Deaver stage 3 leaf springs- truck has a phat butt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by THEJOEB, Sep 27, 2024.
  1. Sep 27, 2024 at 12:44 PM
    THEJOEB
    THEJOEB [OP] Member
    2023 Ice cap Tacoma TRD PRO
    Hey all,
    Looking for a little advice on getting my payload under control in my 23 pro. Carrying a bunch of weight static in the bed now (RSI smartcap, frontrunner rack, solar panels, fridge/slide, power station, recovery gear etc) and am looking into some new leaf springs to support the load. Currently carrying around 500lb full time, and with my toolboxes and basic camp gear its easily 700-800 full time in the back. So im sagging.
    Question is, I have a pro so I was hoping to just run my Fox suspension for as long as I can until I upgrade to new shocks all around someday, but clearly I am going to have to upgrade my leafs now... can I replace my current stock leafs with the deaver stage 3 and not get new rear shocks? The Deavers add about 2" lift by themselves, and im sagging roughly 1.5 inches so that would probably just get me back to level as long as the current rear shocks can be used.
    Im not a mechanic, but I have turned a few wrenches in my day and spent time at youtube university, so Im fairly confident on the install aside from the question of if my current shock setup will still fit with the extra 2 inches on the bigger leaf springs.
    Im sure some of you here have similar issues or setup and was hoping for some ideas on what worked for you. I got too much junk in my trunk.
  2. Sep 27, 2024 at 12:53 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Your stock height springs will not be long enough at full travel. The deavers will add 2" of lift with 700lbs in the bed. That's 2" above stock height, which is 3.5" above your current sag height
  3. Sep 27, 2024 at 12:53 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Yes you can replace the leaf springs without replacing the shocks provided the leafs are intended to fit a taco.
    Anyways, I suggest you ask Deaver for a more authoritative answer
  4. Sep 27, 2024 at 12:55 PM
    gudujarlson
    Minnesota
    This is a common misconception. The shocks limit down travel. The springs are only changing the ride height at rest. They don’t change the upper or lower limit of suspension travel. You might not get the full down travel the springs allow, but nothing bad will happen.
    THEJOEB[OP] likes this.
  5. Sep 27, 2024 at 1:05 PM
    THEJOEB
    THEJOEB [OP] Member
    That was my understanding as well, I may get less down travel with the increased ride height but hopefully they still fit.
    gudujarlson[QUOTED] likes this.
  6. Sep 27, 2024 at 1:09 PM
    gudujarlson
    Minnesota
    As an aside, your Fox shocks might already have slightly more travel than stock. If you put longer travel (universal fit) shocks on, then you need to consider bump stop, brake line length, shock mount relocation, and perhaps other things.
  7. Sep 27, 2024 at 1:15 PM
    Anchovy
    TRD Ferguson
    Except you don't want the shock to be the limiting factor, if you put a limiting strap it'll be fine. But just the shock, the shock will pull itself out in full droop
  8. Sep 27, 2024 at 1:16 PM
    gudujarlson
    Minnesota
    Desert racing trucks have limit straps. Stock trucks do not. On stock trucks the shock limits down travel.
    OEM replacement springs and shocks are made to fit the truck without other modifications, with caveats.
  9. Sep 27, 2024 at 1:20 PM
    THEJOEB
    THEJOEB [OP] Member
    Appreciate the insight, I will of course email Deaver as well before pulling the trigger, but from my research it seems the leaf pack will be the solution i'm looking for and I will likely replace the bumps too while im at it. Just hoping not to have to replace the whole shock setup too at this time.
  10. Sep 27, 2024 at 1:22 PM
    gudujarlson
    Minnesota
    If deaver says something contrary, please inform us.
