Dealerships can't help me, I know you guys can
Discussion in '1st Gen. Tacomas (1995-2004)' started by God's Sun, Apr 25, 2009.
  1. Apr 25, 2009 at 12:39 AM
    God's Sun
    God's Sun [OP] Member
    Coarsegold, Ca
    96 tacoma 3.4L 4wd
    All Stock-All New..deck-plate, blinker, diff snorkel mods. Speed-bleaders(including clutch&load sensor). Bilstein all around. Performance brake pads and shoes. Trail and fog lights. HD u-joints. iEquus gauges-oil pressure, water temp, volts, A/F mix. Extra cab light. Bed lights. Over-sized condenser. Oil blow-back trap and filter. K&N drop-in. Extra Deep cycle battery. Performance clutch. New cooling system, oil pump, altenator...and a few more i'm sure. always adding more.
    I have a 96 toyota tacoma 3.4L 4WD.. during normal highway driving my crankshaft pulley started to come loose, lots of lights and a crankshaft position sensor code and i pulled over immediately pulled over and shut down the vehicle, after a tow home i discovered my crankshaft pulley loose. I have it ready to go back together...timing was unaffected, and my crank suffered no damage. My question is on the inner collar of the pulley that actually is in contact with the shaft has a rectangular groove in it which appears to have a set key that fits into it and the FSM calls it "pulley set key". I have called three dealerships and all they can give me is the woodruff key for the crankshaft timing gear. They say there is nothing else that goes on the shaft. So if there is no set key for it why is there a groove on the pulley..please help..i love my tacoma and take good care of it(i had not checked the torque as a maintaince procedure oops) I want to put it back right Please Help TY Justin
  2. Apr 25, 2009 at 12:46 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I have never worked on the 3.4 v-6.
    But I have worked on many bearings and pulleys. And many have the exact setup you have described. The square piece should be able to be bought at most parts stores, it should come in a long shaft that you can cut to size. you will need to measure the holes for the "key" size. I have also seen a few of the woodruff keys but on the pulley or shaft would only have a half circle cut out to fit the round side of the woodruff.
  3. Apr 25, 2009 at 2:08 AM
    God's Sun
    Coarsegold, Ca
    96 tacoma 3.4L 4wd
    Thanks for hitting me back, yeah I called my dad tonight and he said exactly what you said..I tried the hardware store today, but its weak selection, living in the foothills and all. I work with shafts and motors (eletric though) long and deal with set keys several times a week, i do A/C a for living. I was wondering why toyota can't help me, second if I have to try and fabricate a piece from stock how tight are the
    tolerances. I don't want to screw up my pulley cause i was undersize a little, crankshaft is under a lot more force than I usually deal with and I just want to get it right. Thanks again Justin
  4. Apr 25, 2009 at 10:19 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    Not sure but, I am putting this out to Chris
  5. Apr 25, 2009 at 10:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You got it right. May need to get the part from an auto pat store. Dealers probably only see the part as a complete unit. Also, May want to try a junk yard. The key should be a standard size though.
  6. May 1, 2009 at 6:27 PM
    God's Sun
    Coarsegold, Ca
    96 tacoma 3.4L 4wd
    Well I have fashioned a "key" if you will. It does seem to help a little. I never had a problem with the pulley slipping on the crank anyways. But I got it torqued down as tight as i could. make-shifted a sterring wheel pulley to prevent the motor from turning, put it in 5th and 4 low and torqued till one of the bolts holding the puller to the pulley broke, I know its tight but how tight? I have been defeated in my attempts to find a torque wrench that goes over 150lbs for a figure I can afford. I still have the smallest wobble at idle 650-750rpm. Gone with any type of load. Do you think I should replace it, I hate to drop the cash and have it just be lack of torque. If I was only at say 160-180lbs of torque could that bit I am shy give me my wobble at low RPM. What do you think? I have had balancers go bad(actualy that is the only part to go out on me on multiple vehicals, funny) So I was just wondering what imput you fine people would be able to offer. So my Dad always likes to keep me guessing, he pointed out that when No1 is TDC that slot that I think needs something in it, is at the 12 o'clock position this allows the timing mark on the pulley to line up properly with the marks on the timing cover, so have I been over-thinking this. Miles gone by will tell. Thanks once again
