Dealership Upsells
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lucky Dog, Jan 6, 2020.
  1. Jan 6, 2020 at 8:02 AM
    Lucky Dog
    Lucky Dog [OP] New Member
    2015 Black Tacoma
    I was making a dealership appointment for my last warranty Oil change at 60k today. The service guy starts talking about Tranny flush, and Brake system flush, all out of warranty stuff. My Tacoma is a 2015 Sport 4x4. Are these things really necessary or just the usual dealership wallet dip?
    I will be doing my own maintenance after this last trip to the dealer, which has always been my plan....
  2. Jan 6, 2020 at 8:05 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Brake flush you can easily do yourself if you buy the proper tools for it. But yes, at 60k it would be a good idea to flush out the fluid. As for the transmission flush, it’s up to you. Many argue against it, many say do it. Reason is because when you flush it you could be pushing clumps of whatever through the transmission fluid lines and potentially clog something up and damage your transmission later on. I’ve always just changed the fluid and filter if applicable, and called it a day. Never had an issue doing that with cars past 200k miles. Overall, at 60k both of those are good preventative maintenance measures to take.
    06Tacooo likes this.
  3. Jan 6, 2020 at 8:14 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Can I suggest on the Transmission "Flush" ... do only the drain and refill. Lots of info here on the process as well videos as well. As for the brake flush - like above - easy to do and rewarding knowing the brake fluid is fresh and has not moisture in the fluid.
    Good Luck!
    TacoBreaker, Muddinfun and whatstcp like this.
  4. Jan 6, 2020 at 8:15 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Since I have been retired as a mechanic, I let Toyota do my oil changes. With that said I ALWAYS use a coupon and for the $20 or 25. its not worth my time to do it, plus I get a free wash! As for ALL the other stuff, Toyota has it in ALL their dealers computers on what to suggest at certain mileages. I have a 2012 that was new when I got it and it has 99k on it. I get the oil and filter done every 5k and that's it.
  5. Jan 6, 2020 at 8:18 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    I have stayed current on Tranny service, fluid changes...
    Piece of mind.
  6. Jan 6, 2020 at 8:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    At 60k it's worth changing all fluids IMHO, specially if everything but oil is original.
    Trans just drain/fill as already suggested. I do mine at 30k intervals, because cheap/easy. (I have a dipstick)
    Skyway likes this.
  7. Jan 6, 2020 at 8:31 AM
    Skyway
    Ande'
    St.Pete
    CWB: I need Tires!
  8. Jan 6, 2020 at 8:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    You're driving too much.
    Skyway[QUOTED] likes this.
  9. Jan 6, 2020 at 9:32 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    you can do transmission, engine oil, differential, brake fluid, power steering for under $150 yourself.
  10. Jan 6, 2020 at 1:37 PM
    Fly Skids Up!
    Fly Skids Up! Well-Known Member
    Marc
    Fleming Island, Florida
    2014 regular cab, 4x4, 5 speed manual
    Fog lights, Weather tech floor liners, rear window tint, Gator pro tri fold cover and bed liner, Fuel Anza 16x8 wheels, Cooper Discoverer 265/70-16 AT3 4s, N-Fab nerf bar steps, The ultimate headlight upgrade, Pioneer speakers and amp, sound deadening, Bilstein shocks, Back-up camera, Class III trailer hitch,
    Funny you slay that. I'm too a retired mechanic but do all my own maintenance, even when the first two years was free. Some of the clowns I've seen in the industry, I wouldn't let them take out my trash.
    Rambo54 and Muddinfun like this.
  11. Jan 6, 2020 at 1:46 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I have a 2015 and my diy brake fluid flush was under $8. I also did a Tranny pan dump for less than $40. Easy to do with info from TW.
  12. Jan 6, 2020 at 3:19 PM
    Tacomataco12
    Tacomataco12 Well-Known Member
    I just do the turkey baster suck and drain every oil change on the brake and power steering fluid.:anonymous:
    Lester Lugnut likes this.
  13. Jan 6, 2020 at 5:02 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    i'm just curious, and yes I know that killed the cat, why is that in the last ten years or so we have to do a brake fluid flush. For us old farts this was never done and we never had any problems. I'm not saying don't do it or its a bad thing, It has to be good to have fresh fluid, but back in the day . . .
  14. Jan 6, 2020 at 5:08 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    The dealer would usually do a test on the brake fluid to see what percentage of water is present in the fluid, doesn’t always need to be changed.
  15. Jan 6, 2020 at 5:10 PM
    Brianz1001
    Brian
    too much to type
    Retired one here also, it’s a different generation mechanic out there today.
  16. Jan 6, 2020 at 5:18 PM
    spitdog
    I don’t think anybody’s brakes fail if you don’t flush it. And people just adjust to fading brakes. Brake fluid does collect moisture.
  17. Jan 6, 2020 at 6:11 PM
    DG92071
    DG92071 Well-Known Member
    A company I worked for installed alarms into new and used vehicles at car lots. Each alarm was sold to the dealer for $125 installed. The dealership would in turn sell it for anywhere from $600 to $1,300 and finance it with the car loan.
    The last time my wife's car was at the dealer they recommended a new air filter for the engine. I had replaced it 4 days earlier with a new filter.
  18. Jan 6, 2020 at 6:23 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I know plenty of new and old school guys that never change the brake fluid. Just another overkill maintence item that this board gets on their soap box with.
    DG92071 likes this.
  19. Jan 6, 2020 at 6:25 PM
    Muddinfun
    Muddinfun Well-Known Member
    Going way back, most vehicles had 4 wheel cylinders and a master cylinder. Easy to replace them all. In the more recent years, there's all the ABS stuff with valves, pumps and stuff that have very high precision tolerances. Very expensive stuff that you don't want corroding up.
    Skyway and whatstcp like this.
  20. Jan 6, 2020 at 6:30 PM
    toyoblueboys
    toyoblueboys Well-Known Member
    There's a long story behind this but short story is I purchased the truck at 38k miles in 09. Its an 05 TRD Sport. Now I have 165k miles. Never changed transmission fluid. Most things i read is, start looking for a new transmission. Any suggestions? The truck runs as good as it did when I purchased it. No delayed shifting or sticking in gear. Some towing but not much. Some off road use but again not much. Most miles are all from Highway and grocery trips.
