DEATH WOBBLE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rtsutsui, Oct 30, 2019.
  1. Oct 30, 2019 at 12:01 PM
    rtsutsui
    rtsutsui [OP] New Member
    Recently my 2006 Tacoma prerunner access cab with procomp 17in wheels and nitto crossteks 265/70/17 has been whobbling so bad it’s almost unbearable. When I’m going 30-40 there is a slight wobble but once I get going around 60+ it gets really sketchy and the whole car shakes not only the steering wheel, I recently replaced my center drive shaft bearing and u joint and that has done nothing, the wobble is always there no matter what rmp I’m at or the weather conditions. Any help would be greatly appreciated!!!
  2. Oct 30, 2019 at 12:29 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I’d look at wheels/tires/balance.
    are the wheels hub centric? Whats the center bore size? Any wheel spacers?
  3. Oct 30, 2019 at 12:36 PM
    firelu
    firelu Well-Known Member
    el monte, Ca
    2011 4x4 sport package
    Smoked tail lights, blacked out emblems
    I changed the wheel hub bearing assembly
    and that fixed the problem
    rtsutsui[OP] likes this.
  4. Oct 30, 2019 at 12:53 PM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    Considering it wasn't there before: wheel bearings, lost tire weights, and maybe even loosened alignment points is where I'd look first.
    A friends Benz had the problem that appeared one day and got progressively and rapidly worse. It was the stock steering dampner that went out. Tacomas don't have one. Chevrolet had that problem for a couple of years right out of the plant, they added a steering dampner to "fix" it. Lol
  5. Oct 30, 2019 at 12:55 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Sure it ain’t a Jeep?
    Torspd, whatstcp, TacoBreaker and 2 others like this.
  6. Oct 30, 2019 at 12:57 PM
    beriman10
    beriman10 Well-Known Member
    Omar
    Orange County
    2019 Jeep Wrangler Unlimited Rubicon
    Fox 2.5 Suspension 2 in Lift
    What your describing does not appear to be death wobble. Death wobble is known to occur with solid axle vehicles such as jeeps and heavy duty trucks when steering components are worn. As others have said above, look into alignment/balancing issues with your wheels or potentiall wheel bearings
    vssman, rtsutsui[OP] and JC15Taco like this.
  7. Oct 30, 2019 at 1:09 PM
    LAMCKMA007
    San Diego county
    2006 DCLB 2WD
    I realize those Jeep comments weren't directed towards me however I'm 100% positive a Benz S Class doesn't have a solid 4WD axle in the front. It definitely had a death wobble prior to replacing the stock steering dampner.
    I'll take an extra large popcorn and a small Pepsi please, keep the change.
    rtsutsui[OP] and Alexely999 like this.
  8. Oct 30, 2019 at 4:21 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Death wobble is actually caster wobble. Check the alignment, LCA bushings, etc. Without enough caster, the wheel will start to wobble like a bad wheel on a shopping cart.
    whatstcp likes this.
  9. Oct 30, 2019 at 4:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Jack and test all ball joints.
  10. Oct 30, 2019 at 5:06 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Check that your wheels are hub centric. If the inner diameter of the center of the wheel is larger than the outer diameter of the center of the hub, where it locates, you'll get some wobble/vibration.
    This is a pretty quick thing to check and from a lot of the reading on here, it sounds fairly common.
    It could be a lot of things, but this would be the first thing I would check.
    Alexely999 likes this.
