Deaver stage 3 or dobinson super heavy duty leaf springs??
Discussion in 'Suspension' started by aidenhardcore, Oct 15, 2019.
  1. Oct 15, 2019 at 7:55 AM
    aidenhardcore
    aidenhardcore [OP] Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    So I have a lifted Tacoma with the Ome heavy duty leaf pack in the back. They gave me 3 inches of lift but within six months it is already sagging an inch and a half down. So I need to change them up. Any weight on them and they sag bad.
    if you had to go with a more heavy duty leaf pack, which one would you go for? Deaver stage 3 700-900 lbs or dobinson super heavy duty leaf pack up to 1,100 weight. I was told deaver is a 3inch leaf pack but dobinson not sure.
    If you had to spend the money on a heavier leaf pack them the ome, what would you choose? Thanks guys
  2. Oct 22, 2019 at 7:55 AM
    amag413
    amag413 Well-Known Member
    Aaron
    Philly
    2014 Black Tacoma TRD Sport | Double Cab SB
    JD Fab 2.25 kit, Homemade flatbed, Four Wheel Camper
    The dobinsons super heavy leaf pack will put you at around 3" without a super heavy load and sit more around 2-2.5 with the full payload of your truck in there. What do you have in the back of your truck? the dobinsons leaf pack is also less expensive by a few hundred and its a really good product.
  3. Oct 22, 2019 at 9:01 AM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    The only thing I have on there is a truck cap. which I think weighs about 198 pounds. I do point between 500 and1100 pounds in the bed two times a week for deliveries but besides that that’s all
