Death Wobble!!!
Discussion in 'New Members' started by TroupTaco, Jan 19, 2016.
  1. Jan 19, 2016 at 9:01 PM
    TroupTaco
    TroupTaco [OP] Member
    Marcus
    09 Tacoma TRD OFF-ROAD
    Hey guys.. New to TW and joined cause I have an issue.. The all too familiar DEATH WOBBLE!!! I've searched high and low. At first I thought it was warped rotors, wrong. Checked bushings and no visible damage or missing rubber.. I'm lost. It generally does it when its cold (First 20 minutes on the rd or cold temp) or when its raining and its getting worse. Any clues??
  2. Jan 19, 2016 at 9:08 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Need more information.
    Welcome
  3. Jan 19, 2016 at 9:14 PM
    TroupTaco
    Marcus
    Usually does it on braking, sometimes you can barely feel it on acceleration.. And on first start up.. The colder it is, the worse it is. I've noticed it usually shows its ugly little head around 50-55 but its not always at that speed, sometimes more or less.. Im not a mechanical moron, but this has me scratching my head
  4. Jan 19, 2016 at 9:35 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    how cold are we talking? and is there typically a lot of snow/moisture when it happens?
    (not really good at the vehicle troubleshooting but here goes nothing)
    my thought is maybe the brakes sticking intermittently due to ice build up? are all bolts tight in the suspension leading to the wheels?
  5. Jan 19, 2016 at 9:39 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Death wobble ? Sounds like the way i walked coming back across the border from Tijuana back in my partying days.
  6. Jan 19, 2016 at 9:45 PM
    TroupTaco
    Marcus
    No ice or extreme cold temperatures.. I'm from Georgia so we are talkin between 30 and 50 degrees.. And yes, all bolts are tight
  7. Jan 19, 2016 at 9:47 PM
    theredofshaw
    loose studs on the rotors?
  8. Jan 19, 2016 at 9:49 PM
    TroupTaco
    Marcus
    Negative all wheel hardware is tight
  9. Jan 19, 2016 at 10:11 PM
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    I thought death wobble was a jeep thing.
    Could be tires out of balance. Worn out ball joint or other suspension component worn out or coming loose.
  10. Jan 19, 2016 at 10:12 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    What PSI are you running your tires? How old are they?
  11. Jan 19, 2016 at 10:13 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Where do you feel the wobble? Steering wheel?
    Or is it just some vibration we are talking about? Stock suspension?
  12. Jan 19, 2016 at 10:13 PM
    TroupTaco
    Marcus
    32 psi.. They are maybe a year and a half old. And yes in the steering wheel and brake pedal.. Its the stock suspension
  13. Jan 19, 2016 at 10:16 PM
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    I had the death wobble on my 08 Dodge Cummins after I put the leveling kit on the front end. When I hit certain bumps at highway speeds the whole front end would shake so bad I would almost wreck. It was sketchy as fuck!
    Your problem sounds like something else.
  14. Jan 19, 2016 at 10:18 PM
    memario1214
    Colton
    Missoula, MT
    Hmm... Carrier bearing, ball joints, warped rotors... :notsure: It's so hard to diagnose without having my ass in the seat.
  15. Jan 19, 2016 at 10:18 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I feel stupid for asking, but have you tried having your truck aligned and tires balanced?
    theredofshaw and memario1214 like this.
  16. Jan 19, 2016 at 10:26 PM
    jim532
    jim532 .
    SoCal - 818
    Is it happening while your already moving, or does it happen when you take off from a complete stop? Does it happen when you're driving straight or only when you're turning? Does it only happen when you hit a bump or pothole?
  17. Jan 19, 2016 at 10:36 PM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    You need to go from basics... as stated before: take your truck for an alignment and get your wheels balanced...
    I may think you have a bent wheel, happened to me before...
  18. Jan 19, 2016 at 10:54 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Not sure if death wobble. DW is a self-perpetuating occilation of the steering components as they try to self correct at speed. Its mostly an issue only on solid front axle vehicles and motorcycles. Motorcycles rely on rake/trail to give the caster numbers to keep it upright and the wobble come from the wandering contact patch. On solid axles it's triggered by inputs from the wheels/tires that feed back into the slop in the linkage causing dynamic castering and cambering in oposition when the suspension rapidly cycles side to side. Never heard of it happening on IFS.
  19. Jan 19, 2016 at 11:00 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I second getting an alignment.. When ever I'd pass over sections of road where they "chip and sealed" I got what felt like the death wobble. Got it aligned and it's gone. Granted this was after new UCA's though so my alignment was way off
  20. Jan 19, 2016 at 11:10 PM
    jim532
    jim532 .
    SoCal - 818
    Im pretty sure what this guy is experiencing is not death wobble. Death wobble is pretty violent and is a little more than a wobble.
    I experienced similar symptoms to what the OP is describing in my 04 Taco, it was a bad ball joint.
