Deaver U402 advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by St1fler, Jun 28, 2021.
  1. Jun 28, 2021 at 3:56 PM
    St1fler
    St1fler [OP] Well-Known Member
    Im currently sitting on 4”/2” with about .5” reverse rake after adding bedrack and gear (150 lbs ish) looking to add deaver u402 leafpacks but torn between stage 1 and stage 2. I probably will run another 50 pounds additional constantly and camping gear with rooftop tent will add likely another 200 pounds they will not be on the truck at all times. Leaning toward stage2 but don't want to be too ass high unloaded. What sez ye masses? Pic for attention
  2. Jun 28, 2021 at 6:04 PM
    St1fler
    Not sure why i cant see replies… but heres the email. First, thanks for the compliment. I agree rake is good i just dont want crazy rake. Really thinking stage 2. Right now in the front I am 24.5 hub to fender and 24 flat in the back with a 2” block
  3. Jun 28, 2021 at 6:08 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Stage 2 would be nice. I hate sagging, I rather have a huge rake than a saggy ass
  4. Jun 28, 2021 at 6:19 PM
    WestCoastMango
    WestCoastMango Well-Known Member
    Anthony
    Vancouver Island
    2019 DCSB
    Sounds like stage one would be your best bet. I'd get the stage that you're carrying 90% of the time. If you're constantly over 400lbs then get stage 2.
    Stage one would give you a better ride quality given your load and more flex/droop for off-roading.
  5. Jun 28, 2021 at 7:08 PM
    Abject4x4
    Abject4x4 Just another idiot on the internet
    Marcus
    White SR5 Access Cab
    Going off this, you want all of your suspension to be as soft as possible for the weight you’ve got. Going overboard on coilover springs or a leafpack can be a real pain in the ass — literally.
    Bertw192 likes this.
  6. Jun 28, 2021 at 7:15 PM
    Macsplace
    Macsplace Active Member
    21 Tacoma
    Just installed stage 1's this past weekend. Rough measurement from center of hub to bottom of fender 23.75. I have factory triple fold bed cover, bed mat, and about 30-40 pounds of gear at all times. This is on a 21 Dcsb. Hope this helps
  7. Jun 28, 2021 at 7:23 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    my rear bumper with swingout is ~275, with no tire.. Im planning on getting stage 3
  8. Jun 28, 2021 at 7:24 PM
    angerbot
    angerbot Well-Known Member
    Yep, soft springs and firm shock valving will give you a better ride than the reverse. Go stage 1 IMO.
    WestCoastMango likes this.
  9. Jun 29, 2021 at 2:08 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I have the stage 2 because I don’t want my truck to squat
  10. Jun 29, 2021 at 3:51 AM
    St1fler
    this helps greatly! that is too low! I am right at 24" now with a Dobinsons Quick ride block and factory leafs. Stage 2 it is
