Dealership says 5W-30 Mobile 1???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wishbone1965, May 21, 2013.
  1. May 22, 2013 at 4:24 AM
    #41
    Wishbone1965
    Wishbone1965 [OP] Well-Known Member
    Texas
    2013 SR5 4x4
    Would uphill be better than flat?
  2. May 22, 2013 at 4:26 AM
    #42
    Wishbone1965
    Texas
    2013 SR5 4x4
    Did some reading on this and some people are saying that its possible for the small particles or shavings can get caught up in this. Anyone know about this?
  3. May 22, 2013 at 6:24 AM
    #43
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    :eek:
    Oops, major brain fart! Edited....
    Thanks! I think I was half asleep last night. :D
  4. May 22, 2013 at 6:35 AM
    #44
    Janster
    Jandy
    Lancaster, PA
    I haven't had any issues with it.
    If you're thinking about buying one - It does drain slower because the hole is smaller. You just open it up and walk away for 15 minutes while it drains. No biggie. Because the valve screws up into the oil pan, there is a small amount of oil that doesn't get drained because of the threads that stick up above the pan (inside). So - if you're one of those guys who's gotta get every last drop of old oil out...you won't want to buy this thing.
    If shavings get caught in it, you'll probably notice it'll drain even slower than normal. You can remove it and I would think...you can easily clean it. It's not a complex thing. I've never had mine off in 5 years. Hmm I might take mine off just to install a new gasket.
  5. May 22, 2013 at 6:46 AM
    #45
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    If you have particles big enough to clog that up in your engine oil, you've got much larger problems than figuring out how to drain it.
    As for your orig. question... Each dealer I'm sure uses whatever oils they want to. Yours very well may use Mobil 1, but another dealer may use some other brand.
  6. May 23, 2013 at 1:03 AM
    #46
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    ^^^ Exactly. Large Particles or Shavings in the oil? There should not be any.
  7. May 23, 2013 at 4:18 AM
    #47
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Flat is fine. The drain plug is at the lowest point on the engine so you will get "most" of the old oil out of the engine. It is impossible to get all of the old oil out of your truck even if you were to turn it upside down and shake the piss out of it :)
    Besides that's not really the point. You just want to get the old oil out and put the new clean oil in with a new filter. As far as the drain valve that people are using it looks fine although I don't personally use one. I can see the benefit of having one but it just looks like one more thing that could possibly be knocked off if you do happen to take it off road. I have nothing against it but I just personally take the plug out and let it drain then put the new oil in.
    Just whatever you do... make sure you put a small bead of oil around the gasket on the new oil filter before installing it and for god sake make sure the "old" oil filter gasket is still on the old filter when you take it off and not still stuck to where the filter sits on the engine. You will know if you miss this step real quick because you will have one hell of a clean up job :D
    As other's have said, If you have particles big enough to stop up the drain hole on that valve you have much bigger problems to worry about. You should never have any large (much less small) particles coming out of your engine (ever!).
    Good luck and enjoy wrenching on your truck!
  8. May 23, 2013 at 5:24 AM
    #48
    Wishbone1965
    Texas
    2013 SR5 4x4
    Thanks so much of all the good information!
  9. May 23, 2013 at 5:53 AM
    #49
    RearViewMirror
    Craig Christ
    My pleasure!
