Deavers?
Discussion in 'Suspension' started by Just Moist, Sep 17, 2012.
  1. Sep 17, 2012 at 11:40 AM
    Just Moist
    Just Moist [OP] Active Member
    Austin
    Pre runner
    Are oem replacement 10 leaf deaver pack make a big difference ?
    Or should I go 62" long travel leafs?
  2. Sep 17, 2012 at 11:46 AM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    San Clemente
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    They will be different than stock, yes. OEM replacement (J66) will give you about 1-1.5" of lift but they can't hold a load for shit. Ride is about the same.
    F55 or F67 is SUA and definitely not an OEM replacement .. lots of upgrades required to use them.
    Sounds like you need to research a bit more.
