Death Valley Off-Road Adventures
Discussion in 'Off-Roading & Trails' started by Crom, Nov 14, 2009.
  1. Oct 16, 2020 at 7:14 AM
    #4141
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    have to agree that lower air pressure would have helped
  2. Oct 16, 2020 at 7:40 AM
    #4142
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    @sawbladeduller Currently I air down my General Grabber A/T 2's down to 15 psi for the average dirt road such as Saline. I used to air down my BFG A/T KO2's down to 10 psi because the sidewalls are much stiffer comparing to the General Grabber sidewalls. Both brands are rated Load E. Ive also re valved front and rear which helps with the low impact high frequency stuff. I am curious though, to where do you air down to?
  3. Oct 16, 2020 at 7:56 AM
    #4143
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    I had my E-load duratracs at 17 psi this weekend in saline valley and was cruising the road 40-50 no problem. Good to know I can probably go lower if I ever need to
    sawbladeduller and Hobbs like this.
  4. Oct 16, 2020 at 11:40 AM
    #4144
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    When my truck left the Highway, I dropped the pressure from 45psi to 25psi. I agree a lower psi is helpful. My top speed anywhere in the park is 35mph. I rather enjoy a slower pace than most of you, it seems. I will pull over and let you pass should I see you in my rearview mirror.
  5. Oct 16, 2020 at 11:47 AM
    #4145
    MonkeyProof
    SoCal- SGV
    dropping to 20psi would make a very noticeable difference and would immensely increase the comfort level..
  6. Oct 16, 2020 at 11:53 AM
    #4146
    omegaman2
    omegaman2 Unknown Member
    2015 4WD DCSB
  7. Oct 16, 2020 at 11:59 AM
    #4147
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    I drove out a narrow windy rocky and loose gravel road in 2WD. on return I could not go up the hill in 2WD, maybe a much lower tire pressure would have enabled the 2WD. putting it in 4H the truck rolled up easy.
    ETAV8R, Drainbung and MonkeyProof like this.
  8. Oct 16, 2020 at 12:07 PM
    #4148
    MonkeyProof
    SoCal- SGV
    certainly lower psi's would have aided in more traction, but being in 4wd overall was easier on your rig
  9. Oct 16, 2020 at 12:23 PM
    #4149
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    so tell me about 're-valving'...referring to remote resi
  10. Oct 16, 2020 at 12:53 PM
    #4150
    MonkeyProof
    SoCal- SGV
    possibilities are endless in valving on how you want a shock or coil/over to handle terrain or seat of the pants feel. Basically the valve shims that are inside the shock or coil/over that sandwich the valve body are configured in such a way that is most suitable to your rig, overall terrain that you drive. There are several shock rebuild companies that can do this for you. What brand coil/over and shocks do you have?
    Three companies that quickly come to mind are
    DC Shock Services located in San Dimas, Ca - Kurt is great do deal with, he also does the shock rebuilds and tuning on our Class 6100 Truck and Class 10 Car
    https://www.dcshockservices.com/
    Down South Motorsports located in San Diego, Ca - has rebuilt and revalved my rear shocks years ago, superb customer service
    https://downsouthmotorsports.com/
    Accutune Off-Road located in Carson, Ca.
    Here's a look at my front Coil/Over that I recently rebuilt using new o-rings and shock oil
    The circled red is the shims and valve body
  11. Oct 16, 2020 at 1:26 PM
    #4151
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    As much as I might like to re-build thes myself, realistically over my head. these are King standard resi-OEM replacements, pretty sure 650#coil. probably time for uni-ball replacements as well. Maybe take this apart late next spring when too hot to go Death Valley. I'd have a good bit of downtime.
  12. Oct 16, 2020 at 9:30 PM
    #4152
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    I have the same shocks on a single cab with Cooper STT Pros. I need to revalve mine as well. I would love to keep these tires in the future but I prefer a more cush ride.
  13. Oct 16, 2020 at 10:18 PM
    #4153
    MonkeyProof
    SoCal- SGV
  14. Oct 18, 2020 at 1:03 AM
    #4154
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
  15. Oct 18, 2020 at 7:51 PM
    #4155
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Been a while since I spent any time at Eureka Dunes. Last week I headed out to hopefully enjoy the Orionids Meteor Shower during the new moon. The plan was to head to Saline after a day or two at Eureka Dunes but with the temps being near 100 in Saline Valley and having spent two days with 90 degree temps at the dunes I decided to explore northern Eureka Valley and then head to higher altitudes. Nighttime temps were great at the campground. There were a few campers there and I cannot imagine being there with each site filled with campers and their respective vehicles. One thing I definitely recommend is taking a nighttime hike to any one of the crests of the dune field. Watching stars from that vantage point is really something special.
    Watched this Robber Fly and it's lunch move from plant to plant for quite a while.
    Sunrise on the day of departure
    Referencing Digonnet's Hiking Western Death Valley I decided to explore Cucomungo Canyon out to Nevada and return via the Piper Road. The latter being a bit rougher than the former but nothing difficult in this remote region. Outside DVNP to the north along Cucomungo Canyon there are numerous abandoned cabins and some still lived in ones at Pigeon Spring.
    Startled this yote coming around a corner
    Coming back into the park via the Piper Road did provide nice views of Eureka Valley as noted by Diggonet but it was lackluster with the poor air quality.
    SIZZLE, d.shaw, DVexile and 15 others like this.
  16. Oct 18, 2020 at 8:15 PM
    #4156
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    You mentioned watching the stars from the dunes. Something else I can highly recommend is watching the transition from night to day.
    I did it in the Sierras one night and it blew me away. Seriously one of the coolest things.
  17. Oct 18, 2020 at 8:16 PM
    #4157
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    That requires getting up very early. I'm more of a sunset person than dawn but I'm sure it is awesome too.
  18. Oct 18, 2020 at 8:21 PM
    #4158
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It's really different. I was in the same boat-how could it be that much different? It is.
  19. Oct 19, 2020 at 8:52 AM
    #4159
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    agree. some info from 10.14.20 wednesday. awake looking at stars, surprised to see a red spot eastern horizon. it's 0410 the temp is 64.5*, wind 3.9mph from 347*. a red crescent moon breaks into the hazy sky. at 0610 the T is 61* wind 9.5mph from 342* and starlight fading fast, sunrise.
    DVexile, Hobbs, MSN88longbed and 6 others like this.
  20. Oct 19, 2020 at 2:48 PM
    #4160
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Just read Diggonet's chapter on Cucomungo canyon and this post....it is now on the list for a possible destination on this November's trip to Death Valley. If not this time, one of the trips soon.
    MonkeyProof and sawbladeduller like this.
