Dealership Oil Change Fail: What should I do?
Discussion in 'Arizona' started by Dunkoma, Jan 2, 2014.
  1. Jan 10, 2014 at 6:41 PM
    #41
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    Andrew, what was the outcome??
  2. Jan 10, 2014 at 7:02 PM
    #42
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Look at it as a learning experience. This is exactly why alot of us here recommend doing the oil changes yourself... even if they are free. Over the years here i've read thread after thread on botched dealership oil changes. But hey, look at the bright side... at least they actually put oil back in and hopefully changed the filter. :rolleyes:
    Install a section of 5/16" (id) hose with a clamp to the drain nipple on the bottom of the catch basin... problem solved. :)
  3. Jan 10, 2014 at 7:10 PM
    #43
    TR90125
    TR90125 Well-Known Member
    North Texas
    2013 DCSB TRD Sport
    Bone stock for now....
    I'm late to the thread, but I wouldn't waste my time going back to the dealer. Shit happens, but I can't think of anything they could offer that would make it worth my time driving back there, dinking around waiting to talk to the manager, talking to the manager and hoping he isn't a dick about it just to get a free oil change from the same effn place that effed up the last oil change. I still have over a year of free oil changes and I'm doing them myself anyway, mostly just to avoid the whole "going to the dealer" waste of time.
  4. Jan 10, 2014 at 7:12 PM
    #44
    grrillA
    grrillA Well-Known Member
    Long Beach, CA
    '99 3.4L 4x4
    before I take the truck back from the dealer, I always give a walk around and open the hood and double check their work ( if possible ).
    they are human
  5. Jan 10, 2014 at 7:21 PM
    #45
    seedless024
    seedless024 Well-Known Member
    norman
    SL,UT
    01' TRD ext cab white
    i think you should take it back and make them aware. the only way to correct a fuck up on the techs part is if he knows he fucked up. what if you never took it back, he did it again to some other victi and the victim he did it to didnt notice and ruined something more important... thennnnn he might loose his job
    im just sayin the tech cant "fix the problem" if he didnt know there was a problem to begin with. but he shouldnt loose his job over it.
  6. Jan 10, 2014 at 7:23 PM
    #46
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    This
  7. Jan 11, 2014 at 1:17 PM
    #47
    OldV12
    OldV12 TRD
    Rodrigo
    Glendale, Arizona
    Silverstreak TRD OR 4x4 DCSB
    Stock for now :)
    Then again the tech should double check everything before closing the hood , ALWAYS. Its his job as a tech. What my master/instructor would always tell me. "In a rush or not it never hurts to double check under the hood, better that than having a customer coming back to chew you out".
  8. Jan 11, 2014 at 4:09 PM
    #48
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Bingo
    Had an exhaust leak in my '94. Manifold was warped. Dealer replaced it, I drove the truck home, next day went up Cajon Pass to visit a friend.
    Noticed steam when I got off the freeway (it wasn't overheating).
    The radiator cap was gone.
    I found it, tucked between the head and the distributor.
    ANY cap that I remove when I am working on a vehicle (and I never remove more than one cap at a time) gets placed on top of the hood latch.
    I can't forget it because I can't close the hood without moving it.
  9. Jan 11, 2014 at 4:14 PM
    #49
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I'm guessing the tech couldn't find his Dunkin' Donuts cup and knows he left it in an engine compartment. Again.
  10. Jan 11, 2014 at 4:17 PM
    #50
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
    Tacoma TRD Sport 4x4
    Custom Avid Sliders, AFE Intake, Painted Magnaflow Exhaust, Debadge/Plastidip badges, Icon Extended Travel C/O + 2" Rear Shocks, Icon AAL, Sway Bar Delete, Bar caddy console organizer
    Hahaha that's awesome - well not really, but ya
    ^^^^ agreed
    I agree with phil I really don't think anyone would lose their job over this, especially because I keep hearing about this happening to other people. I'm not the type of person to go in their all angry and demanding, but as most people have said I will go into their and let them know, and just have them inspect the belts and make sure every thing is still in good condition. I haven't been yet because it's inconvenient going there - but I need to get my touch screen checked out because it's a little glitchy so why not bring it up.
    Don't know yet, haven't had the time but I'm taking it in next weekend so I'll post what they say.
