Deaver Spring Drive train noise / hum 75 MPG
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bajasurfer4X4, May 18, 2024.
  1. May 18, 2024 at 1:55 PM
    Bajasurfer4X4
    Bajasurfer4X4 [OP] Member
    Justin
    2019 TRD Off Road Double Cab
    33' K02, 3' Bilstein 5100 lift, High Topper Snug Top
    I recently upgraded to a heaver Deaver spring with added about 1.5 lift on the back. I am getting a low frequency notice/ hum/ friction only during acceleration from about 65 to 75 MPH. I can also feel the steering wheel vibrate due to this vibration. Before installation of springs this noise was not there. The shop that installed them could not find a problem and said the springs are "still settling down" The shop that installed said they had the drive line measured and it was all good. I am still getting the noise and I can't imagine this is good for the drivetrain long term. Any ideas?
  2. May 18, 2024 at 6:44 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If you feel it in the steering wheel, its something attached to the steering wheel
  3. May 18, 2024 at 6:58 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    have you checked your driveshaft? I've seen them hum and vibrate before. Pull it out and drive in 4wd and see if the noise goes away. Another thought would be pinion bearing.
  4. May 19, 2024 at 5:12 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Driveline/pinion angle. Rule is one degree shim per inch of lift. First try carrier bearing drop. Easy install.
