Dealship quoting $700+ for sparkplug replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreeByrd85, Jun 8, 2024.
  1. Jun 10, 2024 at 8:59 AM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    $800 for this job is robbery.
  2. Jun 10, 2024 at 9:38 AM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    That’s why I did it myself. Took my time and just enjoyed the process and it was fine. Couple weeks from now it will be the diffs and than tc and than transmission and than all the fluids should be cleared out and fresh since I bought the truck used a few months ago and know nothing as far as maintenance on it.
  3. Jun 10, 2024 at 9:54 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Nice job, well done. B.T.W. I do not want (in this present world) to be 40 again...
  4. Jun 10, 2024 at 10:08 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I'd get a quote from an independent Toyota friendly shop, or do it myself.
    I changed the plugs on my wife's Subaru, and people told me I had to lift the motor up past the frame to succeed. I invited some friends for mental support and advice and got it done. I literally pirouetted the coils out without moving the motor. the collective "HORRAY" was fun. I judge all spark plug changes to that event now...but no shame in farming out the work. taking a plug out of aluminum heads is not mentally healthy for me. hahaha..
    my new 2023 truck looks like NO-FUN at all. and I did the last change on my 2006 already. I won't keep it past the next change.
    Vmax540 likes this.
  5. Jun 10, 2024 at 10:20 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    We charge 2hrs labor for the 3rd gen. Sounds like good dealers are being reasonable with the labor time.
  6. Jun 10, 2024 at 12:18 PM
    FlyFisherCJ
    FlyFisherCJ Well-Known Member
    Cameron
    Twin Falls ID
    2017 TRD OR DCLB
    Aside from the video in post #15, are there any other tips and tricks you can recommend? I plan on doing this work myself soon as well
  7. Jun 10, 2024 at 3:41 PM
    Williston
    Williston Somewhat-Known Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Don't over-do it on the thread anti-seize. Same for the dielectric compound: Sparce amount on the porcelain and inside the end of the boot (if at all): None on the top metal plug terminal.
    FWIW: I don't use either one and I don't think they do it at the factory either.
    FlyFisherCJ[QUOTED] likes this.
  8. Jun 10, 2024 at 6:53 PM
    Josephray70
    Josephray70 Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    If you got big hands it will be difficult. Very tight areas on driver side, small hand dudes have the advantage on this job.
  9. Jun 10, 2024 at 7:27 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Yea I get that, I suppose I should say I wish my body worked as well as it did when I was 40....
    Vmax540[QUOTED] likes this.
  10. Jun 11, 2024 at 10:15 AM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Well I didn’t put any anti seize on mine but I did do the dielectric grease on the plug, and plug terminal and inside the boot. Hopefully I didn’t do too much.
    Stevie17 likes this.
  11. Jun 11, 2024 at 1:13 PM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    $700? Wow. I will do these all day long for $400 a pop. Line on up.
    I did mine without taking the manifold off and it can't have taken more than an hour.
    Fun bonus was cylinder #3 (center on passenger side) was a little loose and the coil pack was discolored.
  12. Jun 11, 2024 at 2:14 PM
    Williston
    You should be ok. If you use high quality plugs, like OEM Denso or NGK, the nickle-plated threads on them serve the purpose as the anti-sieze. For dielectric grease, I just put a little on the porcelain part of the plug just below the top metal terminal and a little at the end of the plug boot.
    baboltin[QUOTED] likes this.
  13. Jun 11, 2024 at 2:48 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    just who comes up with time values for the book time fee's?
  14. Jun 11, 2024 at 4:20 PM
    Bishop84
    Bishop84 Well-Known Member
    Toyota sets warranty time then 3rd party will add 20-30% as labour.
    It's far from perfect.
    b_r_o likes this.