    I think it's worth it. I checked it and everything looks fine but I spent too much $$ on this truck to not double/triple check everything, and if they hook up my next oil change in the process I'm not going to complain about it. I use synthetic so it always costs me a little extra even though I'm still within the free 2 year period.
    I'm more interested to see what they would have to say about it at this point. If I can I prefer to do stuff on my truck myself, if its for anything off road I'll probably go to sierra expeditions or sdhq, or just set up a mod day; but with my warranties I know i'll still be going to the dealership once in a while and I want one that will at least own up to the mistake and give me good customer service so I'll keep coming back.
    So ya basically this^^^
    And this^^ because it definitely shouldn't have been a rush job - they had my truck all day.
    thanks for all the feedback dudes
  11. Jan 11, 2014 at 4:18 PM
    #51
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
    Hahah that was one of my first thoughts when I saw the cup, that guy was probably like SHhit! hahaha
  12. Jan 19, 2014 at 8:51 PM
    #52
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
    UPDATE:
    Went to the dealership, I started hearing a high pitched hum in the belt - also noticed squeaking in my rear brakes; very loud when going down a hill under 5mph.
    Had an appointment to have it looked at and asked for the service manager right away. Tempe Power Toyota :thumbsup: :D
    He came right over, i showed him the dunkin donuts cup that was shredded and he said they would replace the serpentine belt, note who made the mistake :eek: and check everything out. He took the truck out and onto the highway with me to double check the braking and make sure there wasn't anything else wrong. He also heard the whistle that I get when going 50+mph hours at times. He didn't at first but took it on a long drive to figure it out and duplicate the issue; even with people back at the dealership blowing up his phone. He personally wrote down everything in detail when we got back and it was all finished later that day.
    Ultimately - they washed it, gave me the new belt, took advantage of 2 TSBs and replaced the rotors and rear braking system worth about $500 + ordered the new strip for the front grill that caused the whistling. All my research before going to the dealership didn't bring up any results about the TSBs being for 2013's, just 2012's but it sounds like it's rolled up until the newer models.:D
    On a side note he also told me the same goes for the windshield wind noise TSB for the 2013's; they just replace it (this noise is much louder then the one that's caused by the grill). He was also was about to order a new replacement for my head unit because for two weeks it wouldn't work at startup. It was when it got pretty cold out here but it would take 15 minutes until the touch screen became responsive. This problem stopped a few days ago so I figured it wasn't worth it unless it acted up again.
    Anyway - I just want to make anyone who reads this aware of my good experience at this dealership, and to take advantage of the 2013 TSBs if you have one and are having similar issues.
  13. Jan 19, 2014 at 9:42 PM
    #53
    Phil Dammit
    Your Mom
    Tempe, Arizona
    This all sounds about right
  14. Jan 20, 2014 at 8:10 AM
    #54
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
    Lol thanks Phil
  15. Jan 20, 2014 at 8:17 AM
    #55
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well, the constant on this site is that the dealer is out to fuck you. That's the vibe I get from most users. Your response is exactly what most visits are with the dealer. You go in with an open mind, take the time to show and ride with the service adviser about your complaints, which in turn allow the tech to do his job right, thus allowing you to leave happy and pleased knowing your vehicle has been repaired.
  16. Jan 20, 2014 at 8:18 AM
    #56
    Dunkoma
    Dunkoma [OP] <3
    Andrew
    Phoenix, AZ
    Truth ^^ why wouldn't they do everything possible to help me out? Especially while I'm still under warranty haha.
  17. Jan 20, 2014 at 9:41 AM
    #57
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Marysville
    09 TRD Sport 4x4 BSP DC LB
    OME Iift, Dakars, All-Pro UCAs, Front/Rear protection, LEDs
    I have always done my own maintenance on mine.
    But to help you out, I took a piece of heater hose and connected it to the nipple underneath the oil filter and ran it down to the driver side wheel well, this way the oil will drain down through it.
    Just take note, and now you know why people DIY
  18. Jan 20, 2014 at 9:44 AM
    #58
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Guess you didn read the update :facepalm:
  19. Feb 6, 2014 at 4:25 PM
    #59
    HandOfGod
    HandOfGod Well-Known Member
    Tacoma TRD 4x4
    Stock
    Good to hear the dealership took care of you.
