Death wobble
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaTaco2000, Aug 2, 2016.
  1. Aug 2, 2016 at 9:31 PM
    ToyotaTaco2000
    ToyotaTaco2000 [OP] Member
    Darin
    Stock 2000 tacoma
    Tires were brand new when I bought the truck 4 months back. Steering box is tight
  2. Aug 2, 2016 at 9:32 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Did you replace the rotors yet
  3. Aug 2, 2016 at 10:10 PM
    98 Taco Max
    98 Taco Max Well-Known Member
    Max
    Calgary, AB
    v6 Tacoma 4x4
    total guess i have no idea but bad bushings or loose bolts in the steering rack, front strut mounts, or control arms?? what is the wheel alignment like?? stock truck also means stock size tires?
  4. Aug 3, 2016 at 5:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    If it's not affiliated with brake application, how do rotors create the problem?
  5. Aug 3, 2016 at 7:38 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    My guess is it's something in the suspension geometry that allows the oscillation to happen. If you have checked all the front suspension components, and still can't find anything, I'd try a little more caster in your alignment. This will help with the wheels wanting to point themselves straight. It could be that without enough caster your wheels are on the edge of stability. Think trying to push a grocery cart with at least one front wheel pointed in the wrong direction. You can't make it more than a few inches without going very slow and often not in the direction you want. Of course you could have a situation where the carts wheel just shakes up and down every aisle, in which case you have a defective component...
  6. Aug 3, 2016 at 7:56 AM
    ToyotaTaco2000
    Darin
    Stock 2000 tacoma
    I can get the wobble/shake to happen when ever if I go down to a bout 35 mph in 5th gear and then speed it up it happens when I'm speeding up again. But it happens mostly after I go over a bridge or an over pass on the freeway but it comes at random times
  7. Aug 3, 2016 at 7:59 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
  8. Aug 3, 2016 at 8:18 AM
    ronoc
    ronoc WisTaco Guy
    Madison, WI
    Bruce 2017 TRD OR DCLB 4x4
    Line-X coated Leer 180 topper Prinsu cab rack Ebay Pro Grill
    I had a slight version of this when on the highway until I replaced the steering wheel bushings. Tightened everything right up.
  9. Aug 3, 2016 at 7:18 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Wow that video is shocking, i just cant happing without a really fucked tie rod or loose A arms, if is was a loose wheel bearing that was that bad theres no way you couldnt hear it going down the road.
  10. Aug 3, 2016 at 7:22 PM
    K9kodi
    K9kodi Well-Known Member
    1997 Tacoma x cab 4x4 2.7
    3" body 2.5" spacer
    Well on my solid axle just he alignment being off with too little caster caused it. Tires were too neutral and had no resistance. i went through and bough Carli ball joints, new steering box, new tie rod and drag link, steering box stabilizer. You name it. Just needed some caster. I'd button everything up and check everything, rotate tires rear to front and check alignment
    robssol and mlcc like this.
  11. Aug 4, 2016 at 12:01 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    VoilĂ ! Validation! Lol, This would be the cheapest thing to check. So two votes for caster...
  12. Aug 4, 2016 at 12:27 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Was steering rack bushings suggested? Or control arm bushings? Rack bushings can easily be checked turning the tires (parked) and watching the rack for flex. Also id have the rag joint as well as the steering arm yoke or whatever it's called, I forget. Mine went bad, the joint located in the firewall. Didn't have that wobble, but I suppose it could cause it.
  13. Aug 4, 2016 at 1:05 AM
    Chocolates
    Chocolates Well-Known Member
    Seattle or Bellingham
    05 DCLB
    Unicorns and glitter
    Another obvious one is tire pressure. Double check it. On an SAS 4runner I used to have, we went through all the other stuff (including the important caster!), and realized lower pressure was setting it off. A cheap one to check off if you haven't.
  14. Aug 4, 2016 at 1:28 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Concur with alignment. If you're not a Jeeper (I'm not either) you probably aren't familiar with death wobble, having seen it happen at 65 as my buddy was following me....it's terrifying. For him it was new(er) tires, and an alignment that mostly cured it. @JJ04TACO hit it on the head with suspension geometry. Unless you're super lifted or your entire suspension shit the bed you shouldn't have death wobble like a Jeep or anything even close.
    All you guys talking about brakes...:bananadead:
  15. Aug 4, 2016 at 4:07 AM
    #35
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Front struts would have been my first thing to check. A more rare and unfortunate occurrence would be bad bearings in your front differential.
  16. Aug 4, 2016 at 4:20 AM
    #36
    Squirrelbomb
    Squirrelbomb Well-Known Member
    Lost in Montana
    16 DCLB OR
    If you had a solid axle I would say it was your track bar. With an independent front end I would say control arms also check draglinks and tie rod ends for play.
  17. Aug 7, 2016 at 12:55 PM
    #37
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Any updates?
  18. Aug 8, 2016 at 11:39 AM
    #38
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I had a wobble problem last year that started out quietly and increased in volume and intensity over the next 2 miles, then gradually stopped over the next mile or so. That happened in two different locations on the interstate. Haven't had it since but you know what they say, "Problems that go away by themselves come back by themselves..."
    This first happened after I replaced the rear brake linings. To see what was going on, I drove about 60 and then very slowly applied the emergency brake. For my efforts I was rewarded with the same exact "wobble", starting with when the brake shoes first started to make contact with the drums. I'm still working on the problem as of today though. If I find anything definitive I'll definitely post a notice in this forum.
