Deaver leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Dec 19, 2024.
  1. Dec 19, 2024 at 8:29 AM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys looking for anyone that has experience with the deaver leaf springs on the 2nd gen . Whitch deaver spring do I need if I want to maintain the 1in. Of lift with the 180 - 200 Pound shell .
  2. Dec 19, 2024 at 8:35 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Do you mean Deaver?
    The U402 Stage 1 should give you a little over 1" of lift with that bed weight.
    If you don't have bed stiffeners, they would be a good investment also with the cab or just if you go offroad at all.
  3. Dec 19, 2024 at 8:37 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    inkedtater likes this.
  4. Dec 19, 2024 at 8:37 AM
    tacoma guy
    Joe
    Phoenix Az.
    Oops yes . Danm auto spell correct. Ok that is what I was wondering. On there web sight they said 2in . But I wasn't sure if that is before or after the weight . Yes I definitely did the bed stiffeners before installing the shell .Thank you for suggesting the stiffeners much appreciated !
    drizzoh[QUOTED] likes this.
  5. Dec 19, 2024 at 8:48 AM
    UMC
    UMC I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    37's & rear locker
    You might want to consider stage II as well. Stage I is designed for 0 to 300 lb and stage II is 400 to 600 lb. When you load it up with camping gear and stuff it's easy to push over that 300 lb mark which is a little arbitrary in my opinion.. I have stage II and sometimes run an empty bed and sometimes have as much as 1,000 lbs. It's a little stiff when empty but I think a lot of it comes down to a matter of preference.
  6. Dec 19, 2024 at 8:57 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    The lift they note, 2 inches in this case, is loaded to the rated weight. If you are unloaded, the lift will be much higher. I'm running stage 3 for my camper, and if I take out the camper I probably have like 6 inches of rear lift, lol. practically zero down travel.
  7. Dec 19, 2024 at 9:01 AM
    inkedtater
    inkedtater Member
    Tater
    2017 TRD Off Road long bed Access Cab
    Body Armor Bumpers - Front and Back S&B Cold Air Intake Icon Billet UCA Eibach Pro Truck Lift w/ Coil Overs Icon AAL Springs Spyder Worx 1.25" Spacers R4T Body Mount Relocate Camburg Stock length LCAs Carven Cat Back with Magnaflow Muffler Welded In Heritic Light Bar & Ditch Lights Nacho Roof Lights Torrix Winch w/ Factor55 Ultra Hook & Fairlead RCI Skids and Sliders Teraflex x Nomad Deluxe Offroad Wheels Toyo Open Country RT Trails 295*70*17R
    YF_Ryan likes this.
  8. Dec 19, 2024 at 9:03 AM
    YF_Ryan
    Kent, WA
    Looking at that link, I swear for 2nd gens the lift was rated at 3 inches. I think the 2 inch is for 3rd gens, as they sit slightly higher to begin with.
  9. Dec 19, 2024 at 9:12 AM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah there wed sight isn't to clear . I will have to call them and see what they say . Thanks guys for all the replys and info . Much appreciated!! :thumbsup:
    YF_Ryan likes this.
  10. Dec 19, 2024 at 9:50 AM
    BabyBilly
    Billy
    2020 TRD
    Yeah I've been running the Stage II for a few years with about 500lbs constant load. I wouldn't use them with much less weight than I've got.
  11. Dec 19, 2024 at 10:17 AM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    These are rated at 2 inchs of lift with the weight.
    Just installed mine and there 2-2.5 with 300lbs.
  12. Dec 19, 2024 at 10:24 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Damn. From what I've seen that's the unweighted lift and have seen other guys report about it goes down to ~1.25" lift with 200lbs on that pack. Leaf packs always seem to lift more than advertised though. Aside from the ride quality being awful, that's the other thing that pissed me off about my RXT pack. Lifted way more than it said. Couldn't get rid of that pack quick enough.
  13. Dec 19, 2024 at 10:34 AM
    YF_Ryan
    Kent, WA
    Yeah, Deaver are definitely rating the lift WITH the rated weight. It takes 2000 or so pounds of weight to get my rear end back down to stock height.
  14. Dec 19, 2024 at 10:42 AM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Yep
    Rated weight
    And it’s based on a 3rd Gen
    The 2nd Gen should be able to add a lot more weight to the rating.
  15. Dec 19, 2024 at 10:48 AM
    tacoma guy
    Joe
    Phoenix Az.
    Danm . So if I only want 1" of lift with the 200 pound shell I wonder if I should go with the j66 springs ? They are rated at 1"of lift but it doesn't say with how much weight. So being that they don't mention any weight if that is just with an empty stock bed ?
  16. Dec 19, 2024 at 10:52 AM
    BabyBilly
    Billy
    2020 TRD
    Deaver will bend custom leaf springs for your truck if you tell them your weight and where you want it to ride. They just won't be available off the shelf. Alcan will do the same.
    drizzoh likes this.
  17. Dec 19, 2024 at 10:57 AM
    YF_Ryan
    Kent, WA
    Do you not usually run with anything under that 200 pound shell? I always feel that weight adds up far faster than people expect. I actually planned to go Stage 2 originally, but a friend told me I should get Stage 3 for this reason. I'm extremely glad I did.
    And if you do go Deaver, when first installed they'll be even higher. It took awhile for mine to settle, same thing happened with my buddy's raptor. Looked silly in the rear for a bit, even loaded.
  18. Dec 19, 2024 at 10:59 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    J66 is what I'm running now. They're not designed for weight as they do not have an overload leaf. I've put a couple hundred lbs in mine and it didn't protest too much, but not sure how much weight it would want to have on a daily basis. You could run the J66 + move over your factory overload and get the best of both worlds with about 1.5" unloaded weight, but it would be best to contact Deaver directly for your needs. Wish they offered more packs that didn't jack up the bed super high.
    I love the J66 unloaded though, which is how my truck is 99% of the time. Highly recommend to everyone with an empty bed.
  19. Dec 19, 2024 at 11:00 AM
    tacoma guy
    Joe
    Phoenix Az.
    Oh WOW, I was not aware that they would do that . That might be an option. Thanks for letting me know that . Thanks to all you guys for all the info ! That helps narrow things down a bit more .
  20. Dec 19, 2024 at 11:05 AM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah the 200 pound shell is what I run 99 % of the time . When I do put more weight it's not in there for to long .
    YF_Ryan[QUOTED] likes this.
