Death by CEL
Discussion in '1st Gen. Tacomas (1995-2004)' started by nk2k2, Sep 1, 2019.
  1. Sep 1, 2019 at 7:19 AM
    nk2k2
    nk2k2 [OP] Well-Known Member
    Virginia Beach, VA
    2003 IJM SR5 4WD
    Not literal death, but my CEL is driving me nuts.
    I've had the same three codes for months (P0441, P0442, P0446) and I am at a loss at what to do next.
    Backstory: The CEL came on a few months back. I started with replacing the gas cap. Light came on. Then replaced the VCV. Light came back on. And lastly I replaced the canister. Light came back on again. I had my local shop do a smoke test, and they replaced a few hoses that either had a hole in them or they thought was old.
    So a side note, my fuel tank was replaced along with the fuel pump. The tank was replaced because of a hole in the OEM tank from rust.
    Any help is appreciated. It's an 03 with the 2.7L.
  2. Sep 1, 2019 at 7:24 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I had the same issue with a 2004 v6, I did the 02 sensors banks 1 and 2, also. believe it or not after a few driving cycles the check engine light went off, hard to believe those are tough codes to get rid of. my last ditch effort was to run a bottle of CATACLEAN thru the gas tank was only $20 at Auto store, never had to tho
  3. Sep 1, 2019 at 7:26 AM
    BillsSR5
    bill
    2014 SR5
  4. Sep 1, 2019 at 7:52 AM
    1997tacomav6
    Denver
    I replaced both the sensors and my code went away also.
  5. Sep 1, 2019 at 7:54 AM
    nk2k2
    Virginia Beach, VA
    2003 IJM SR5 4WD
    So I’ve replaced the downstream O2 because I needed a new exhaust pipe. How difficult is the upstream O2 to replace?
  6. Sep 1, 2019 at 7:54 AM
    1997tacomav6
    Denver
    Same process, easy, if you have a 5 speed you have to remove the stick shift boot
    because the wire is tied on there with a clip on top of the transmission.
    Soak the bolts because they might be hard to break loose
  7. Sep 1, 2019 at 8:07 AM
    nk2k2
    Virginia Beach, VA
    2003 IJM SR5 4WD
    Wait, the codes that I have are unrelated to the O2 sensor. It’s talking about a leak in the evap system.
  8. Sep 5, 2019 at 5:41 AM
    yurtdweller
    yurtdweller Well-Known Member
    2003 Toyota Tacoma 2.7l
    I also have this trio of codes and am wondering what to do. Just replaced the entire exhaust system, but kept the old sensors. Should I try the new sensors? (Not a "cheap" fix if it doesn't work).
  9. Sep 5, 2019 at 5:51 AM
    Mallard386
    Mallard386 Well-Known Member
    Virginia
    2001 ext cab 4x4 4 banger 115k and counting
    TBD
    Very easy! I had the same issue and replaced my upstream o2 sensor and it fixed the problem
  10. Sep 5, 2019 at 5:52 AM
    yurtdweller
    How does one check to make sure it's the O2 sensors? I have a BlueDriver bluetooth OBDII reader. Will that help me understand if it is the O2 sensors?
  11. Sep 5, 2019 at 5:55 AM
    1997tacomav6
    Denver
    I think I paid 75-100 for the pair on eBay and fixed my issue, if I remember two different part numbers
  12. Sep 5, 2019 at 6:04 AM
    BillsSR5
    bill
    2014 SR5
    i used a small 1/8" drive ratchet with a deep socket, there wont be enough room to get anything bigger in there, its a little cramped
  13. Sep 5, 2019 at 6:10 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I thought we were talking evap problems, did I accidentally swipe into something else?
    nk2k2[OP] likes this.
  14. Sep 5, 2019 at 6:19 AM
    yurtdweller
    That's why I asked above how people can test the O2 sensors if they get this trio of codes. I have a hard time throwing money at O2 sensors when my trouble codes say nothing about O2 sensors.
  15. Sep 5, 2019 at 6:26 AM
    Mallard386
    Virginia
    TBD
    I thought I had a bad fuel canister, but I also knew an o2 senor can throw the same code so I started with the cheaper option which was the o2 sensor. I replaced it and probably after 100 miles it my CEL went away
  16. Sep 5, 2019 at 6:27 AM
    BillsSR5
    bill
    2014 SR5
  17. Sep 5, 2019 at 8:23 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I would have a smoke test done first to check for evap leaks before changing air/fuel mix #1 sensor or o2 #2 sensor. Both sensors can be checked manually at their connections for ohms resistance .05 to .07 between blue wire and black wire. If zero ohms sensor is dead. Measuring sensor performance is more complicated but can be done on some some diagnostic readers.
    nk2k2[QUOTED][OP] likes this.
  18. Sep 19, 2019 at 10:07 AM
    nk2k2
    Virginia Beach, VA
    2003 IJM SR5 4WD
    So I had another smoke test done. Looks like the gas cap is escaping bits of smoke due to the seal between the gasket on the cap and the rust built up on the filler neck.
    Looks like a steel wool and acetone will be used over this weekend. Maybe that will fix it.
  19. Sep 19, 2019 at 12:53 PM
    Black DOG Lila
    Virginia
    Get the new cap from Toyota dealer parts dept dont waste your money on aftermarket caps. Polish the neck well and apply vaseline.
  20. Sep 19, 2019 at 1:01 PM
    nk2k2
    Virginia Beach, VA
    2003 IJM SR5 4WD
    I already replaced the new cap with OEM. Any suggestions on how to polish the neck? Good call on vaseline.
