Dealing With Panel Scratches?
Discussion in 'Detailing' started by IrishPilot, Oct 11, 2010.
  1. Oct 11, 2010 at 4:31 PM
    IrishPilot
    IrishPilot [OP] Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    Long story short my panel below the environmental controls got scratched up some during a headunit install. Is there a good way to get those scuffs out?
  2. Oct 12, 2010 at 7:32 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Not easily. Depending on how deep they are, some 0000 steel wool can remove some scuffs, but, you run the chance of changing the texture of the plastic. I've used this method on door panels, door sills and seat trim before with good results.
  3. Oct 12, 2010 at 10:27 AM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    about all you can do short of replacement is clean up the damage.
    If the plastic is gouged and there is/are plastic curls and/or rough edges use an exacto (NEW) blade and trim till the scratch/gouge edge is smooth and, perhaps, bevel the edge slightly so that it blends as best as it can.
    any abrasive buffing will damage the surrounding area and change the texture/color slightly. try on an are not noticable.
  4. Oct 12, 2010 at 5:34 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Got a pic??? You may have some options, just get a good pic, and post. I'll give you some ideas.
  5. Oct 13, 2010 at 9:46 AM
    IrishPilot
    MN
    Ill try to snap a pic quick when I get a chance...
