have some issues with my sub. I only notice it when playing Cd's even with the bass level set to 0 and when the volume is turned down it gets worse. Sounds like a scratching sound? Is this what you are experiencing? Anyone else have this issue? Doesn't do it when using the radio or Ipod????
  6. Oct 12, 2009 at 4:43 PM
    SLOH
    Scott
    Los Angeles
    well there was absolutely no problem whatsoever with it and i get it back like that....something tells me a wire isn't just going to fuck up like that, the pitch of it is even different
  7. Oct 12, 2009 at 4:44 PM
    SLOH
    Scott
    Los Angeles
    no its a distinct thump from my bass and its off my ipod, i just got a kenwood installed a week ago and had everything wired and perfect...when the volume is on 1, the base sounds like the volume is on 15, but this abnormal bass hit doesn't necessarily get louder when i turn up the music..its just there in the song
  8. Oct 12, 2009 at 4:46 PM
    toast
    Ok well you have to ask yourself:
    Why would they be touching anything having to do with your wiring?
    Don't you think it's possible your Kenwood blew your sub and now it sounds bad all the time?
    I take it you got a new HU and kept the stock sub?
  9. Oct 12, 2009 at 4:48 PM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    Same issue. It pisses me off all day. My truck has 1000 miles on it and I already want to change the system.
  10. Oct 12, 2009 at 4:48 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    usually alignments aren't covered by warranty, whether it's factory warranty or dealership labor warranty. your alignment could be in spec during alignment but one pothole and it's out. your alignment is even out of spec as soon as you drive it. i would take it back to the dealer to check the tires and maybe rotate them back. it's possible a bad tire is causing this symptom. i've seen it a lot. rotate the tires for a customer and now we have a pulling,drifting or vibration issue that wasn't there. it could also be a bent wheel.
    and i agree with you about the radio. i see porters and some techs all the time change the radio to their preference and it pisses me off. but you can't prove but you know they do it.
  11. Oct 12, 2009 at 5:08 PM
    SLOH
    Scott
    Los Angeles
    okay, to address the issues above, i have an aftermarket sub, 12" rockford fosgate and 500w amp rockford fosgate. 1 week ago had the kenwood installed, had them wire it past the factory amp so i have subwoofer control, my HU is now fully functional and i can customize every audio aspect of my car, its been fine for a week, imsikotic even saw me at the place last week when he drove by. I haven't blown my speakers or sub, i've had that set up for 1.5 years, i checked the sub and amp, everything is perfectly fine, checked the settings in my kenwood, nothing is touched, why would they be fucking with the wiring, i have no idea? all i know is its different now
    as for the rim and tires, i don't even have 1000 miles on them, they are brand spanking new and i know none of them are bent cause i haven't touched dirt since i've had them yet and i haven't hit anything....
    i'm not talking about oo i hit a pothole now its off a little bit, this is noticeable, i feel like i'm fighting the steering wheel so i don't know why a simple rotation of the tire would cause this, all of them have been balanced properly or else i would have noticed a problem before but i've driven about 400 miles and everything was fine...another reason i think the alignment is off now is because, long story, have cv axel grease in my left wheel well, now there is a rubbing spot where the grease is missing that wasn't missing before and what i mean by this is you can see where the tire is rubbing but its a small area...and it doesnt feel like real rubbing...and something that small wouldn't cause it to pull that much...i have no idea this is lame
  12. Oct 12, 2009 at 5:09 PM
    SLOH
    Scott
    Los Angeles
    i'm gonna go once over everything...
  13. Oct 12, 2009 at 5:26 PM
    SLOH
    Scott
    Los Angeles
    okay, the bass is definitely miss firing, when i turn up the song, the bass kind of overrides it until you get to a part in the song where there is no base and you hear thump..thump..thump, its the same pitch and volume always, regardless of how high/low the music is and its constant...then all of a sudden it'll stop and everything will be normal...then all of a sudden it'll come back on again irradically...this is me sitting there watching it when its at low volume, the bass hit is clearly higher than it should be at volume 1/2/3/4/5 until about 10 but then i have this added awkward bass hit in the song that doesn't sound like it should be there and no its not the song cause it is at random points in the song...this is so frustrating..
  14. Oct 12, 2009 at 5:44 PM
    SLOH
    Scott
    Los Angeles
    no i don't even really know what rca's are....i mean the whole system:HU, Amp, Sub everything is internal to the car, i don't have wires showing really so i don't know how i would check them without taking things apart...
  15. Oct 12, 2009 at 5:50 PM
    SLOH
    Scott
    Los Angeles
    yeah okay thats what i thought but i wasn't sure, yeah there is no way i'm gonna be able to look at those, those plug into the back of the HU right? if so, my HU is an in dash one, so i would have to take it back to where i got it installed and have them take things apart and look at it
  16. Oct 12, 2009 at 5:54 PM
    SLOH
    Scott
    Los Angeles
    but see whats weird is that i haven't even touched dirt since i've had it installed...haven't hit any bumps, didn't hit any bumps on the way to the dealership and it was listening to it at a nice volume, not too loud or soft and everything was good and then i get it back and its like this....how could things get screwed up when its just been sitting there
  17. Oct 12, 2009 at 5:55 PM
    SLOH
    Scott
    Los Angeles
    and yeah the way the amp is mounted i can't see that end either w/o trying to dismount the amp but i don't even have any tools being in a dorm...:(
  18. Oct 12, 2009 at 6:03 PM
    SLOH
    Scott
    Los Angeles
    no i know exactly what button you're talking about and thats exactly how i had it before, "off" i checked the HU settings, after going back out there and playing with them the bass seems to be back to normal pitch wise but the awkward completely random bass hit is still there, what doesnt make sense is how the bass hit doesn't change volume regardless of how hi/low i make the music, its the same volume/pitch (the awkward bass hit that is)
  19. Oct 12, 2009 at 6:13 PM
    SLOH
    Scott
    Los Angeles
    alright well do you think the dealership had anything to do with this? why would something like this all of a sudden happen?
  20. Oct 12, 2009 at 6:16 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Holy shit! How is that even possible :eek:. I'd drive my truck through their building if they did that shit to me.
