Deavers w/ air bags?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PThy, Mar 13, 2025.
  1. Jun 3, 2025 at 7:30 AM
    paralysisXanalysis
    paralysisXanalysis Active Member
    Mesa, AZ
    2016 Tacoma TRD OR
    Auxiliary cooling fans, rebuilt takeoff TRD pro shocks, Airbags, Deavers, Trans Cooler, Fab Four rear bumper, 2wdLo mod, other dumb stuff
    There is an eyelet on one end and the other end is a threaded shaft on my fox piggybacks (TRD pro takeoffs I got dirt cheap and rebuilt myself) so there is only one OEM mounting orientation. As for the orientation of the shock damper I see no issues with orientation as long as it is valved for that specific orientation. So yes I agree with you if I had mounted it upside down my rebound valving would be controlling the compression cycle and the compression valving would be controlling the rebound cycle. "Not ideal" in the words of Lance Armstrong
    But if it was valved properly specifically for shaft up or shaft down then the designed orientation will work fine.
    Hope I'm making sense - not sure why I typed that all out I'm fairly certain we are on the same page
    Dorf510[QUOTED] likes this.
  2. Jun 19, 2025 at 11:04 AM
    paralysisXanalysis
    Mesa, AZ
    2016 Tacoma TRD OR
    Hey sorry to drag this up again, do you feel like the bag and cradle setup is limiting your uptravel? I am blow away by how good the deavers ride on road and off (wailed on them this weekend out side of prescott) but I don't see much room for uptravel as the bags are maybe 2" from contacting the cradles? I have plenty of uptravel on the shocks (currently riding at 20% sag if that) but am interested how you feel (or actual data) about your deaver - airbag setup
  3. Jun 21, 2025 at 6:27 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    The up-travel is not a issue on the daystar cradles, as the bag is only attached to the frame side and not directly to the axle(has a “strike pad” the bag rests on). I air them to 25-30 when towing(2-3k lb) and then air down to 0psi when running trails. The daystar cradles/mount allows the bags to be used when needed, but not limit the travel too much when fully aired down(more of a rigid bump-stop when aired down).
  4. Jun 23, 2025 at 12:13 PM
    paralysisXanalysis
    Mesa, AZ
    2016 Tacoma TRD OR
    I need to measure the stack height of cradle, bag and bag mounting hardware vs the OEM bump stops and compare the difference. my gut tells me that even at full 0-5psi in the bags and full compression the stack height of the airbag assembly is greater than that of the OEM bumps thus limiting up-travel but only by an 1.5" - 2" at most??? Sorry I know I am splitting hairs and not the best at explaining but I think it is something to consider when using airbags.
    All that aside thx for the info on bags and deavers, the deavers have been the best suspension upgrade I have ever done and the truck rides wonderfully on and off-road, and although I am on the fence about keeping the bags installed they were and are a great tool. On road feels as good as a 63" GM leaf which is insane and offroad it just eats up nasty trails. Wildly impressed with deaver
  5. Sep 4, 2025 at 9:04 AM
    paralysisXanalysis
    Mesa, AZ
    2016 Tacoma TRD OR
    well I have been running deavers and airbags for 3+ months and I am a huge fan of how well it is performing. Towing with the bags inflated to 35 psi the whole setup rides like a dream (towing a popup camper and load so up to 4K at times, not sure on actual tongue weight). I have towed from Phx to durango, dropped the popup at the campsite and after adjusting tire and airbag pressure it has wheeled around flawlessly. Also have done a few other trips in the AZ white mountains and it has towed great on forest roads of all kinds. I am a big fan of the setup. There are some minor drawbacks and I don't think that the trd pro shocks have the right stroke and length for my setup but overall it has been great towing and rips pretty well on rough roads (for what it is).
    Thanks for all those that provided input.
