Dealership sheered a lug, should I have asked for a loaner until replacement?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IkemanTx, Apr 1, 2017.
  1. Apr 1, 2017 at 4:47 PM
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    This actually happens most of the time when the tech doesn't take the time to make sure the nuts are threaded on straight when putting them back on. Hits them with the impact crossthreaded and keeps going hoping it will make it to the bottom before breaking off.
    If it does he get away with it the next poor sucker will break the stud off trying to remove the crossthreaded and galled to hell nut. The new wheels take a little more care to thread the nuts on straight due to having deep holes around the nuts and tech are pressed for time.
    I wrenched for 20 years and have been the "next poor sucker" many times. I always threaded by hand to avoid this.
    TRDSport10, tomwil, Pittrider and 2 others like this.
  2. Apr 1, 2017 at 5:07 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    While we are talking lug nuts and studs.
    Chrysler actually had it right back before 1971 when that had regular righthand lug nuts on passenger (right) side and lefthand lug nuts on the driver (left) side.
    On the right side the lug nuts tend to want to tighten themselves but on the left side with righthanded threads a loose lug nut will tend to want to loosen even more.
    Left hand lugnuts on the left side will want to tighten if loose, and will never continue to loosen and fall off, it's a fail safe method.
    My 70 Challenger has lefthand lug nuts.
    Apparently not as big a problem as Chrysler originally felt since they conformed with everyone else starting in 1971.
    I think there are still large Semi trucks that use lefthand lugs, but don't know for sure.
  3. Apr 1, 2017 at 5:16 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Assemble any kids bicycles lately?
  4. Apr 1, 2017 at 5:22 PM
    worthywads
    nope, left hand nuts?
  5. Apr 1, 2017 at 5:26 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Yes.... on one pedal though, the pedal to the cranks are left and right threads.
    TRDSport10 and ABA180 like this.
  6. Apr 1, 2017 at 5:34 PM
    balljoint
    Dave
    Ontario
    '18 DCLB
    Preventing the pedaler from unscrewing his own pedal.
    File IFR[QUOTED] and TRDSport10 like this.
  7. Apr 1, 2017 at 5:38 PM
    16 SR5
    16 SR5 Member
    Paul
    south central Kansas
    2024 DC OffRoad A/T Hybrid
    It's the oil-based carrier in the anti-seize that is the lubricant(3-7% by weight paraffin based oil). Here's what Permatex says about their anti-seize compound:
    "Permatex® Anti-Seize Lubricant Category:
    Specialty Lubricants - Anti-Seize
    A highly refined blend of aluminum, copper and graphite lubricants."
    Maybe a better choice for stopping corrosion to apply an anti-corrosion (Boeshield or LPS3) compound to the fastener after it is torqued dry
  8. Apr 1, 2017 at 5:43 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I'll keep using it, haven't had any problems in 35 years on any of my trucks or my auto-x car.
    File IFR likes this.
  9. Apr 1, 2017 at 5:52 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This. They are also marked L and R..
    File IFR[QUOTED] likes this.
  10. Apr 1, 2017 at 6:04 PM
    Bishop84
    Bishop84 Well-Known Member
    My dealership would install an aftermarket stud or remove one from a hub from a lot tacoma before letting any truck leave the shop like that. Hell we have 2nd gen hubs lying around.
    I would have fixed this before the customer was even alerted to it.
    I don't get how some dealers have Toyota mentality and some do not.
    daddy_o likes this.
  11. Apr 1, 2017 at 6:15 PM
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    Give that man a cigar.......think Wal-Mart " techs ".....and go from there.
  12. Apr 1, 2017 at 6:26 PM
    IkemanTx
    IkemanTx [OP] Well-Known Member
    Isaac
    2017 4X4 SR5 Tacoma
    I think they just wanted to go home, honestly. It was 3:15 and their service department closes at 3:00 on saturdays.
  13. Apr 1, 2017 at 6:31 PM
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    My dealership has never sheared a lug but the last 2 times getting them to swap out from my oem tires to my mud tires they have messed up one of my tpms. They replaced them free of charge but the last time they messed up one of my tpms they didn't have one in stock and had to return later to get a new one installed.
    TheCookieMonster likes this.
  14. Apr 1, 2017 at 6:36 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    I took my taco in for service and had them rotate my tires while I was there. I checked my lugs when I got home (I have 5 spline lugs and 1 security lug on each wheel) and either my torque wrench is off or they over torqued my lugs because there is no way they were at 85 ft lbs.
  15. Apr 1, 2017 at 7:02 PM
    #35
    whec716
    whec716 Well-Known Member
    Houston
    2016 Inferno TRD-Offroad
    Discount Tires overtightened/crossthreaded a lugnut on my wife's subaru. We couldn't get it off. They sent us to a tire repair place on their dime who replaced the crossthreaded lugnut and another in about 1 hour.
  16. Apr 1, 2017 at 7:15 PM
    #36
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    I disagree. I would definitely take the truck off some sweet jumps before it gets fixed. That way when it breaks, I can blame the dealer, then I can demand a new truck at least 1 trim level above.
    :D
  17. Apr 1, 2017 at 7:17 PM
    #37
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    I drove around with 5 lugs for 5k miles ... i ddint realize it was missing til the next oil change when they notified me about it. I quietly let them know they are the only ones who service my truck and they replaced it
  18. Apr 1, 2017 at 7:29 PM
    #38
    File IFR
    Central MA
    Same here. I'll keep applying it on my spark plugs changes as well..... Never had a plug back out yet :D
    TRDSport10 likes this.
  19. Apr 1, 2017 at 7:34 PM
    #39
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    They use a torque stick in order to torque your lugs with an impact gun. What do you think they do, just take a guess on the lugs' torque specs?
  20. Apr 1, 2017 at 7:36 PM
    #40
    Idig63
    Idig63 Well-Known Member
    Seattle
    2017 TRD OR 4X4 DCLB BLACK
    ^^^^^ Common (unfortunately) but not really loaner worthy. But they should fix asap.
