dealing with yet another noise, this one sounds like rear suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Oct 12, 2024.
  1. Oct 12, 2024 at 11:31 AM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    So now that the passenger side wheel bearing is fixed...
    I've been hearing what sounds very similar to an object in the bed bounding up and then falling back down when I drive over bumps at low speeds. Except...there is nothing in the bed. Imagine the sound a 3-foot section of 2x4 getting pitched an inch into the air and then falling back into the bed makes...almost exactly like that.
    It might be happening at high speeds as well but is being masked by road and other noises.
    Any ideas?
    Thanks.
  2. Oct 12, 2024 at 11:36 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    loose trailer hitch?
  3. Oct 12, 2024 at 6:34 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Check the shocks, make sure the rubbers are where they are supposed to be.
  4. Oct 13, 2024 at 8:11 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Is the bed loose? Search on here. Over time the composite wears down and the bed will have some play causing a noise.
    b_r_o likes this.
  5. Oct 13, 2024 at 8:47 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes check the bed for being loose. Especially the front passenger side. Go to each corner of the bed and lift up, if it's loose you'll feel it.
    Mine made a ton of noise over bumps before I finally figured out what it was..
