Death Valley Off-Road Adventures
Discussion in 'Off-Roading & Trails' started by Crom, Nov 14, 2009.
  1. Nov 8, 2019 at 10:45 AM
    #3001
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Airing down will help regardless of which tires you run. With washboard if you
    can get comfortable at speed, 30-50, the vibrations usually smooth out depending on how bad the washboard is. If you haven't driven much off-road take it easy at first. Always plan for worst case scenario. The majority of accidents and deaths in DV are from roll-over accidents.
    While stock tires aren't the best I went out to many places before I replaced them with General Grabbers. I got two flats with the Grabbers.
  2. Nov 8, 2019 at 10:46 AM
    #3002
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Its a gambling alright! I love to gamble!
  3. Nov 8, 2019 at 10:48 AM
    #3003
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    You're a quick quoter...I edited my post. Don't gamble in DV. People die there and stuff.
    trailbound likes this.
  4. Nov 8, 2019 at 10:56 AM
    #3004
    BalutTaco
    Ahhh. I wouldn't want that..... Maybe ill stick to the main trails lol
  5. Nov 8, 2019 at 10:59 AM
    #3005
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Or, they end up leaving/abandoning disabled vehicles right in the middle of the roadway blocking traffic in both directions :facepalm:
    trailbound and ETAV8R[QUOTED] like this.
  6. Nov 8, 2019 at 11:05 AM
    #3006
    BalutTaco
    wait how do people roll over? I'm gonna go like 15mph or slower hint (i drive like an old man)
    Arctic Taco likes this.
  7. Nov 8, 2019 at 11:05 AM
    #3007
    BalutTaco
    yeeee... I don't want my taco to be parted out :((((
  8. Nov 8, 2019 at 11:11 AM
    #3008
    MonkeyProof
    SoCal- SGV
    Hobbs, trailbound and ETAV8R like this.
  9. Nov 8, 2019 at 11:13 AM
    #3009
    BalutTaco
    Hobbs likes this.
  10. Nov 8, 2019 at 11:13 AM
    #3010
    MonkeyProof
    SoCal- SGV
    They don't just rollover by themselves...
  11. Nov 8, 2019 at 11:24 AM
    #3011
    BalutTaco
    strange....
  12. Nov 8, 2019 at 1:11 PM
    #3012
    theick
    theick Well-Known Member
    Eric
    Las Vegas
    People drive to fast on a washboard road, get into a corner going to fast, slide into the edge of the road and roll over.
  13. Nov 8, 2019 at 1:37 PM
    #3013
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    I went to Titus about 2 years ago. Super easy. I saw a lot of stock Subaru's. IMO, I don't really think you even need good tires to do that trail. It's just bumpy. I saw an outback hauling ass and passing everybody when I went.
    Titus is on the top of my list on things to see in DV. I definitely recommend it. One of my favorites in California.
    Watch out for sharp rocks, I didn't really see that many though. Just take it slow and enjoy the view!
  14. Nov 8, 2019 at 2:21 PM
    #3014
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Titus is probably just fine on stock tires - just be dang sure you have your good full size spare, it is in good condition and full of air, and you have the tools to change it. You are extremely unlikely to lose two tires on Titus. But you don't want to be the idiot blocking the road if you lose one tire and discover your spare is also flat, rusted in place or whatever.
    Going 15 mph is exactly the thing to do. Greatly reduce the chance of a flat and pretty much eliminate the possibility of a roll over. People roll over from going too dang fast on dirt roads. They are dirt, they provide way less traction. Surprise, surprise you can't turn on them very fast without sliding and then hitting the berm and then "why's everything upside-down all of a sudden?"
    Suspension can play role (pun intended) here as well. On bumpy roads a stock suspension may have less traction than a fancy racing suspension. A stock suspension may also overheat on a long run of washboard again resulting in much lower traction. Truck will start drifting side to side even though you are going straight because a broken/overheated suspension provides little traction on washboard when going fast. None of this will be a problem at 15 mph though.
    One reason people end up going way to fast is that sometimes washboard will "smooth out" as you go faster. So you feel stuck going either really slow or really fast. Airing down can help a lot with this allowing you to travel at a more modest speed with a better ride.
    The other issue with dirt is the ABS system in the truck. If you drive fast with ABS and try to stop in a hurry you will discover you can't actually stop hardly at all going fast on dirt with ABS enabled. So again - just go slow. Or if you expect to go faster do one of the ABS disable mods.
    Titus is usually just some washboard on the first part that just goes across mostly flat desert. Once in the mountains and canyons it tends to be mostly nice road with rocky bumpy sections. These days it is typically in quite good condition with mostly clearance issues for things like Subarus. For a stock truck you should have plenty of clearance. Some parts are rather steep, both up and down, so using low gears is a good idea.
    Anyway, the vast majority of DV is perfectly fine in a stock truck solo. Just be prepared to fix obvious things like a flat. For your own safety be prepared to spend the night with your truck in an unplanned location. Many people make things worse by rushing unnecessarily once they are stuck. Slow down and think. The first thing I do when I get even minorly stuck is grab a soda and a snack and calm down for 15 minutes and then figure out what to do. Camping overnight right where you are stuck if necessary is a fine thing to do.
    MSN88longbed, RenMan, ETAV8R and 4 others like this.
  15. Nov 9, 2019 at 7:00 AM
    #3015
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Yea you'll be fine with your Tacoma on stock tires. Last time I did it I saw a few cars going for it super slow so had to do a lot of passing because most of them have no business leaving the pavement. A stock RAV4 made it through. Now if there's been rain its a whole different story. AFAIK there hasn't been any. As was said make sure your spare is good (ck the air pressure - flip it over). Carry plenty of water. Fill up in Beatty, take it easy and enjoy. Post back
    RenMan and DVexile[QUOTED] like this.
  16. Nov 9, 2019 at 9:51 AM
    #3016
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I’ve put a fair number of desert miles on the Subaru I had before getting back into a truck, and it was in some ways better than even my TRD Tacoma for the majority of gravel/washboard roads like Titus or the Big Pine/DV Road. Lower CG, and AWD helped stability if I did go fast, and fear of flats on my passenger car all season tires encouraging me to go slow we’re the factors.
  17. Nov 9, 2019 at 10:18 AM
    #3017
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    When do you plan to visit DV? Do you have a schedule for Titus Canyon?
    I ask as I am currently headed to Beatty for a day or two and wouldn't mind running Titus again.
    theesotericone likes this.
  18. Nov 9, 2019 at 10:30 AM
    #3018
    BalutTaco
    Leaving on Nov 23rd coming back the 27th its about an 8hr drive.. I have plenty of time depends on my situation when I get there. I do have a list race track, sand dunes, artists drive, telescope peak, Zabriskie point, twenty mule, dantes view, devil golf course, bad water, ubehebe, crater, the kettle maybe the hot springs
    Hobbs[QUOTED] likes this.
  19. Nov 9, 2019 at 10:35 AM
    #3019
    Hobbs
    Yep…
    That's quite a list! Good for you! Which sand dunes are you planning on seeing?
  20. Nov 9, 2019 at 10:37 AM
    #3020
    BalutTaco
    uhhh..... To be honest... I don't know... I just wanna slide down it LOL.
