Dealership left cap off after oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by olesmoky, Feb 5, 2023.
Thread Status:
Not open for further replies.
  1. Feb 5, 2023 at 10:58 PM
    olesmoky
    olesmoky [OP] Member
    2021 Tacoma trd
    Alright I’m going to start this off with I should have checked, but back in November I got an oil change at the local Toyota dealership and found out today that when they added new oil they never put the cap back on. I recently made a trip from El Paso to Houston and on every road sand was poured to stop ice buildup. There’s some discoloration to the oil and a good amount of sand on the dipstick when I pulled it and there was sand ever other check I did which was about 6 times. How much hell should I raise in the dealership and what long term consequences could this have on the engine because it was run thousands of miles like this.
    Ive been using the free oil changes since I purchased the truck from this dealership
  2. Feb 5, 2023 at 11:08 PM
    chinoxmk22
    chinoxmk22 Well-Known Member
    Mario
    2023 Tacoma
    surprised it’s still running with sand in the internals. I’d escalate all the way up to the dealership owner. They’ll probably give you a hard time to prove it since it’s been months.
    SH10151, Wulf and cryptolime like this.
  3. Feb 5, 2023 at 11:12 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I would contact them right away. it may be hard to prove it was left off but hopefully you got some photos. Any time of dirt of sand is going to prematurely wear out all sorts of things. thinking of this is like sand getting into the intake x1000. You should have no sand visible on your oil dipstick. It could be grounds for a new engine. One time long ago we had a mustang and the oil plug was left off causing as you expect catastrophic engine failure. They put in a new engine. I would expect something similar here as there is no way they are going to get all the sand out without pulling the engine apart is my thought. Dirt/Sand in engine is no good.
  4. Feb 5, 2023 at 11:14 PM
    nudavinci64
    Robert
    also if its been recent it will be easier. I had a recent brake job done and they forgot to put the cap of my brake resi back on. I drove 8 hours and noticed it before going into the desert (thankfully). I took it back and had them look it over and put in new fluid and flush it all out. If its been awhile as @chinoxmk22 noted it will be harder as they now can find a way to wiggle out of it and they will try. But one thing to remember is they have insurance for things like this.
  5. Feb 5, 2023 at 11:19 PM
    MGMDesertTaco
    lol, almost as good as the other dude that didn't get a filter with his oil change.
    I would politely bring this to Toyota corporates attention and explain and express your concerns. Corporate will want proof from the dealer's tech. Then I would politely bring this to the service department manager's attention, have them document it and then ask them to change it again for free.
    See if Toyota corporate will kick down an extended warranty for free. Then do your own service like the rest us or find another dealer. :boink:
  6. Feb 6, 2023 at 1:59 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    New engine.
    69 Jim and Taco22trdor like this.
  7. Feb 6, 2023 at 4:28 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    That sucks. It's stories like this that keep me doing my own service work.
    MR E30, Tacomod, Anton338 and 15 others like this.
  8. Feb 6, 2023 at 4:32 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Sorry to hear that. With the time that’s pasted it’s probably going to be tough to prove but maybe they’ll admit it was them.
    I must be lucky with the dealer I go to. They check/show the oil the dipstick and that the oil cap in on in front of customers. Maybe they had something similar happen and this is their SOP now.
    Big tall dave and 22Coma6MT like this.
  9. Feb 6, 2023 at 4:33 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    not intended to be critical of you but i'm curious if you lifted the hood between november and early february, maybe to check the oil?
    i check that the oil fill cap is tight when i check the oil and i have found it loose in the past and had to tighten it.
    i recall another thread where someone had the same issue. maybe the dealer is not tightening the cap enough, and it is vibrating loose and falling off...?
    i also had a bad experience with the dealer doing the first oil change. afterward there was a small oil leak around the filter housing, the clips for the air filter cover were not tightened, and the cover not placed back over the positive battery terminal. it just tells me they did not complete the final visual check of their work before sending it. i always have and will do my own oil changes and maintenance.
    i won't return to the dealer for anything other than warranty or a recall, both of which i hope are never needed and why i bought a toyota.
  10. Feb 6, 2023 at 4:35 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Best of luck!!
    i feel for you !
    This is going to be so hard to prove .
    A few days I could see but not opening the Hood for months.
    Chew, The hammer and OffroadToy like this.
  11. Feb 6, 2023 at 5:23 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Yet another reason to take 30 minutes and DIY.
  12. Feb 6, 2023 at 5:27 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Lesson learned. Tough one though
    OffroadToy likes this.
  13. Feb 6, 2023 at 5:50 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    No way it has been off all that time. You would have had a check engine light on for lean codes, due to the massive vaccum leak, from the cap being off.
  14. Feb 6, 2023 at 6:09 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    :worthless:
    The hammer likes this.
  15. Feb 6, 2023 at 6:38 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Take it to your nearest reputable garage in the future, no need to go to dealer unless you have warranty issues. Just keep your receipts just in case. I have been doing this for years and saved a lot of money compared to the maintenance prices of the dealer. My dealer is 2 hours away so it is good to get the maintenance closer to home. just saying
  16. Feb 6, 2023 at 6:39 AM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    One thing that most people forget is that even though you didn’t screw up (supposedly), neither did the service writer or the service manager.
    manners and polite, but firm communication go a very long way with everyone that you will be involved with for your situation.
    Side story that proves this, my GF and I have a shared checking account. I checked it last year to see that she wrote a check. Odd. She deposits money into the account. I pay joint bills out of the account. The check number was off too. Long story short, a lot tech at the Toyota dealership stole two checks from two check books out of her center console (I know…) and cashed them that day.
    I politely explained the situation to the service manager and he personally checked the cameras and found who did it and gave me the info. Legally, he didn’t have to do any of that. He then gave the deputy the info quickly and easily. Took 4 months to get the videos from the bank because they wanted warrants.
    more flies with honey than vinegar.
  17. Feb 6, 2023 at 6:53 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    This is ALL on the OP for being so negligent as to not even check the oil level at home, so I have to ask, what was OP thinking?
    Anyone can make a mistake, and someone has to supervise or do a QC check on all the work done to one’s property.
    A plumber can leave a leaky pipe underneath the sink, a HVAC tech can strip/leave cabinet screws on the ground, so unless you’re a total Willy-nilly, someone needs to do an inspection.
    That said, I’ve seen oil filler caps left off with no apparent consequences, and it’s too late now anyway. All that can really be done is first and foremost learn something from this, hope for the best and not lose sleep over it.
    na8rboy likes this.
  18. Feb 6, 2023 at 6:55 AM
    23TacoSR
    23TacoSR Well-Known Member
    A reputable Toyo store will take your word for it.
    If I am not the one doing the LOF, I check the cap, the oil level and the undercarriage for oil leaks later that same day.
  19. Feb 6, 2023 at 6:56 AM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    I love some good victim blaming.
    MR E30, tacomataco2 and Reggie4x4 like this.
  20. Feb 6, 2023 at 7:19 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    With all due respect to the OP, if it were my call at the dealership I wouldn't honor it either. Not after that much time has passed.
    tcjacado and na8rboy like this.
Thread Status:
