Dealership screw up
Discussion in 'Technical Chat' started by iliketurtles, Feb 1, 2012.
  1. Feb 1, 2012 at 4:40 PM
    iliketurtles
    iliketurtles [OP] Well-Known Member
    I got my oil changed at the dealership today and the tech failed to noticed the case of synthetic oil in the truck AND the note on the paperwork saying i brought oil. He put a synthetic oil blend in it and i had them drain it and re fill with my mobil 1. Will the little bit of blended synthetic left in there hurt anything?
  2. Feb 1, 2012 at 4:41 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    no it will be fine
  3. Feb 1, 2012 at 4:43 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Dumbasses abound. Didn't see it or read the paperwork ? You will be ok
  4. Feb 2, 2012 at 10:08 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    So when I get my truck and start letting them do the free oil changes..should I just buy a case of oil and tell them to put that in?
  5. Feb 2, 2012 at 10:14 AM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    in my opinion, your engine is forever ruined. i would be pissed!! :boom:
  6. Feb 2, 2012 at 10:18 AM
    neilvan
    neilvan Well-Known Member
    Holy crap, get a lawyer, how dare someone make a mistake!
    Seriously though, other than costing you a little bit of time you won't have any problems.
  7. Feb 2, 2012 at 10:20 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    omg you need a new motor...who the hell expects a motor to run on dino oil, its never been done before!
    just kidding youre a okay
  8. Feb 2, 2012 at 10:44 AM
    iliketurtles
    I told the guy not to worry about it. I don't like when people jump down my throat for making an honest mistake (although it's pretty effing sad he did something so absent minded), so I was nice to the guy about it.
    I've just heard a million times you aren't supposed to go back so conventional oil after using synthetic, and didn't want to jack anything up. Thanks guys.
  9. Feb 4, 2012 at 10:46 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Contrary to popular belief it is ok to mix both conventional and synthetic oil together. Early oils did have problems but todays oils are very much compatible with each other and will not cause issues (From old mechanics and from chemists)
    Sent via Tapatalk(Bold 9900)
  10. Feb 4, 2012 at 9:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I've gone from conventional to synthetic, back to conventional. No problems. It's a myth. A synthetic blend is just the two types mixed together, nothing's gonna happen.
  11. Mar 26, 2012 at 9:15 PM
    iliketurtles
    I've put a few thousand miles on the truck since that oil change, and the engine still hasn't exploded. I guess it was alright. I'm just worried what they'll forget/mess up next time. Maybe it'll be something exciting like forgetting to put oil in at all.
  12. Mar 26, 2012 at 9:37 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    I still have my first truck, a 74 Datsun PL620, I don't even change the oil anymore... Just add a quart every now and then. 476,000+miles later, still runs like a champ. Just add some marvel you will be all good. I'm serious about that but don't recommend it.
    Your truck will be fine. I have run every oil known to man over the years and you are gonna be just fine. You can run the cheapest dino oil as long as you change it regularly. I run syntheics with everything and add lucas to it, and a lil marvel. Never had any internal engine failure on any vehicle.
    What dealership BTW, I work in auto service and always good to know what dealer forgot. They probably just put in the factory stuff on tap which is no biggie, but I have seen horror stories like not filling up a car or forgetting stuff.
  13. Mar 26, 2012 at 9:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    DIY. Its easy as can be, and there is a write up on here on how to do it.
  14. Mar 27, 2012 at 8:38 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I do my own oil changes but still worry about the dealership changing it by mistake when the truck is in getting worked on for something else. Just in case I put stickers at the fill and drain holes to let them know synthetic is being used...
  15. Mar 27, 2012 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Trust me....They dont give a shit about the stickers. They'll use whatever the guy feels like at the time.
  16. Mar 27, 2012 at 8:53 AM
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    When I lived in a condo I couldn't change my own oil (living in Washington D.C. sucked). I found a mechanic that would change my oil for $10 if I brought him the oil and filter. After one oil change I realized he'd keep my synthetic and mobil 1 filter and put generic oil and a no name chinese filter on. I drove back the next day and he wasnt there, but I made the other mechanic drain and refill and put on the my filter that were both "coincidentally", according to the mechanic, sitting in the mechanics office. The funny thing is I had written on the box of oil and it still had my handwriting on it.
    Luckily I've since moved to the best coast and have a nice garage to do my own maintenance...
  17. Mar 27, 2012 at 8:54 AM
    oldstick
    oldstick Medicare Member
    GA
    OK, I'll bite. What did I miss?
    What is it that is so important about Mobile 1 vs the other brand synthetics (or blends for that matter)?
  18. Mar 27, 2012 at 9:11 AM
    bamma
    Spokane, WA
    I actually think Valvoline is the best right now.
  19. Mar 27, 2012 at 3:14 PM
    OffroadToy
    here ya go...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/58460-best-motor-oil.html
    ^ lol^ Just noticed that was the only post the guy that started that thread ever made and it went 24 pages with 472 replies!
