Dealership Oil Change Fail: What should I do?
Discussion in 'Arizona' started by Dunkoma, Jan 2, 2014.
  1. Jan 2, 2014 at 2:22 PM
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
    Tacoma TRD Sport 4x4
    Custom Avid Sliders, AFE Intake, Painted Magnaflow Exhaust, Debadge/Plastidip badges, Icon Extended Travel C/O + 2" Rear Shocks, Icon AAL, Sway Bar Delete, Bar caddy console organizer
    Wowww
  2. Jan 2, 2014 at 2:39 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
  3. Jan 2, 2014 at 2:43 PM
    Aw9d
    Aw9d That one guy
    Az
    This exact same thing happened to me at Big Two.
    Bitch, get a full detail inside and out and make them replace any parts that are damaged. I had them replace the belt and alternator on mine after this.
  4. Jan 2, 2014 at 2:44 PM
    Aw9d
    Aw9d That one guy
    Az
  5. Jan 2, 2014 at 3:09 PM
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
    Lmao - ya looks like pretty much the exact same scenario
  6. Jan 2, 2014 at 3:19 PM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    I'm glad I saw this. I now know how to keep from making a mess when doing my oil changes. What's the special tool number for the Dunkin Donuts cup?:D
  7. Jan 2, 2014 at 3:21 PM
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
  8. Jan 2, 2014 at 3:23 PM
    whahahajr
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
  9. Jan 2, 2014 at 4:38 PM
    05Aztacoma
    05 Tacoma 4x4
  10. Jan 3, 2014 at 6:28 PM
    tacosunday
    tacosunday GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Haha I did this to myself one time. I was wasted though.
  11. Jan 3, 2014 at 6:36 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Somebody got some loaded pistol mags stolen, that was a good thread.
    As for OP:
    I'd let them know, just as a friendly reminder. Maybe have em clean it. Agree with everyone else.
  12. Jan 5, 2014 at 4:08 AM
    OldV12
    OldV12 TRD
    Rodrigo
    Glendale, Arizona
    Silverstreak TRD OR 4x4 DCSB
    Stock for now :)
    Maybe you should change your oil yourself next time :)
  13. Jan 5, 2014 at 4:45 AM
    Lastplace
    Lastplace Well-Known Member
    Wonder if the cup idea would work on my daughter's 4runner?
  14. Jan 5, 2014 at 2:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Cup, hose and a water bottle....
    What makes the most sense though is to simply use an empty oil bottle saved from the last oil change.
    You need to transfer the oil into a container for recycling anyways... can't just pitch the cup in the can.
  15. Jan 10, 2014 at 8:11 AM
    #35
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Andrew, when I worked at Schumachers, lot attendants has been known to steal jewelry, medicine, guns, whatever they wanted. You sign a waiver when you sign your truck for service stating that the dealer is not liable for those items and to remove them before you leave it.
    This is what you should do, the tech should at least know he fucked up. Why they use a cup and didn just funnel it to a catch can on the ground is beyond me. Better yet why didn he drain the oil before he removed the filter?
  16. Jan 10, 2014 at 8:15 AM
    #36
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    you are on Point!!! I have learned that lesson a few times! Mandatory you do a walk around... Even when i work on things i do a double check!
    Not too bad.. just some oil over spray... they will do a clean i am sure..
  17. Jan 10, 2014 at 8:31 AM
    #37
    speedydave
    speedydave Got Boost?!?
    Dave
    Hickory, Nc
    Ecoboost
    There is oil trapped in the filter in the v6, it's even in the factory service manual to use something to catch the oil, that is why there is a drain hole with a nipple.
    It seems to me, that this isn't something some poor schmuck shouldn't lose his job over.
  18. Jan 10, 2014 at 8:33 AM
    #38
    speedydave
    Dave
    Hickory, Nc
    Ecoboost
    They use oil in bulk, there usually aren't any left over oil bottles.
  19. Jan 10, 2014 at 8:38 AM
    #39
    Phil Dammit
    Your Mom
    Tempe, Arizona
    If there is a drain hole with a nipple all he had to do was let it drain into the catch can once the truck was in the air. replace the filter and then spray with brake cleaner.
    Dude aint gonna lose his job over that. Trust me, I was a line tech for 4 years. He will get a verbal, maybe a written warning, but he aint gonna lose his job over it. However, the dealer should be informed that this happened so that it does not happen again.
  20. Jan 10, 2014 at 6:40 PM
    #40
    Rich91710
    Rich
    Los Angeles
    08 Base
    I was referring to options for DIY.
