Dealership installed Lift, Wheels & Tires...
Discussion in 'Wheels & Tires' started by JonyU, Mar 4, 2012.
  1. Mar 4, 2012 at 4:46 PM
    JonyU
    JonyU [OP] New Member
    Salt Lake City
    2012 DC Sport
    Recently purchased a 2012 DC TRD Sport with a 3" spacer lift, 18" XD Addict Wheels, and 286/65/18 Nitto Terra Grappler installed by the dealership. The truck was already modified when I purchased it.
    The Problem....
    The tires are rubbing against the upper control arm and the dealership can't seem to figure out how to fix it. Larger offset puts the tire outside of the wheel well and I am trying to stay away from a spacer. They are willing to fix the problem, and it is becoming apparent they have no clue what they are doing.
    I am not expert when it comes to this so any advice is appreciated.
  2. Mar 4, 2012 at 4:53 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    A more negative offset puts the wheel further outside the wheel well. Like -12 would stick out further than +12. About a 4.5" backspacing would be -12 offset on a 9" wide wheel. Asuming your 18" wheel is 9" wide, most are. If the offset is too positive or the backspacing is too high numerically, you could just add some spidertrax spacers to get the wheel away from the UCA. That's really all you can do. Wider tires than stock will not work with stock UCA. Actually, a more expensive route but it would improve your alignment would be to get aftermarket UCA. That would work with the wider tire and stock offset / backspacing. New UCA are really the right way to fix your problem and also the problem you probably don't realize you have (out of spec alignment)
  3. Mar 4, 2012 at 5:00 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    Tell them the only solution is for them to purchase and install icon ucas lol
  4. Mar 4, 2012 at 5:24 PM
    JonyU
    Salt Lake City
    2012 DC Sport
    Would a 17" wheel and different tire size fix the problem?
  5. Mar 4, 2012 at 5:35 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    This.
